3 Replies Latest reply on Aug 25, 2011 11:32 AM by Dave LaRonde
    Decimal/Period (.) Play Audio track only functionality
    paulgolden Level 1
      I'm using AE CS5.5.  I'm wondering if anyone can tell me why the CTI or playhead returns to the start when you hit the period again instead of just stopping where it is, like every other editing program I've ever used?  I'm trying to work with a complex music track that would benefit from the ability to play the audio and then stop it where the playhead is instead of looping back to the where the playhead started.
      Scrubbing the timeline (Command & Scrub) works OK, but not the scrubbing sound is pretty crude; I know you can put markers in on the fly during a preview (*), but that seems like extra work; RAM Preview works the same way, so that's out.
      Is there any keyboard shortcut I'm missing to make playback behave like other edit programs?  What is the point of looping back?
        • 1. Re: Decimal/Period (.) Play Audio track only functionality
          Dave LaRonde Level 6
          You're absolutely right: AE has a crude way of dealing with audio.  It isn't one of its strong suits.  But then, AE does things that no editing application can possibly do.  That's because it was never intended to be an editing application like the ones you normally use.  Its strengths lie elsewhere.
          Here's an analogy: think of your editing apps as Microsoft word, and AE as Adobe illustrator.  Would you use Illustrator to write pages and pages of copy?  Of course not.  Would you use Microsoft word to lay out a good-looking print ad?  Certainly not!  Both applications can create text, but both have entirely different uses.
          That's the difference: editing applications are designed to edit.  AE is designed for motion graphics, effect and compositing.  Just as you don't expect an NLE to do great compositing, you shouldn't expect AE to be a whiz-bang editor.
          If improved scrubbing or starting/stopping the CTI during an audio preview would be that important to your work, you can submit a feature request (https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform).  Adobe uses the volume of feature requests to gauge how important a certain new feature would be to people.
          But I have to tell you: in the 15 years I've used AE, the methods of previewing audio haven't changed.  Maybe a tiny bit, but not to the extent you seek.  So it's just not that important to the majority of users, and Adobe concentrates on introducing new features.  Now, if disgruntled AE users regularly stormed the lobby of Adobe Headquarters in San Jose, CA demanding changes to audio preview, chances are good something would have been done about it.
          Apparently, AE's audio previewing features work okay for the majority of users.  We deal with it.  I personally see no problem with it.  One tends to get used to it.  To sum up, I don't think it's going to change.  Sorry.
          But here's a rarely-appreciated trick: turn on Caps Lock when you scrub audio: you can move the CTI in real time and scrub to your heart's content.  Then use either a layer marker on the audio layer, or a marker in the comp.
          • 2. Re: Decimal/Period (.) Play Audio track only functionality
            paulgolden Level 1
            Hey Dave
            I appreciate the Word/Illustrator analogy, and I would never to try to do
            anything remotely tricky with audio processing in AE.
            But because AE is an animation tool as well as a compositing tool, it's
            important to have reasonably good audio tools for track analysis.  The
            start/stop is one of the almost immutable hallmarks of all picture/audio
            editing and it works the correct way in all of Adobe's other products
            including Premiere, Audition, Flash, Photoshop and any other tool that plays
            motion and audio.
            (I've even stopped complaining about AE using the page up/page down to move
            frame by frame back and forth (almost every other program uses the arrow
            keys, including Premiere), but AE's audio behavior is bizarre. )
            But I have found a weird work-around in the meantime (maybe it's a bug):  if
            I do a RAM preview and then hit the space bar during playback, the playhead
            will stop in place and allow me to (.)  audio only preview forward from that
            point.
            I'm not sure I see the difference between the Audio Scrub and the CapsLock
            Audio Scrub (picture refresh off). Perhaps it's because I have a reasonably
            simple picture that doesn't need a lot of frame to frame render...
            I was just hoping I was overlooking something so simple it needed no
            explanation in the manual...
            • 3. Re: Decimal/Period (.) Play Audio track only functionality
              You might find the phrase "well, that's how it's always been done" to be a little more than lame, but in this case it's true.  I personally have few problems with audio previewing in AE.  I've adapted to AE quirks that would drive an audio pro up a wall.
              Now you are aware of the four different ways to preview audio in AE, correct?
