1 Reply Latest reply on Aug 25, 2011 9:30 AM by joe bloe premiere
    Premiere Cashes while opening files
    hajj616
      Need some help!
      I'm fairly new to Premiere. I've been working seemlessing on a project...had no issues saving or closing the project, but when I try to open any of my projects Premiere loads the project, brings up a white screen then crashes. Thanks in advance!!
      Here is the Problem Report:
      Process:         Adobe Premiere Pro CS5.5 [4282]
      Path:            /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
      Identifier:      com.adobe.AdobePremierePro
      Version:         5.5.0 (5.5.0)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [96]
      Date/Time:       2011-08-25 11:42:23.274 -0400
      OS Version:      Mac OS X 10.6.8 (10K549)
      Report Version:  6
      Interval Since Last Report:          594703 sec
      Crashes Since Last Report:           29
      Per-App Interval Since Last Report:  348464 sec
      Per-App Crashes Since Last Report:   21
      Anonymous UUID:                      F4094532-9A66-4A8D-B31A-1489425B0CA0
      Exception Type:  EXC_BREAKPOINT (SIGTRAP)
      Exception Codes: 0x0000000000000002, 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   com.apple.CoreFoundation      0x00007fff84351598 CFRetain + 200
      1   com.apple.CoreFoundation      0x00007fff8435acd5 __CFBasicHashAddValue + 53
      2   com.apple.CoreFoundation      0x00007fff8435ab5f CFBasicHashAddValue + 191
      3   com.apple.CoreFoundation      0x00007fff8435a977 CFDictionaryAddValue + 199
      4   com.adobe.dvaui.framework     0x000000010325216a dvaui::drawbot::CoreTextStringDisplayInterface::ResetString(dvaui::drawbot::FontInterface const&, dvaui::drawbot::BrushInterface const*, unsigned short const*, int, dvaui::drawbot::TextAlignment) + 170
      5   com.adobe.dvaui.framework     0x000000010325b1ed dvaui::drawbot::CoreTextFontInterface::MeasureStringWidth(unsigned short const*, int) const + 157
      6   com.adobe.dvaui.framework     0x000000010324b653 dvaui::drawbot::TruncateStringImpl(dvaui::drawbot::FontInterface const&, unsigned short const*, dvaui::drawbot::TextTruncation, float) + 195
      7   com.adobe.dvaui.framework     0x000000010324c5cc dvaui::drawbot::SurfaceInterface::DrawString(dvaui::drawbot::BrushInterface const&, dvaui::drawbot::FontInterface const&, unsigned short const*, dvacore::geom::PointT<float> const&, dvaui::drawbot::TextAlignment, dvaui::drawbot::TextTruncation, float) + 108
      8   ...adobe.UIFramework.framework 0x000000010388ff31 UIF::DC::DrawString(UIF::Font const&, ASL::ParamRect<int> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::ParamColor<RGBColor> const&, UIF::Align, UIF::VerticalAlignment, UIF::Truncate) + 561
      9   ...be.HandlerProject.framework 0x00000001092bad61 HandlerProject::StringColumn::Draw(UIF::DC&, ASL::InterfaceRef<BE::IProjectItem, BE::IProjectItem>, ASL::ParamRect<int> const&, UIF::GDIObjectID const&, bool, ASL::InterfaceRef<HandlerProject::ProjectViewState, BE::ISerializeable>) + 289
      10  ...be.HandlerProject.framework 0x00000001092257ba HandlerProject::ColumnSubview::DrawNode(UIF::DC&, HandlerProject::ProjectListTreeView&, ASL::InterfaceRef<HandlerProject::ProjectListViewNode, ASL::ASLUnknown>, __gnu_cxx::__normal_iterator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>*, std::vector<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>, std::allocator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown> > > >, __gnu_cxx::__normal_iterator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>*, std::vector<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>, std::allocator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown> > > >, int, unsigned int) + 858
      11  ...be.HandlerProject.framework 0x000000010922a720 HandlerProject::ColumnSubview::DrawProjectTree(UIF::DC&, ASL::ParamRect<int> const&, __gnu_cxx::__normal_iterator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>*, std::vector<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>, std::allocator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown> > > >, __gnu_cxx::__normal_iterator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>*, std::vector<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown>, std::allocator<ASL::InterfaceRef<HandlerProject::Column, ASL::ASLUnknown> > > >, ASL::ObjectPtr<std::list<ASL::InterfaceRef<HandlerProject::ProjectListViewNode, ASL::ASLUnknown>, std::allocator<ASL::InterfaceRef<HandlerProject::ProjectListViewNode, ASL::ASLUnknown> > >, ASL::AtomicValue>, unsigned int, int&) + 160
      12  ...be.HandlerProject.framework 0x000000010922f112 HandlerProject::ColumnSubview::PaintSelf(UIF::DC&) + 450
      13  ...adobe.UIFramework.framework 0x0000000103960aec UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 620
      14  com.adobe.dvaui.framework     0x0000000103297230 dvaui::ui::UI_Node::UI_DispatchDraw(dvaui::drawbot::Drawbot*) const + 112
      15  com.adobe.dvaui.framework     0x00000001032973fb dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 187
      16  com.adobe.dvaui.framework     0x000000010329781d dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 813
      17  com.adobe.dvaui.framework     0x00000001032980ff dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 447
      18  com.adobe.dvaui.framework     0x0000000103298152 dvaui::ui::UI_Node::UI_DispatchDrawToChildren(dvaui::drawbot::Drawbot*) const + 50
      19  ...adobe.UIFramework.framework 0x0000000103960af7 UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 631
      20  com.adobe.dvaui.framework     0x0000000103297230 dvaui::ui::UI_Node::UI_DispatchDraw(dvaui::drawbot::Drawbot*) const + 112
      21  com.adobe.dvaui.framework     0x00000001032973fb dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 187
      22  com.adobe.dvaui.framework     0x000000010329781d dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 813
      23  com.adobe.dvaui.framework     0x00000001032980ff dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 447
      24  com.adobe.dvaui.framework     0x0000000103298152 dvaui::ui::UI_Node::UI_DispatchDrawToChildren(dvaui::drawbot::Drawbot*) const + 50
      25  ...adobe.UIFramework.framework 0x0000000103960af7 UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 631
      26  com.adobe.dvaui.framework     0x0000000103297230 dvaui::ui::UI_Node::UI_DispatchDraw(dvaui::drawbot::Drawbot*) const + 112
      27  com.adobe.dvaui.framework     0x00000001032973fb dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 187
      28  com.adobe.dvaui.framework     0x000000010329781d dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 813
      29  com.adobe.dvaui.framework     0x00000001032980ff dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 447
      30  com.adobe.dvaui.framework     0x0000000103298152 dvaui::ui::UI_Node::UI_DispatchDrawToChildren(dvaui::drawbot::Drawbot*) const + 50
      31  ...adobe.UIFramework.framework 0x0000000103960af7 UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 631
      32  com.adobe.dvaui.framework     0x0000000103297230 dvaui::ui::UI_Node::UI_DispatchDraw(dvaui::drawbot::Drawbot*) const + 112
      33  com.adobe.dvaui.framework     0x00000001032973fb dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 187
      34  com.adobe.dvaui.framework     0x000000010329781d dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 813
      35  com.adobe.dvaui.framework     0x00000001032980ff dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 447
      36  com.adobe.dvaui.framework     0x0000000103298152 dvaui::ui::UI_Node::UI_DispatchDrawToChildren(dvaui::drawbot::Drawbot*) const + 50
      37  ...adobe.UIFramework.framework 0x0000000103969a98 UIF::TabViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 744
      38  com.adobe.dvaui.framework     0x0000000103320cd4 dvaui::ui::OS_View::UI_HandlePlatformDrawEvent() + 1092
      39  com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
      40  com.adobe.dvacore.framework   0x000000010011cfd9 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 9
      41  com.adobe.premiere.frontend   0x000000010c775cae boost::function0<int>::operator()() const + 46
      42  com.adobe.premiere.frontend   0x000000010c775063 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 35
      43  com.adobe.dvacore.framework   0x000000010011bbf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
      44  com.adobe.dvacore.framework   0x000000010011e773 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
      45  com.adobe.dvaui.framework     0x0000000103314a9a -[DVAMacContainerView drawRect:] + 186
      46  com.apple.AppKit              0x00007fff87d06cc5 -[NSView _drawRect:clip:] + 3390
      47  com.apple.AppKit              0x00007fff87d05938 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1325
      48  com.apple.AppKit              0x00007fff87d05ca2 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2199
      49  com.apple.AppKit              0x00007fff87d05ca2 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2199
      50  com.apple.AppKit              0x00007fff87d05ca2 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2199
      51  com.apple.AppKit              0x00007fff87d0400a -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 767
      52  com.apple.AppKit              0x00007fff87d03b2c -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 254
      53  com.apple.AppKit              0x00007fff87d003de -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2683
      54  com.apple.AppKit              0x00007fff87c79c0e -[NSView displayIfNeeded] + 969
      55  com.apple.AppKit              0x00007fff87c41c3b -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 1050
      56  com.apple.AppKit              0x00007fff87c417d2 -[NSWindow orderWindow:relativeTo:] + 94
      57  com.apple.AppKit              0x00007fff87c3f154 -[NSWindow makeKeyAndOrderFront:] + 46
      58  com.adobe.dvaui.framework     0x000000010330ccbe dvaui::ui::OS_Window::UI_Show(bool) + 350
      59  ...dobe.dvaworkspace.framework 0x0000000106c1ebf7 dvaworkspace::ser_impl::ReadTopLevelWindow(dvaworkspace::workspace::TopLevelWindow*, dvacore::proplist::PropList const*, std::list<boost::intrusive_ptr<dvaworkspace::workspace::TabPanel>, std::allocator<boost::intrusive_ptr<dvaworkspace::workspace::TabPanel> > >&, bool, bool, bool) + 951
      60  ...dobe.dvaworkspace.framework 0x0000000106c1fa3c dvaworkspace::workspace::RestoreWorkspace(dvaworkspace::workspace::Workspace&, dvacore::proplist::PropList const&, bool, bool, bool) + 1900
      61  ...dobe.dvaworkspace.framework 0x0000000106c26a57 dvaworkspace::workspace::ManagerBase::AddWorkspace(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::proplist::PropList&, bool) + 183
      62  com.adobe.premiere.frontend   0x000000010c74cac9 FE::Application::InstallWorkspace(ASL::InterfaceRef<BE::IWorkspaceSettings, BE::IWorkspaceSettings>) + 217
      63  com.adobe.premiere.frontend   0x000000010c7959da FE::DocumentManager::OpenDocument(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 6666
      64  com.adobe.premiere.frontend   0x000000010c7bd29d -[PremiereCocoaMacApplicationDelegate openFiles:] + 1165
      65  com.adobe.premiere.frontend   0x000000010c7bb7c4 -[PremiereCocoaMacApplicationDelegate application:openFiles:] + 20
      66  com.apple.AppKit              0x00007fff87e78b52 -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 505
      67  com.apple.AppKit              0x00007fff87d45065 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 217
      68  com.apple.Foundation          0x00007fff8866c1c6 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 360
      69  com.apple.Foundation          0x00007fff8866bff6 _NSAppleEventManagerGenericHandler + 114
      70  com.apple.AE                  0x00007fff8148232b aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 162
      71  com.apple.AE                  0x00007fff81482224 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 32
      72  com.apple.AE                  0x00007fff8148212b aeProcessAppleEvent + 210
      73  com.apple.HIToolbox           0x00007fff83ea6619 AEProcessAppleEvent + 48
      74  com.apple.AppKit              0x00007fff87c4a095 _DPSNextEvent + 1191
      75  com.apple.AppKit              0x00007fff87c49801 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
      76  com.apple.AppKit              0x00007fff87c0f68f -[NSApplication run] + 395
      77  com.adobe.premiere.frontend   0x000000010c7bbaa4 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 164
      78  com.adobe.premiere.frontend   0x000000010c7691a7 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2503
      79  com.adobe.premiere.frontend   0x000000010c7bec1d AppMain + 253
      80  com.adobe.premiere.startup    0x000000010c93c3e8 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 232
      81  com.adobe.AdobePremierePro    0x0000000100003540 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 288
      82  com.adobe.AdobePremierePro    0x0000000100003ac7 main + 167
      83  com.adobe.AdobePremierePro    0x00000001000033a8 start + 52
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x00007fff8502bc0a kevent + 10
      1   libSystem.B.dylib             0x00007fff8502dadd _dispatch_mgr_invoke + 154
      2   libSystem.B.dylib             0x00007fff8502d7b4 _dispatch_queue_invoke + 185
      3   libSystem.B.dylib             0x00007fff8502d2de _dispatch_worker_thread2 + 252
      4   libSystem.B.dylib             0x00007fff8502cc08 _pthread_wqthread + 353
      5   libSystem.B.dylib             0x00007fff8502caa5 start_wqthread + 13
      Thread 2:
      0   libSystem.B.dylib             0x00007fff8502ca2a __workq_kernreturn + 10
      1   libSystem.B.dylib             0x00007fff8502ce3c _pthread_wqthread + 917
      2   libSystem.B.dylib             0x00007fff8502caa5 start_wqthread + 13
      Thread 3:
      0   libSystem.B.dylib             0x00007fff8504da6a __semwait_signal + 10
      1   libSystem.B.dylib             0x00007fff85051881 _pthread_cond_wait + 1286
      2   com.adobe.amt.services        0x000000010f708247 C_AMTUISwitchSuppressUpdates + 16439
      3   com.adobe.amt.services        0x000000010f70139e C_EULA_SetState + 1742
      4   com.adobe.amt.services        0x000000010f7082b2 C_AMTUISwitchSuppressUpdates + 16546
      5   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      6   libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 4:
      2   ...ple.CoreServices.CarbonCore 0x00007fff82c8dd87 TSWaitOnCondition + 118
      3   ...ple.CoreServices.CarbonCore 0x00007fff82bfcff8 TSWaitOnConditionTimedRelative + 177
      4   ...ple.CoreServices.CarbonCore 0x00007fff82bf6efb MPWaitOnQueue + 215
      5   ...obe.ASLFoundation.framework 0x00000001004a6450 ASL::(anonymous namespace)::TaskProc(void*) + 96
      6   ...ple.CoreServices.CarbonCore 0x00007fff82bcf0d1 PrivateMPEntryPoint + 63
      7   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      8   libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 5:
      Thread 6:
      5   com.adobe.dvacore.framework   0x000000010018e2bf dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      6   com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
      7   com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      8   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
      9   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      10  libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 7:
      Thread 8:
      1   ...dobe.dvatransport.framework 0x000000010069896e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
      2   ...dobe.dvatransport.framework 0x0000000100699a25 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
      3   ...dobe.dvatransport.framework 0x0000000100676abc SkyConnectionEnv::MainLoop() + 76
      4   ...dobe.dvatransport.framework 0x0000000100676b29 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
      6   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      7   libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 9:
      2   ...dobe.dvatransport.framework 0x0000000100699b5f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
      3   ...dobe.dvatransport.framework 0x000000010069a755 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
      4   ...dobe.dvatransport.framework 0x000000010067f6a9 asio_detail_posix_thread_function + 25
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      0   libSystem.B.dylib             0x00007fff85012d7a mach_msg_trap + 10
      1   libSystem.B.dylib             0x00007fff850133ed mach_msg + 59
      2   com.apple.CoreFoundation      0x00007fff84397932 __CFRunLoopRun + 1698
      3   com.apple.CoreFoundation      0x00007fff84396dbf CFRunLoopRunSpecific + 575
      4   com.apple.audio.CoreAudio     0x00007fff8543e786 HALRunLoop::OwnThread(void*) + 152
      5   com.apple.audio.CoreAudio     0x00007fff8542b755 CAPThread::Entry(CAPThread*) + 125
      Thread 16:
      Thread 17:
      Thread 18:
      4   com.apple.CoreFoundation      0x00007fff84396b46 CFRunLoopRun + 70
      5   com.adobe.dvacore.framework   0x0000000100178c59 dvacore::threads::RunPlatformEventLoop() + 89
      6   com.adobe.dvacore.framework   0x000000010017e831 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 177
      7   com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
      8   com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      9   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
      10  libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      11  libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 19:
      1   libSystem.B.dylib             0x00007fff8504d8f9 nanosleep + 148
      2   ...e.ScriptLayerPPro.framework 0x0000000106e7c8ab ScObjects::Thread::sleep(unsigned int) + 59
      3   ...e.ScriptLayerPPro.framework 0x0000000106e67403 ScObjects::BridgeTalkThread::run() + 163
      4   ...e.ScriptLayerPPro.framework 0x0000000106e7c9a6 ScObjects::Thread::go(void*) + 166
      Thread 20:
      0   libSystem.B.dylib             0x00007fff85056956 recvfrom + 10
      1   ServiceManager-Launcher.dylib 0x0000000127bc5562 Invoke + 54020
      2   ServiceManager-Launcher.dylib 0x0000000127bc46bf Invoke + 50273
      3   ServiceManager-Launcher.dylib 0x0000000127bc3706 Invoke + 46248
      4   ServiceManager-Launcher.dylib 0x0000000127bc3761 Invoke + 46339
      5   ServiceManager-Launcher.dylib 0x0000000127bc37e2 Invoke + 46468
      6   ServiceManager-Launcher.dylib 0x0000000127bbdeed Invoke + 23695
      7   ServiceManager-Launcher.dylib 0x0000000127bbe086 Invoke + 24104
      8   ServiceManager-Launcher.dylib 0x0000000127bbeb0f Invoke + 26801
      9   ServiceManager-Launcher.dylib 0x0000000127bbebfd Invoke + 27039
      10  ServiceManager-Launcher.dylib 0x0000000127bc1eff Invoke + 40097
      11  ServiceManager-Launcher.dylib 0x0000000127bc21a5 Invoke + 40775
      12  ServiceManager-Launcher.dylib 0x0000000127bc2764 Invoke + 42246
      13  ServiceManager-Launcher.dylib 0x0000000127bc2951 Invoke + 42739
      14  ServiceManager-Launcher.dylib 0x0000000127bb467f Login + 1773
      15  ServiceManager-Launcher.dylib 0x0000000127bb5d01 Login + 7535
      16  ServiceManager-Launcher.dylib 0x0000000127bc2e88 Invoke + 44074
      17  ServiceManager-Launcher.dylib 0x0000000127bc52a1 Invoke + 53315
      18  libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      19  libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 21:
      0   libSystem.B.dylib             0x00007fff85012dda semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x00007fff85051772 _pthread_cond_wait + 1015
      2   ...ple.CoreServices.CarbonCore 0x00007fff82bfd018 TSWaitOnConditionTimedRelative + 209
      3   ...ple.CoreServices.CarbonCore 0x00007fff82bf6efb MPWaitOnQueue + 215
      4   com.adobe.dvacore.framework   0x000000010018e2bf dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      5   com.adobe.dvacore.framework   0x000000010011e4b6 boost::function0<void>::operator()() const + 38
      6   com.adobe.dvacore.framework   0x00000001001866a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      7   ...obe.boost_threads.framework 0x00000001000be744 thread_proxy + 132
      Thread 22:
      2   ...ple.CoreServices.CarbonCore 0x00007fff82c8b4df TS_exception_listener_thread + 126
      3   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      4   libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 23:
      Thread 24:
      Thread 25:
      1   ...e.MediaFoundation.framework 0x0000000100bc356c MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 428
      2   libSystem.B.dylib             0x00007fff8504bfd6 _pthread_start + 331
      3   libSystem.B.dylib             0x00007fff8504be89 thread_start + 13
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x00007fff8436d2a6  rbx: 0x0000000000000000  rcx: 0x0000000000000000  rdx: 0x00007fff8436d244
        rdi: 0x0000000000000000  rsi: 0x000000000000000a  rbp: 0x00007fff5fbf9e50  rsp: 0x00007fff5fbf9e40
         r8: 0x0000000000000000   r9: 0x000000010343e6b0  r10: 0x00007fff700258d0  r11: 0x000000012fb4b200
        r12: 0x000000012fb4b200  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x0000000000000000
        rip: 0x00007fff84351598  rfl: 0x0000000000000246  cr2: 0x0000000100123630
      Binary Images:
             0x100000000 -        0x100003fff +com.adobe.AdobePremierePro 5.5.0 (5.5.0) <2DAF1480-B633-192E-D640-5498244937DC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/MacOS/Adobe Premiere Pro CS5.5
             0x100008000 -        0x10000dffd +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <5625AF72-323C-27C5-0094-213D09698D11> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x100011000 -        0x100083ff7 +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <E604CBB8-A3F0-69D1-510B-3D8156D37D29> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10009a000 -        0x1000a1fff +com.adobe.boost_date_time.framework boost_date_time version 5.5.0 (5.5.0.233) <575000B6-FC00-DBF0-75B4-9406D5EE1ADF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x1000bc000 -        0x1000c4ff7 +com.adobe.boost_threads.framework boost_threads version 5.5.0 (5.5.0.233) <9BFFD349-156E-69D5-C0EF-954FEE1C0706> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x1000da000 -        0x100268fe7 +com.adobe.dvacore.framework dvacore version 5.5.0 (5.5.0.233) <13CC32EF-EB9D-AEC6-F42A-0858A5E30234> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x100419000 -        0x10043afef +com.adobe.dvamediatypes.framework dvamediatypes version 5.5.0 (5.5.0.233) <BA3B2A94-959B-6D5A-870A-36C4CDF0E3F9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x100465000 -        0x100466fff +com.adobe.PRM.framework PRM version 5.5.0 (5.5.0.0) <AD3E526D-FB0F-4C09-837C-0B61984BCEF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x10046c000 -        0x1004d3ff7 +com.adobe.ASLFoundation.framework ASLFoundation version 5.5.0 (5.5.0.0) <84C8706F-621E-5633-6DC7-09517E8CE7D3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x1005d2000 -        0x1005e8fff +com.adobe.ASLMessaging.framework ASLMessaging version 5.5.0 (5.5.0.0) <394C6ED9-ADDE-663D-4E2A-CA030DFC99AE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x10060d000 -        0x10060efff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <D9747273-37A6-4D7B-A28F-CDDC14CADF14> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x100615000 -        0x100627ff7 +com.adobe.ASLUnitTesting.framework ASLUnitTesting version 5.5.0 (5.5.0.0) <02CAA5AF-EC36-3E87-243D-2592FC36D3CD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x100645000 -        0x100646fff +com.adobe.boost_system.framework boost_system version 5.5.0 (5.5.0.233) <8D01B0C5-1D9A-114A-996A-9683400D4987> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x10064f000 -        0x1006c7fff +com.adobe.dvatransport.framework dvatransport version 5.5.0 (5.5.0.233) <0B9D3E2F-4F4D-695E-B219-57A67E5EEA49> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x10075f000 -        0x10079ffff +com.adobe.dvamarshal.framework dvamarshal version 5.5.0 (5.5.0.233) <A946A5E7-FE0D-264F-F7A8-270ABD744D50> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x10083c000 -        0x100a2cfe7 +com.adobe.dynamiclink.framework dynamiclink version 5.5.0 (5.5.0.233) <2AA1175D-0572-242A-98ED-8B4153F4A7E1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x100baa000 -        0x100be9fe7 +com.adobe.MediaFoundation.framework MediaFoundation version 5.5.0 (5.5.0.0) <7A20BCB7-0D45-A0E6-7D8E-8583E3D97386> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x100c48000 -        0x100cc6fe7 +com.adobe.AudioRenderer.framework AudioRenderer version 5.5.0 (5.5.0.0) <24E78936-3C2E-607C-668C-631287050D8B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x100d78000 -        0x100da2fff +com.adobe.dvacaptioning.framework dvacaptioning version 5.5.0 (5.5.0.233) <D353C687-8E04-6800-7924-FBFF73E71C40> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
             0x100dd0000 -        0x10190bfe7 +com.adobe.Backend.framework Backend version 5.5.0 (5.5.0.0) <A1A3642F-319E-1431-AEA7-60582C6DFCAB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x102818000 -        0x1029e8fe7 +com.adobe.ImageRenderer.framework ImageRenderer version 5.5.0 (5.5.0.0) <4CED009C-05FA-164F-5A10-4729B727B40B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x102af1000 -        0x102b32ff7 +com.adobe.MLFoundation.framework MLFoundation version 5.5.0 (5.5.0.0) <16822B47-71BB-4FFF-403D-7F14E56DFDAB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x102b98000 -        0x102bf3ff7 +com.adobe.VideoFrame.framework VideoFrame version 5.5.0 (5.5.0.0) <291C329E-02B3-CD6F-C892-04028E456556> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x102c75000 -        0x102cafff7 +com.adobe.PluginSupport.framework PluginSupport version 5.5.0 (5.5.0.0) <E3EFEC9F-1610-7313-8F5D-190C39EDD9FD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x102cff000 -        0x102d3ffff +com.adobe.SweetPeaSupport.framework SweetPeaSupport version 5.5.0 (5.5.0.0) <7EF8F6EB-9AA8-D321-674B-67A6DCEC55FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x102da0000 -        0x102de2ff7 +com.adobe.AudioSupport.framework AudioSupport version 5.5.0 (5.5.0.0) <B9FD71E8-C2E9-D623-B0CB-7E70267912D9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x102e36000 -        0x102e39ff7 +com.adobe.MediaUtils.framework MediaUtils version 5.5.0 (5.5.0.0) <00B41115-09AE-8B82-7E39-319E5E46D357> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x102e40000 -        0x102e5dff7 +com.adobe.AudioFilterHost.framework AudioFilterHost version 5.5.0 (5.5.0.0) <8ED1DD51-2219-327B-BC5C-EE4F26C4709A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x102e8d000 -        0x102eebffd +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <37A7128D-857A-F1CF-A00D-497983A42017> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x102efb000 -        0x102f9ffef +com.adobe.AdobeXMPFiles Adobe XMP Files 5.2 -f 17 (61.141987) <C504760D-5727-CC17-08BD-74688712F2C4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x102fd2000 -        0x10300bfef +com.adobe.AudioFilters.framework AudioFilters version 5.5.0 (5.5.0.0) <BDD4D962-A84F-CDE6-16BC-537132DDCF50> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x103085000 -        0x103091ff7 +com.adobe.boost_signals.framework boost_signals version 5.5.0 (5.5.0.233) <80163CD8-3F67-4877-1CE4-CBE99E3160F7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x1030aa000 -        0x10340ffef +com.adobe.dvaui.framework dvaui version 5.5.0 (5.5.0.233) <0565C197-3CF1-EFD3-3316-A65B8A574AF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x103831000 -        0x103ae0fff +com.adobe.UIFramework.framework UIFramework version 5.5.0 (5.5.0.233) <47121FC6-287C-9636-2D58-5144C691716B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
             0x103ece000 -        0x103ffafff +com.adobe.VideoRenderer.framework VideoRenderer version 5.5.0 (5.5.0.0) <5354E859-1C3A-A80D-8DF0-58E3357460E9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x104195000 -        0x104366fff +com.adobe.ImporterHost.framework ImporterHost version 5.5.0 (5.5.0.0) <C0070B85-AD71-DB00-31B4-4E7F94314A53> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x104592000 -        0x10465fff7 +com.adobe.ExporterHost.framework ExporterHost version 5.5.0 (5.5.0.0) <9134EAAC-FA20-3B98-ABF7-D90F6A801215> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x10479e000 -        0x104821fff +com.adobe.PlayerHost.framework PlayerHost version 5.5.0 (5.5.0.0) <2913DCA7-2A38-0D9A-C54B-30FF66DFFFCE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x1048e4000 -        0x104956ff7 +com.adobe.RecorderHost.framework RecorderHost version 5.5.0 (5.5.0.0) <1B0C1090-5865-9400-7E03-C8F060F25B54> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
             0x1049ee000 -        0x1049fdff7 +com.adobe.ProjectConverterHost.framework ProjectConverterHost version 5.5.0 (5.5.0.0) <F540E650-57F6-DA03-74AE-5AA1684F2811> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterH ost
             0x104a15000 -        0x104aeffff +com.adobe.VideoFilterHost.framework VideoFilterHost version 5.5.0 (5.5.0.0) <EB7740FF-3A76-9532-92F2-D10DF0A677C9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x104bcb000 -        0x104bdaff7 +com.adobe.ProjectSupport.framework ProjectSupport version 5.5.0 (5.5.0.0) <615322FC-88BF-E5BF-E4A7-29FA5390AA1F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x104bf3000 -        0x104c0bff7 +com.adobe.AMEAppFoundation.framework AMEAppFoundation version 5.5.0 (5.5.0.0) <D0DFB126-503D-2B37-D474-2142C9F82CE4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x104c35000 -        0x104c58fff +com.adobe.PostEncodeHost.framework PostEncodeHost version 5.5.0 (5.5.0.0) <739DE9CD-A999-E201-C4C4-7476ABA7C535> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
             0x104c8d000 -        0x104cccff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.5.0 (5.5.0.233) <360ED464-77B2-BE6D-6929-51DBC5379518> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x104ce8000 -        0x104d05fff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6819BA1B-DF86-5EE8-C777-4E011D616A39> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x104d10000 -        0x104db0fef +com.adobe.AdobeScCore ScCore 4.1.28 (4.1.28.13048) <83CA2291-5B56-AB69-AF81-A1FBD64AA937> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x104df9000 -        0x104e9dffb +com.adobe.AdobeExtendScript ExtendScript 4.1.28 (4.1.28.13048) <3022B3E5-07EC-A68B-5E75-41996620745F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x104f02000 -        0x104f59fff +com.adobe.BravoInitializer.framework BravoInitializer version 5.5.0 (5.5.0.0) <07C40DB8-B9AA-F6C7-6594-B8C5ABD27D43> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
             0x104fde000 -        0x10511cff7 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <50F24A33-D8E9-5F39-22C8-75B097EE97B8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x105146000 -        0x105490fe7 +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <085E87D9-3079-EA53-25DC-85800CCBB0DF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x105569000 -        0x10589afe7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <C36D0E60-9ACD-1302-CBDC-07722DD97DE9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x10593c000 -        0x1059ffff7 +com.adobe.AMEWrapper.framework AMEWrapper version 5.5.0 (5.5.0.0) <3E1C898E-A5CA-631E-04D1-254B7485D790> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
             0x105ad5000 -        0x105beefff +com.adobe.EncoderHost.framework EncoderHost version 5.5.0 (5.5.0.0) <A7CD8C66-0392-711D-DEF2-58FBA614784F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x105d10000 -        0x105da7ff7 +com.adobe.MBCProvider.framework MBCProvider version 5.5.0 (5.5.0.233) <300CD412-82B9-5CAE-D7F4-13E92E0D75E7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
             0x105e41000 -        0x10653afff +com.adobe.Mezzanine.framework Mezzanine version 5.5.0 (5.5.0.233) <3EDBE5B6-F6F4-F610-3C77-688DB69C2EA6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
             0x106b88000 -        0x106b99ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <AD464E16-20D1-A4FC-878D-CF44322F72BC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x106ba6000 -        0x106c5bff7 +com.adobe.dvaworkspace.framework dvaworkspace version 5.5.0 (5.5.0.233) <80D3EE09-5D72-E780-CA49-E8E47D07A30E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x106d58000 -        0x106ee7fff +com.adobe.ScriptLayerPPro.framework ScriptLayerPPro version 5.5.0 (5.5.0.233) <30A28312-6604-37F8-C434-F7B8654C645E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
             0x107127000 -        0x1071fefe7 +com.adobe.dvaeve.framework dvaeve version 5.5.0 (5.5.0.233) <61FA5D63-DB8B-8D0F-9B96-7D70451B46F0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x10735c000 -        0x1073d8ff7 +com.adobe.MediaCoreUI.framework MediaCoreUI version 5.5.0 (5.5.0.0) <160AAABC-2145-6A08-69FC-46E4E13515AA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x107460000 -        0x107657ff7 +com.adobe.SettingsUI.framework SettingsUI version 5.5.0 (5.5.0.0) <4D18628F-3FCB-7382-8171-0A24D7BD43D3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x1078f3000 -        0x107a72fef +com.adobe.HSL.framework HSL version 5.5.0 (5.5.0.233) <C0DC5FA7-4CFD-ED51-5C06-9B62FCFEA22E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
             0x107c56000 -        0x107fe0fff +com.adobe.Dialogs.framework Dialogs version 5.5.0 (5.5.0.233) <3CB7833A-9B3F-612E-8357-52CBF42B9F84> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
             0x108369000 -        0x108379fff +com.adobe.HandlerAudioMiniMixer.framework HandlerAudioMiniMixer version 5.5.0 (5.5.0.233) <F1B6A9AE-6F31-C517-6EC2-DA704FB51AB5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMini Mixer
             0x10839e000 -        0x108437fff +com.adobe.HandlerAudioMixer.framework HandlerAudioMixer version 5.5.0 (5.5.0.233) <27A0308A-099E-59C9-27FF-6EDE9C4B2849> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
             0x10850e000 -        0x1085a3fff +com.adobe.HandlerCapture.framework HandlerCapture version 5.5.0 (5.5.0.233) <04CB52A5-B067-29EB-D899-88D036D19F13> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
             0x10867c000 -        0x108697ff7 +com.adobe.HandlerCSXS.framework HandlerCSXS version 5.5.0 (5.5.0.233) <3D4E335B-368B-056D-0C77-5EA1E89D43DB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
             0x1086d4000 -        0x108908fff +com.adobe.HandlerEffectControls.framework HandlerEffectControls version 5.5.0 (5.5.0.233) <FA9EA28F-A97E-62D2-4D90-C32532F47FB2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCon trols
             0x108b71000 -        0x108bd5fff +com.adobe.HandlerEffects.framework HandlerEffects version 5.5.0 (5.5.0.233) <F4C48E7E-0FEB-BF62-F4EA-376F2F6E84BA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
             0x108c50000 -        0x108c5cfff +com.adobe.HandlerEvents.framework HandlerEvents version 5.5.0 (5.5.0.233) <6C5CD2F7-C5F1-185A-AB9D-A4F85A222B2E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
             0x108c82000 -        0x108c93fff +com.adobe.HandlerGetProperties.framework HandlerGetProperties version 5.5.0 (5.5.0.233) <00E99DDE-3999-2A5A-FC44-78A39FB4467A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetPropert ies
             0x108cb5000 -        0x108cccff7 +com.adobe.HandlerHistory.framework HandlerHistory version 5.5.0 (5.5.0.233) <103A398D-8CF1-C0A0-26BD-2F0E163A6660> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
             0x108cfa000 -        0x108d44ff7 +com.adobe.HandlerInfo.framework HandlerInfo version 5.5.0 (5.5.0.233) <A6A76324-8EA0-9D14-408F-B46015DC6A23> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
             0x108dab000 -        0x108e04ff7 +com.adobe.HandlerMetadataEditor.framework HandlerMetadataEditor version 5.5.0 (5.5.0.233) <CBF125AE-629E-29A1-AEF3-BC2EC22C8EEA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataE ditor
             0x108ea4000 -        0x108f08ff7 +com.adobe.HandlerMediaBrowser.framework HandlerMediaBrowser version 5.5.0 (5.5.0.233) <006A5852-D72A-5D60-5AC2-19405B0103C2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowse r
             0x108fa3000 -        0x108fc7ff7 +com.adobe.HandlerMulticam.framework HandlerMulticam version 5.5.0 (5.5.0.233) <44E01CE5-8095-39E6-11B1-84CAD5EA0912> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/HandlerMulticam
             0x10900c000 -        0x10909fff7 +com.adobe.HandlerProgramMonitor.framework HandlerProgramMonitor version 5.5.0 (5.5.0.233) <3C56A9C7-6F7A-5A03-040E-427DD5A8251B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMo nitor
             0x109188000 -        0x10933dff7 +com.adobe.HandlerProject.framework HandlerProject version 5.5.0 (5.5.0.233) <A3A857E5-38B2-90D6-976D-39942D2AF282> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
             0x109561000 -        0x109653ff7 +com.adobe.HandlerSourceMonitor.framework HandlerSourceMonitor version 5.5.0 (5.5.0.233) <F77BFAB1-B451-5867-351E-227B56DF9971> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMoni tor
             0x10976a000 -        0x109961ff7 +com.adobe.HandlerTimeline.framework HandlerTimeline version 5.5.0 (5.5.0.233) <2566D6F0-B97D-0DBF-F1CB-DFB59A51ADDB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
             0x109b89000 -        0x109bf0ff7 +com.adobe.FontEngine.framework FontEngine version 5.5.0 (5.5.0.233) <5653082D-C8EC-6814-B95B-EA31F22C5BA8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
             0x109c8f000 -        0x109cbffff +com.adobe.TitleLayer.framework TitleLayer version 5.5.0 (5.5.0.233) <9A824CAE-2AD4-951B-5153-FBBA99334C5C> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
             0x109e71000 -        0x109e7ffe7 +com.adobe.TitleImageManager.framework TitleImageManager version 5.5.0 (5.5.0.233) <18A87CD0-8F6D-D144-5396-2079BD83B2BF> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
             0x109e9b000 -        0x109f3cff7 +com.adobe.TitleCharacterFactory.framework TitleCharacterFactory version 5.5.0 (5.5.0.233) <CD346A2C-4445-81B3-8358-D32D62014C58> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFa ctory
             0x109fa7000 -        0x10a0d7fef +com.adobe.TitleCG.framework TitleCG version 5.5.0 (5.5.0.233) <268CE1D6-CC83-ABE8-3512-D975185B6495> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
             0x10a1b8000 -        0x10a52bff7 +com.adobe.TitleLayout.framework TitleLayout version 5.5.0 (5.5.0.233) <0B2E5685-EB52-304A-1F99-79B238F7D3A8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
             0x10ac86000 -        0x10ad03fff +com.adobe.TitleRenderer.framework TitleRenderer version 5.5.0 (5.5.0.233) <59A508B7-246B-9A4A-2134-32D49944F5EB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
             0x10adcf000 -        0x10b61ffef +com.adobe.premiere.HandlerTitler 1.0 (1.0) <E42EDE8F-0043-42EF-DC49-B92826A273B8> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
             0x10c12f000 -        0x10c272fef +WRServices ??? (???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10c2be000 -        0x10c2eeff7 +com.adobe.HandlerTools.framework HandlerTools version 5.5.0 (5.5.0.233) <F696F050-A0F8-E24F-8399-113D07FE76EE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
             0x10c38e000 -        0x10c3cdfff +com.adobe.HandlerTrim.framework HandlerTrim version 5.5.0 (5.5.0.233) <6606604C-4939-7757-017C-137198942A28> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerTrim
             0x10c430000 -        0x10c43fff7 +com.adobe.HandlerVSTEditor.framework HandlerVSTEditor version 5.5.0 (5.5.0.233) <8D9DE50E-CAE8-F4E9-0B2A-606D7BE7B7FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/HandlerVSTEditor
             0x10c462000 -        0x10c47dfff +com.adobe.CSXSManager.framework CSXSManager version 5.5.0 (5.5.0.233) <53573694-8690-6DB0-3723-2BCDBA05E5F2> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
             0x10c4a5000 -        0x10c642fff +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <09F6FBA4-E768-BDFB-35AE-C7EB8EBA2D1A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
             0x10c6f0000 -        0x10c715fff +com.adobe.PrRegistration.framework PrRegistration version 5.5.0 (5.5.0.233) <04E2D249-FB99-72D0-7E7F-FEEA3F838391> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
             0x10c735000 -        0x10c810fff +com.adobe.premiere.frontend 1.0 (1.0) <E680FB53-18A0-A451-CC31-D822D801C2FD> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
             0x10c935000 -        0x10c956fff +com.adobe.premiere.startup 1.0 (1.0) <C3D52AF2-DC03-DA59-C18C-4EE4297E87FA> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
             0x10c972000 -        0x10ca58fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
             0x10cab0000 -        0x10cd88fe6 +libxerces-c-3.0.dylib ??? (???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x10cf02000 -        0x10cf29ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.40804) <AC47EA6A-1549-A7DA-EDF8-ABE11C38D179> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/mc_enc_dv.framework/Versions/8.5/mc_enc_dv
             0x10cf3d000 -        0x10cf3dff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
             0x10cf40000 -        0x10cf96fff +com.adobe.GPUFoundation.framework GPUFoundation version 5.5.0 (5.5.0.0) <9813E17D-CC20-4054-C41C-0270CDF8F21F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
             0x10d0f4000 -        0x10d1aafff +com.adobe.exo.framework exo version 5.5.0 (5.5.0.233) <D3E299AD-5454-F010-8474-07477382A092> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x10d2d8000 -        0x10d327fff +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.5.0 (5.5.0.233) <251CF852-5711-300B-310D-D9E8B22E1BF5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x10d39f000 -        0x10d3cbff7 +com.adobe.amefoundation.framework amefoundation version 5.5.0 (5.5.0.0) <AD58F2FB-D65B-9EA0-4CD0-8FD87E594524> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
             0x10d415000 -        0x10d43ffff +com.adobe.ameproperties.framework ameproperties version 5.5.0 (5.5.0.0) <DB927F22-7B0D-8BB5-6CCD-E0AB802D2850> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
             0x10d492000 -        0x10d4b3fff +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <57E822F5-271D-A9EE-A92C-88C8835DCC68> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10d4c2000 -        0x10d4c8fff +com.adobe.AppServices.framework AppServices version 5.5.0 (5.5.0.0) <2C59D2D1-83C8-7936-04C9-49213A0DB39F> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
             0x10d4d6000 -        0x10d52efeb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <3CCEC733-BC2D-63D5-7DD6-FA2616C67B9E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x10d574000 -        0x10d57aff7  com.apple.agl 3.0.12 (AGL-3.0.12) <1AB34F57-2E8D-42FB-A484-5CCB928CA456> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x10d581000 -        0x10d5dcff7 +com.adobe.dvametadata.framework dvametadata version 5.5.0 (5.5.0.233) <93EBD415-0B36-8AA3-65A8-8F88EA5A2B08> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x10d669000 -        0x10d771ff7 +com.adobe.dvametadataDB.framework dvametadataDB version 5.5.0 (5.5.0.233) <E4C27C90-3DA3-D86D-84BD-C6BBA721E9DC> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
             0x10d7bd000 -        0x10d856ff7 +com.adobe.dvametadataUI.framework dvametadataUI version 5.5.0 (5.5.0.233) <5F774FE0-9337-452D-680D-F10FEF247087> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x10d901000 -        0x10d920ff7 +com.adobe.dvastoryparser.framework dvastoryparser version 5.5.0 (5.5.0.233) <58197FBF-A24E-CB32-F65F-4D4A94CD2250> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
             0x10d93e000 -        0x10d982fff +com.adobe.DynamicLinkMedia.framework DynamicLinkMedia version 5.5.0 (5.5.0.0) <33DD3195-BD13-EF42-9289-2C2C2CCC7D14> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x10da06000 -        0x10da6aff7 +com.adobe.QT32Client.framework QT32Client version 5.5.0 (5.5.0.0) <9DEACCB0-5BB0-0EEB-793F-C29BC5FDEAED> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x10daf1000 -        0x10dc5efe7 +com.adobe.Display.framework Display version 5.5.0 (5.5.0.0) <FAACC489-C954-154E-5F7E-CDC57F8B971A> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Display.framework/Versions/A/Display
             0x10df76000 -        0x10dfdbfff +aif_core ??? (???) <CCF73A5E-ED9B-5409-27FC-44E12098C191> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
             0x10dfff000 -        0x10e234ff7 +aif_ogl ??? (???) <3C8F8D5E-081D-F87A-AE75-2566681F3275> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
             0x10e34e000 -        0x10e36dfff +image_runtime ??? (???) <B3AC8DB1-4754-1FF6-098E-10DEC1C9F146> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
             0x10e392000 -        0x10e44ffef +com.diaquest.pro4.omf 1.0.0.1022 (1.0.0.1022) <C735F37D-4D03-1648-4A2E-F94E65070BD0> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
             0x10e477000 -        0x10e490feb +libtbb.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbb.dylib
             0x10e4a1000 -        0x10e4a7feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10e4ae000 -        0x10e4b2ff8 +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <09559AEB-61DE-8DE8-4315-BFA0A7D6394B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x10e4b7000 -        0x10e533ff7 +com.adobe.PProDynamicLinkServer.framework PProDynamicLinkServer version 5.5.0 (5.5.0.233) <3C9B3F90-D179-A09D-8474-1A38E192BBB6> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkS erver
             0x10e613000 -        0x10e61afff +com.adobe.dvacaptioningui.framework dvacaptioningui version 5.5.0 (5.5.0.233) <977BE5B5-125D-F563-4B30-1047A76CAF2E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
             0x10e6d7000 -        0x10e6dffff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
             0x10f183000 -        0x10f1a9fff  GLRendererFloat ??? (???) <490221DD-53D9-178E-3F31-3A4974D34DCD> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x10f6e4000 -        0x10f758ff3 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <1B6C37A0-570C-14D0-52A3-87C835F530BB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
             0x10f7f8000 -        0x10f7fafef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x120800000 -        0x120993fe7  GLEngine ??? (???) <53A8A7E8-4846-D236-F3D9-DA3F2AF686D8> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x1209c4000 -        0x120de0fff  com.apple.ATIRadeonX2000GLDriver 1.6.36 (6.3.6) <EBE273B9-6BF7-32B1-C5A2-2B3C85D776AA> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
             0x121e00000 -        0x121e78fef +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <7AAC7875-787B-A4BA-F319-2B4425511ED4> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x121f87000 -        0x121f8bfff  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <917E3DC8-E34D-B130-F61F-50808466E674> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
             0x121f90000 -        0x121f96ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <C35BDA60-35FC-4BE7-B378-DCC73D99E2C9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x122fe4000 -        0x122feafff +com.adobe.ExporterCoreAudio.framework ExporterCoreAudio version 5.5.0 (5.5.0.0) <60755676-3CCD-97F0-4AF4-29A122170694> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAu dio
             0x123ac5000 -        0x123ad4ff7 +com.adobe.PremiereFiltersMetaPlugin.framework PremiereFiltersMetaPlugin version 5.5.0 (5.5.0.0) <64AC313F-2B3A-3AD1-3544-23A3FA783004> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/Premiere FiltersMetaPlugin
             0x125ac6000 -        0x125ad8fe7 +com.adobe.TransitionsMetaPlugin.framework TransitionsMetaPlugin version 5.5.0 (5.5.0.0) <4F37A87D-2BC3-3955-5FBB-F42A2F5DD946> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsM etaPlugin
             0x12648e000 -        0x1264aafff +com.adobe.VXMLPresetReader.framework VXMLPresetReader version 5.5.0 (5.5.0.0) <2C11ABD2-D24F-223F-ED7F-833966A39708> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/VXMLPresetReader.framework/VXMLPresetReader
             0x1264e4000 -        0x126557fff +com.adobe.PlayerMediaCore.framework PlayerMediaCore version 5.5.0 (5.5.0.0) <43DD9C7A-61C7-2394-3EB1-0A8EEDF1C3C9> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
             0x1265d0000 -        0x126606ff7  com.apple.AVCVideoServices 1.0 (42) <542C7C48-9C21-33F9-FF51-ABFAEBE33B6E> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
             0x12663e000 -        0x12665ffef +com.adobe.AudioVideoIO.framework AudioVideoIO version 5.5.0 (5.5.0.0) <8B305308-47D6-3FB2-DB1F-9E958FE27560> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
             0x126731000 -        0x126740fef +com.adobe.AudioConverter.framework AudioConverter version 5.5.0 (5.5.0.0) <39E0D4E5-DCEF-3F03-1565-C4B0E16B9B10> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x126755000 -        0x12677cff7 +com.adobe.ExporterQuickTimeHost.framework ExporterQuickTimeHost version 5.5.0 (5.5.0.0) <D45F2F8A-D919-06FE-84BB-388F519EF872> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQu ickTimeHost
             0x1267b4000 -        0x1267cdfff +com.adobe.QTParser.framework QTParser version 5.5.0 (5.5.0.0) <679FD2AE-66ED-4D51-707F-D349C47869B5> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x127500000 -        0x1276f2ff7  com.apple.audio.codecs.Components 2.0.3 (2.0.3) <9C486CBC-47B6-6703-EE2A-34F28C1FE023> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x127763000 -        0x1277a8fff +com.adobe.ImporterQuickTime.framework ImporterQuickTime version 5.5.0 (5.5.0.0) <D134C964-8B10-12E8-BACB-21A43995E6EE> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickT ime
             0x1277f2000 -        0x1278d3fff +com.adobe.IPPMPEGDecoder.framework IPPMPEGDecoder version 5.5.0 (5.5.0.0) <298699E4-39BB-E81E-ACD5-F0AE69A33D7B> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/IPPMPEGDecoder.framework/IPPMPEGDecoder
             0x127b83000 -        0x127ba3ff7 +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <48D74CFC-E9C7-143A-F971-2C7F0ACF7602> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
             0x127bb2000 -        0x127bdafef +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <DBEE8529-7074-635B-2CAD-DF7BA597D909> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
             0x12881d000 -        0x128823fe7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <87272933-FB21-81D0-00E6-92BC3D7583FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
             0x12888c000 -        0x12888eff7 +com.adobe.Motion.framework Motion version 5.5.0 (5.5.0.0) <2D12B8CD-AAE0-74EB-29BD-5BA4CDFC60B1> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
             0x12cd6b000 -        0x12cd6dff7 +com.adobe.Opacity.framework Opacity version 5.5.0 (5.5.0.0) <E2236FBC-05A9-8496-3A9B-E04A7B3B2060> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
             0x12cdad000 -        0x12cdeffef +com.adobe.pip ??? (5.5.0.1265) <D81C0CE8-05D5-6072-E1CE-0EDD333D009D> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x12cfad000 -        0x12cfc5ff7 +com.adobe.ExporterMPEGPreview.framework ExporterMPEGPreview version 5.5.0 (5.5.0.0) <EC248166-E8C8-0F6E-8F33-7408514B1754> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEG Preview
             0x12da06000 -        0x12da15ffd +com.mainconcept.mc_enc_mpa 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mpa.framework/mc_enc_mpa
             0x12e800000 -        0x12e912fef +com.mainconcept.mc_enc_mp2v 8.6 (8.6.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_enc_mp2v.framework/mc_enc_mp2v
             0x12e967000 -        0x12ea3cff3 +com.mainconcept.mc_mux_mp2 8.5 (8.5.0.40804) /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Frameworks/PLibs/mc_mux_mp2.framework/mc_mux_mp2
             0x12f4e4000 -        0x12f4e5ff7 +com.adobe.PProAEFilter.Bevel_Edges ??? (1.0) <7507D0FD-FD6E-B46C-D738-39FF90D2C472> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
             0x12f4ec000 -        0x12f4edfff +com.adobe.PProAEFilter.Mosaic ??? (1.0) <B5B1AFB7-7947-747D-0352-1D57909982FB> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
             0x12f51d000 -        0x12f522fff +com.adobe.PProAEFilter.Twirl ??? (1.0) <CA624D6A-C123-3D23-1DC3-526D125086E3> /Applications/Adobe Premiere Pro CS5.5/Adobe Premiere Pro CS5.5.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
          0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
          0x7fff80003000 -     0x7fff8004aff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff80099000 -     0x7fff80116fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
          0x7fff80117000 -     0x7fff80142ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
          0x7fff802e0000 -     0x7fff80569ff7  com.apple.security 6.1.2 (55002) <4419AFFC-DAE7-873E-6A7D-5C9A5A4497A6> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff805d7000 -     0x7fff80a1bfef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <E14EC4C6-B055-A4AC-B971-42AB644E4A7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff80b33000 -     0x7fff80ed0fe7  com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff80ed1000 -     0x7fff8108fff7  com.apple.ImageIO.framework 3.0.4 (3.0.4) <0A4F51A1-4502-767B-8A4E-F14C6214EF88> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x7fff81090000 -     0x7fff8109ffef  com.apple.opengl 1.6.13 (1.6.13) <516098B3-4517-8A55-64BB-195CDAA5334D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff810a0000 -     0x7fff810a0ff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff811ca000 -     0x7fff8128bfff  libFontParser.dylib ??? (???) <A00BB0A7-E46C-1D07-1391-194745566C7E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff8128e000 -     0x7fff8129fff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <FB5EE53A-0534-0FFA-B2ED-486609433717> /usr/lib/libz.1.dylib
          0x7fff812b0000 -     0x7fff812b0ff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x7fff812b1000 -     0x7fff81367ff7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
          0x7fff8141e000 -     0x7fff8147efe7  com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff8147f000 -     0x7fff814bafff  com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff814bb000 -     0x7fff814f8ff7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <F743389F-F25A-A77D-4FCA-D6B01AF2EE6D> /usr/lib/libssl.0.9.8.dylib
          0x7fff81578000 -     0x7fff815c7fef  libTIFF.dylib ??? (???) <1E2593D1-A7F6-84C6-DF8F-0B46AE445926> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x7fff815c8000 -     0x7fff815ceff7  IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff81630000 -     0x7fff81644ff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <63C87CF7-56B3-4038-8136-8C26E96AD42F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff81645000 -     0x7fff81648ff7  libCoreVMClient.dylib ??? (???) <E03D7C81-A3DA-D44A-A88A-DDBB98AF910B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff81649000 -     0x7fff816ceff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff816cf000 -     0x7fff816d6fff  com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff816d7000 -     0x7fff816feff7  libJPEG.dylib ??? (???) <46A413EA-4FD1-A050-2EF0-6279F3EAD581> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x7fff816ff000 -     0x7fff817b4fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff81aa5000 -     0x7fff81bbffef  libGLProgrammability.dylib ??? (???) <8A4B86E3-0FA7-8684-2EF2-C5F8079428DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff81c46000 -     0x7fff81c4bfff  libGFXShared.dylib ??? (???) <1D0D3531-9561-632C-D620-1A8652BEF5BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff81e4b000 -     0x7fff81eebfff  com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff81eec000 -     0x7fff81f02fef  libbsm.0.dylib ??? (???) <83676D2E-23CD-45CD-BE5C-35FCFFBBBDBB> /usr/lib/libbsm.0.dylib
          0x7fff82181000 -     0x7fff8298bfe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <EEE5CE62-9155-6559-2AEA-05CED0F5B0F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff8298c000 -     0x7fff82999fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x7fff82b0b000 -     0x7fff82b22fff  com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff82b23000 -     0x7fff82b6ffff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
          0x7fff82b70000 -     0x7fff82bb8ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff82bc8000 -     0x7fff82efcfef  com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff82f4a000 -     0x7fff83088fff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff83089000 -     0x7fff83146fff  com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff83177000 -     0x7fff8328efef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
          0x7fff8328f000 -     0x7fff833aefe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff83488000 -     0x7fff83488ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff8349b000 -     0x7fff8349bff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff8349d000 -     0x7fff8349eff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <53299948-2554-0F8F-7501-04B34E49F6CF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8349f000 -     0x7fff834b8fff  com.apple.CFOpenDirectory 10.6 (10.6) <CCF79716-7CC6-2520-C6EB-A4F56AD0A207> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff834b9000 -     0x7fff834ecff7  libTrueTypeScaler.dylib ??? (???) <69D4A213-45D2-196D-7FF8-B52A31DFD329> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff834ed000 -     0x7fff834effff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff834f0000 -     0x7fff834f3ff7  com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff834f4000 -     0x7fff83bf0ff7  com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x7fff83c12000 -     0x7fff83c4fff7  libFontRegistry.dylib ??? (???) <4C3293E2-851B-55CE-3BE3-29C425DD5DFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff83e72000 -     0x7fff84170fff  com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff84171000 -     0x7fff8417cff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <5CA110A2-0712-F774-E7CF-AA7A2A106DAC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff8434b000 -     0x7fff844c2fe7  com.apple.CoreFoundation 6.6.5 (550.43) <31A1C118-AD96-0A11-8BDF-BD55B9940EDC> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff844ca000 -     0x7fff844caff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff844cb000 -     0x7fff844cfff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
          0x7fff844d0000 -     0x7fff844e2fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
          0x7fff844e3000 -     0x7fff844e8ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff844f5000 -     0x7fff8451aff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff8451b000 -     0x7fff845a7fef  SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff845f3000 -     0x7fff84624fff  libGLImage.dylib ??? (???) <7F102A07-E4FB-9F52-B2F6-4E2D2383CA13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff84625000 -     0x7fff8467aff7  com.apple.framework.familycontrols 2.0.2 (2020) <F09541B6-5E28-1C01-C1AE-F6A2508670C7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff84ef8000 -     0x7fff84efdfff  libGIF.dylib ??? (???) <201B8077-B5CC-11AA-E1B0-1D057ABE416A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x7fff84efe000 -     0x7fff84f01fff  com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff84f02000 -     0x7fff84f6cfe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff85012000 -     0x7fff851d3fef  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
          0x7fff853d0000 -     0x7fff8540cfe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <1E041185-131C-C237-C250-38BE933A269A> /usr/lib/libcurl.4.dylib
          0x7fff8540d000 -     0x7fff8548cfe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff856a7000 -     0x7fff856e4fff  com.apple.LDAPFramework 2.0 (120.1) <16383FF5-0537-6298-73C9-473AEC9C149C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff86734000 -     0x7fff86757fff  com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff86758000 -     0x7fff867a2ff7  com.apple.Metadata 10.6.3 (507.15) <2EF19055-D7AE-4D77-E589-7B71B0BC1E59> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff867a3000 -     0x7fff86961fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
          0x7fff86962000 -     0x7fff8698afff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff86a5d000 -     0x7fff86a5dff7  com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff86a5e000 -     0x7fff86ab1ff7  com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff86b24000 -     0x7fff86c09fef  com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff86c0a000 -     0x7fff86c27ff7  libPng.dylib ??? (???) <6D8E515B-E0A2-2BA1-9CAC-8CB8A8B35879> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x7fff86c9c000 -     0x7fff86ca2ff7  com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x7fff86cab000 -     0x7fff86cfaff7  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
          0x7fff86cfb000 -     0x7fff86d3cfef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff87144000 -     0x7fff871d4fff  com.apple.SearchKit 1.3.0 (1.3.0) <3403E658-A54E-A79A-12EB-E090E8743984> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff87359000 -     0x7fff873d7ff7  com.apple.CoreText 151.10 (???) <54961997-55D8-DC0F-2634-674E452D5A8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x7fff873e1000 -     0x7fff87491fff  edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff874d4000 -     0x7fff874e2ff7  libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
          0x7fff877ae000 -     0x7fff878e3fff  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <E5D7DBDB-6DDF-E6F9-C71C-86F4520EE5A3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff87914000 -     0x7fff87916fff  libRadiance.dylib ??? (???) <A9DB4D5D-4072-971B-DEF6-DDE645F415EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x7fff87917000 -     0x7fff879f4fff  com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff879f5000 -     0x7fff87a38ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff87a39000 -     0x7fff87a59ff7  com.apple.DirectoryService.Framework 3.6 (621.11) <AD76C757-6701-BDB5-631E-1CB77D669586> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff87a5a000 -     0x7fff87a5bfff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
          0x7fff87a94000 -     0x7fff87a98ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff87a99000 -     0x7fff87ad3fff  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <539EBFDD-96D6-FB07-B128-40232C408757> /usr/lib/libcups.2.dylib
          0x7fff87ad4000 -     0x7fff87ae3fff  com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff87c06000 -     0x7fff88600ff7  com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff88601000 -     0x7fff88607ff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff88608000 -     0x7fff88609ff7  com.apple.TrustEvaluationAgent 1.1 (1) <040B71B1-F8BD-1605-057E-E80DBDE1FE59> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff8860a000 -     0x7fff8860aff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff8860b000 -     0x7fff8862cfff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
          0x7fff8862d000 -     0x7fff888affe7  com.apple.Foundation 6.6.7 (751.62) <6F2A5BBF-6990-D561-2928-AD61E94036D9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff888b0000 -     0x7fff88984fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x7fff88985000 -     0x7fff8899bfe7  com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff88b2c000 -     0x7fff88b75fef  libGLU.dylib ??? (???) <1C050088-4AB2-2BC2-62E6-C969F925A945> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff88bf4000 -     0x7fff88c35fff  com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff88c36000 -     0x7fff8907dfef  com.apple.RawCamera.bundle 3.7.1 (570) <5AFA87CA-DC3D-F84E-7EA1-6EABA8807766> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff890f1000 -     0x7fff8918bfe7  com.apple.ApplicationServices.ATS 275.16 (???) <4B70A2FC-1902-5F27-5C3B-5C78C283C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff8918c000 -     0x7fff891a7ff7  com.apple.openscripting 1.3.1 (???) <2243C17C-EE36-D5B6-3A3E-8258973FF789> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff89364000 -     0x7fff89379ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <DC999B32-BF41-94C8-0583-27D9AB463E8B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff8937a000 -     0x7fff8943bfef  com.apple.ColorSync 4.6.6 (4.6.6) <BB2C5813-C61D-3CBA-A8F7-0E59E46EBEE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff8a477000 -     0x7fff8a48bfff  libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff8a58d000 -     0x7fff8a646fff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
          0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
      Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i7, 2.8 GHz, 8 GB, SMC 1.54f36
      Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.6
      Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: ST31000528ASQ, 931.51 GB
      Serial ATA Device: HL-DT-ST DVDRW  GA11N
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
      USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfd140000 / 5
      USB Device: v125w, 0x03f0  (Hewlett Packard), 0x3307, 0xfd141000 / 7
      USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0xfd142000 / 6
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000 / 4
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000 / 3
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000 / 5
      USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000 / 3
