4 Replies Latest reply on Aug 27, 2011 3:59 PM by abbyfvc05
    Premiere Elements 9 - file too large
    abbyfvc05
      When loading high quality pics (5 meg and up) into Elements 9 I get an error message that the file(s) are too big.  Only way around it so far that I have found is to resize my pics before incorporating into Elements 9.
      Any other suggestions on how I can get around this.  Any comments are welcomed.
      Cheers !!!
        • 1. Re: Premiere Elements 9 - file too large
          I've been recommending for years (both in my books and in the FAQS  to the right of this forum) that you never use a photo larger than 1000x750 pixels in a video project. (For hi-def, you can go as large as 2000x1500.)
          http://forums.adobe.com/thread/431851?tstart=30
          Using a larger photo does not make for better video. Video resolution is video resolution -- and putting a larger or higher definition photo into a project doesn't accomplish anything except slow rendering to a crawl and, more often than not, crash the program.
          A 5 megapixel photo is about 1,664,000x1,248,000 -- or nearly 7 times our recommended size.
          • 2. Re: Premiere Elements 9 - file too large
            the_wine_snob Level 9
            I agree with Steve.
            In PrE, the Scaling algorithms in PS, or PSE, are better, and yield higher quality. This ARTICLE goes into more detail. Note: when originally written, the vast majority of video was SD, at 720 x 480 (NTSC), or 720 x 576 (PAL), but further down the article, mention is made of HD Projects, which run up to 1920 x 1080. That article also goes into detail on doing the Scaling in PS/PSE with automation.
            Also, processing overly-large still images is very, very resource intensive, and it only takes a few very large images, before the computer and PrE will choke. This is even true with PrPro CS 5 and 5.5, which now have better Scaling algorithms, but can still suffer with many very large images. It takes a serious NLE workstation, that is perfectly tuned to handle them. If one really needs all those extra pixels, then I strongly recommend that they use After Effects, instead of PrPro, or PrE.
            • 3. Re: Premiere Elements 9 - file too large
              abbyfvc05 Level 1
              Thank you very much for your help.
              Cheers !!!
              Alan,
              • 4. Re: Premiere Elements 9 - file too large
                abbyfvc05 Level 1
                Thank you for your help.
                Appreciated !!!
                Alan,
