1 Reply Latest reply on Sep 5, 2011 3:43 AM by Anirudh Sasikumar
    Use signed framework RSL
    eprevot123 Level 2
      Hi all
      I try to use signed framework RSLs to speed up my Flex application startup, so I followed indications "Using the framework RSLs" on help.adobe.com.
      In my project Properties > Flex Build path > Library path :
      - I set Framework Linkage to RSL
      - I edit framework.swc link type : uncheck "linkage  : same as framework", select "link type:RSL", RSL deployment path is "framework_4.5.1.21328.swz", uncheck "force load RSL", and select "application domain : default"
      - do the same for textLayout.swc, spark.swc, rpc.swc
      Then when I compile the project, I have the framework_4.5.1.21328.swz AND the framework_4.5.1.21328.swf in the bin-debug.
      And if I myApp.html in a browser, I see it loads the framework_4.5.1.21328.swf (instead of .swz)
      What did I miss to use the signed framework RSL swz ?
      (I use FlashBuilder 4.5)
