0 Replies Latest reply on Aug 24, 2011 5:06 PM by nunnap2011
    Flash Builder 4.5 SOAP call for images using Base64 Encoding
    nunnap2011
      I am trying to load some image meta data in a flash builder mobile application by making a SOAP call to .Net service. I am able to test the web service successfully using a .Net console application. However when I make the call from flash builder mobile client I get a null result. What am I doing wrong? I am using SOAP 1.1 ByteArray didn't work for Flash builder. So converted the ByteArray to Base64 format and tried to obtain result that way. Both ways worked from a .Net Client but not working from Flash mobile.
      Here is the code
      <fx:Script>
              <![CDATA[
                  import mx.graphics.ImageSnapshot;
                  import mx.graphics.codec.JPEGEncoder;
                  import mx.graphics.codec.PNGEncoder;
                  import mx.rpc.AsyncToken;
                  import mx.utils.Base64Encoder;
                  import services.exifimagemetadata1.ExifImageMetaData1;
                  import spark.components.Image;
                  public var metaData:ExifImageMetaData1 = new ExifImageMetaData1();
                  public var imageBytes:ByteArray = new ByteArray();
                  public var gpsData:String;
          private function getBase64EncodedImage():String
                      var myEncoder:Base64Encoder = new Base64Encoder();
                      myEncoder.encodeBytes(getImageBytes());
                      var image64BitText:String = myEncoder.toString();
                      return image64BitText;
          public function GetMetaDataFromExif():void{
                      var imageToken:AsyncToken = metaData.GetExifBase64Data(getBase64EncodedImage());
                      gpsData = imageToken.result.toString();
                      metaResult.text = gpsData;
          protected function GetImageMetaDataFromExif(event:MouseEvent):void
                      GetMetaDataFromExif();
      </fx:Script>
      <s:layout>
      <s:VerticalLayout>
      </s:VerticalLayout>
      </s:layout>
      <s:HGroup>
      <s:Image id="test" width="130" height="140" source="@Embed(source='assets/p1000106.jpg')"/>
      </s:HGroup>
      <s:HGroup>
      <s:Label width="100" height="140" backgroundColor="Blue" click="GetImageMetaDataFromExif(event)">
      <s:text/>
      </s:Label>
      </s:HGroup>
      <s:HGroup>
      <s:Label id="metaResult" width="200" height="140" backgroundColor="yellow"/>
      </s:HGroup>
