2 Replies Latest reply on Aug 23, 2011 4:21 AM by Colin Brougham
    Add a Dissolve to Favourites
    andi_urra Level 1
      Hi, this seems odd, but I cannot find a way to add a dissolve, e.g. "Dip to White" to my favourites, i.e. presets.
      Am I missing something?
      Regards,
      Andreas
        • 1. Re: Add a Dissolve to Favourites
          Colin Brougham Level 6
          Do you mean save a transition as a preset? If so, you can't do that. Ask for that here: Adobe Feature Request/Bug Report Form
          You can add a transition to a custom effects bin, though. Just create a new custom bin (in the Effects panel) and then drag the transition you want into it. It's simply a copy/link to the original transition; you can't save any custom parameters (e.g. duration) for the transition.
          • 2. Re: Add a Dissolve to Favourites
            andi_urra Level 1
            Hi Colin, thank you very much. That was what I was looking for. I had tried to drag them into the Presets folder. This did not work. I had totally forgotten about the option to create custom folders.
            I will add a feature request for adding them to the presets, though. So that it should be possible to have default lengths and other parameters available.
            Thanks and regards,
            Andreas
