1 Reply Latest reply on Aug 25, 2011 11:18 AM by Joel Cherney
    Line spacing on text tab leader lines?
    namethos Level 1
      I was experimenting with text and tabbed leader lines.  I was able to get that to work but I could not increase spacing between lines using the normal after paragraph controls.  It seems that the before and after controls do not apply to this type of text.
      How can I adjust space between the lines of text?
      Thanks in advance.
        • 1. Re: Line spacing on text tab leader lines?
          Joel Cherney Adobe Community Professional & MVP
          Something is wrong here - maybe your document, maybe your install of InDesign, but much more likely (sorry to be blunt) your understanding of how ID works. The before-para and after-para spacing isn't to increase the distance between lines of text, but to increase the distance between paragraphs. If each line is a separate paragraph, then Space Before and Space After will work just fine. To increase the distance between lines of text within a single paragraph, use the leading to affect line height:
