3 Replies Latest reply on Aug 24, 2011 12:12 PM by Marijan Tompa [tomaxxi]
    Can't set documentTitle to a blank string
    frameexpert Level 4
      I have a client that wants the documentTitle field to be blank for certain PDFs. If I go to File > File Info (in CS5.5) and delete the Document Title and export a PDF, everything is fine. However, if a Document Title is already set and I try to remove it with JavaScript, it doesn't work:
          doc.metadataPreferences.documentTitle = "";
      where doc is my document object. If I set it to any other string it works. I tried setting it to a space:
          doc.metadataPreferences.documentTitle = " ";
      but that doesn't work either. Any workarounds would be appreciated. Thank you very much.
      Rick Quatro
