5 Replies Latest reply on Aug 25, 2011 7:42 AM by RupakKhurana
    What Destination Name to use with DataServiceTransaction in Model Driven approach
    RupakKhurana Level 1
      Hello
      I am using Model Driven Approach where no destinations are configured in data-management-config.xml, it is done automatically. In my backend webapp, I want to persist some data and push the changes to the clients. While I can use DataServiceTransaction.createItem() but what destination name should I use? What is the default name of the destination created by model assembler?
      thanks
      RK
        • 1. Re: What Destination Name to use with DataServiceTransaction in Model Driven approach
          Rohit . Kumar Adobe Employee
          Hi Rupak,
          You should pass the destination name to DST. And by default, it is called <ModelName>.<NameOfEntity>
          Rohit
          • 2. Re: What Destination Name to use with DataServiceTransaction in Model Driven approach
            Ashish Vashisht Level 1
            The Destination Id is <ModelName>.<EntityName> (Note the dot . in between the two parts). If you have Flash Builder with the Data Services Modeller plugin installed, you can actually see the destination in the Destinations view, under DMS Destinations.
            I also wanted to note, if you run into issues calling Data Service Transaction on the server, you may want to try setting the Message Broker on the FlexContext like this:
            MessageBroker messageBroker = MessageBroker.getMessageBroker(null); //Pass in the Message Broker ID if you have changed it.
            FlexContext.setThreadLocalMessageBroker(messageBroker);
            then when you are done with the Data Service Transaction, you can call setThreadLocalMessageBroker() with null.
            • 3. Re: What Destination Name to use with DataServiceTransaction in Model Driven approach
              Hi Ashish
              Now the Destination ID is correct but I get the following exception. Also tried setting the Message Broker on the FlexContext but same error. The code is as follows.
              Pls advise
              Rupak
                       DataServiceTransaction dtx = DataServiceTransaction.begin(false);
                       //DataServiceTransaction dtx = DataServiceTransaction.getCurrentDataServiceTransaction();
                       dtx.setSendChangesToAdapter(true);
                       Currency c1 = new Currency();
                       c1.setCurrencyCode("ABC");
                       c1.setCurrencyName("Dummy Currency");
                       c1.setCurrencyLastUpdated(new Date());
                       c1.setCurrencyId(new Integer(537));
                       dtx.createItem("TraderWorkStation.Currency", c1);
                       dtx.commit();
                       FlexContext.setThreadLocalMessageBroker(null);
              TWSServer08/24/2011 11:15:31.736 DEBUG Service.Data.Transaction Started non-jta data service transaction
              TWSServer08/24/2011 11:15:31.768 DEBUG Service.Data.Transaction Sending server message to adapter: Flex Message (flex.data.messages.DataMessage)
                  operation = create
                  id = {currencyId=537}
                  clientId = srv:91D4E7AE-B0DB-B0EA-681D-4404F4AC8E96
                  correlationId = null
                  destination = TraderWorkStation.Currency
                  messageId = srv:91D4E7AE-B0DB-B0EA-681D-4404F4AC8E96:0
                  timestamp = 1314198931739
                  timeToLive = 0
                  body = TraderWorkStation.Currency@238
              TWSServer08/24/2011 11:15:31.771 DEBUG Service.Data.General Before TraderWorkStation.Currency.createItem (
                  (TraderWorkStation.Currency) {currencyId=537} (14308998) {
                      currencyName = Dummy Currency
                      currencyCode = ABC
                      currencyId = 537
                      currencyLastUpdated = Wed Aug 24 11:15:31 EDT 2011
              TWSServer08/24/2011 11:15:31.797 DEBUG Endpoint.AMF Serializing AMF/HTTP response
              Version: 3
                (Message #0 targetURI=/1/onStatus, responseURI=)
                  (Typed Object #0 'flex.messaging.messages.ErrorMessage')
                    headers = (Object #1)
                    rootCause = null
                    body = null
                    correlationId = "7816F4B3-E6EC-B7CD-A98D-FC5EFF8A3646"
                    faultDetail = null
                    faultString = "The item of type, 'TraderWorkStation.Currency', passed to the assembler does not match the assembler's configured entity type, 'TraderWorkStation.package1.Currency'.  To convert 'flex.messaging.io.amf.ASObject' to a strong type automatically, set the item-class in the destination."
                    clientId = "91D4E4EF-9095-35C3-0E30-0059517696E5"
                    timeToLive = 0.0
                    destination = "AdminControlService"
                    timestamp = 1.314198931792E12
                    extendedData = null
                    faultCode = "Server.Processing"
                    messageId = "91D4EF9D-F0F1-D3D1-5F9B-2F636C098859"
              Message was edited by: RupakKhurana
              • 4. Re: What Destination Name to use with DataServiceTransaction in Model Driven approach
                As Don mentioned in the other thread, you can use the ServerGeneratedEntities annotation to control this. For more information, see this documentation:
                http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WS4976f0ec3ef482461096f 38112701857408-8000.html
                • 5. Re: What Destination Name to use with DataServiceTransaction in Model Driven approach
                  Ok, so far so good, but in my original code, I am using dtx.setSendChangesToAdapter(true) and expect that the createIte
                  m() would be persisted to the database. Is it not the case, while I see that the new item is sent to the client but it is not being written to the database.
