1 Reply Latest reply on Aug 24, 2011 5:38 AM by Jerry62712
    Flex 3 to Flex 4
    Jerry62712 Level 1
      I'm trying to convert an application from Flex 3 to Flex 4.  One of the problems is discussed in another thread on how Flex 4 doesn't use CSS (background-Image).  But this thread is for other things, starting with this.
      1) When I go into design mode, the properties becomes blank and says it will only work in design mode.  Is there a secret design mode?
      2) When I go into design mode, the image won't fit on the page and you can't scroll down.  If I change the resolution to 12%, it will fit on the page but is unreadable.  Is there some way to scroll so you don't have to go to 12%?
      3) When I try to run the application to see it, I only get an old version and not the current one.  How do I force it to use the current version?
      Thanks.
