2 Replies Latest reply on Aug 26, 2011 10:58 AM by Kutra
    Upgrading to RH9...remove RH8 first or install on top of it?
    Kutra Level 1
      Now that Service Pack 9.0.1 addresses the issues with conditional build tags, we have decided to upgrade our RoboHelp version from 8 to 9 to 9.0.1. Our projects use a lot of conditional build tags and version controlled using Sourcesafe. Here are my question.
      • Should I first uninstall RH8 and then install RH9? Or should I install RH9 first and then uninstall RH8?
      • We will be installing RH9 on a Windows XP machine rather than moving to Windows 7. According to Adobe, RH9 works with Windows XP so I am assuming this shouldn't be a problem.
      • Once RH9 is installed, is the process of upgrading the project as simple as just opening the XPJ file with RH9?
