1 Reply Latest reply on Aug 25, 2011 10:30 AM by Flex harUI
    Error #1034: Type Coercion failed: cannot convert components::mycustomitemrenderer@85fbc29 to mx.con
    Ananth Flex
      dear friends....
                          Error #1034: Type Coercion failed: cannot convert components::mycustomitemrenderer@85fbc29 to mx.controls.listClasses.IListItemRenderer.
      help me to add event listner to below mentioned classfactory object(obj)....
      this was the error i'm getting while using class factory;
      my coding
      var obj:ClassFactory=new ClassFactory(components.mycustomitemrenderer);//getting error here....
      var dg_column:DataGridColumn;
      if(qry_checklist_items.length>0)
      for(var i:int=0;i<qry_checklist_items.length;i++)
      dg_column=new DataGridColumn();
      dg_column.headerText=qry_checklist_items[i].wf_checklist_item_name;
      if(qry_checklist_items[i].wf_checklist_item_input_type!="static")
      dg_column.itemRenderer=obj;
      else
      dg_column.itemRenderer=lbl;
      if(qry_checklist_items[i].wf_checklist_item_default_sort_dir!=null)
      if(qry_checklist_items[i].wf_checklist_item_default_sort_dir=="asc")
      dg_column.sortDescending=false;
      dg_column.setStyle("color",0xFF0000);
      dg_column.sortable=true;
      else
      dg_column.sortDescending=true;
      //dg_column.setStyle(mystyle,0);
      col_arr.push(dg_column);
      dg_column.dataField="wf_checklist_result_header_notes"
      dg_column.headerText="Notes";
      //Txt_A.properties={mouseFocusChange:"submit"};
      dg_column.itemRenderer=Txt_A;
      and i wan to add event listner to the text box which is added dynalically and further i wan to add button and click event for that dynamically....
      is it possible?
