I'm working with RH8. I notice
d today as I was making edits that the Save does not always work, or at least the asterisk will not disappear after I select Save All and the Save is greyed out at the same time. I elected to close the topic and when I reopened it, the edits I made were there so I believe they were saved. Anyone know why this is happening?
I think it is a bug. I have never known Word not to save if Save All is clicked. If it didn't save you would get prompted when you close the topic.
Maybe I misstated. I meant "Robohelp" would not save. when I closed the
topic, it did not prompt me.
I didn't misunderstand you. What I was getting at is if you had any doubts about whether or not RoboHelp had saved because the asterisk was still showing, RoboHelp prompts for unsaved changes when you close a topic or the project. Thus if it did fail to save when clicking Save All it would still prompt you later but, as stated, I have never known Save All to fail.
I noticed the same thing happen today in RoboHelp 9 that luviola10 did in RoboHelp 8.
I Saved All and the * still showed on the topic tabs. The changes were saved, so it may be a bug.
Randi
Hi Randi,
so it's a bug that they did not fix in rh9...interesting. thanks for letting
me know because from the other comment I received saying the person had
never seen it, I feel that I'm not crazy.
Luviola
Please read my replies. I did not say that I had never seen RoboHelp fail to clear the asterisk, what I said was that I had never known it to fail to save the changes. Save All always works but it might fail to clear the asterisks.
Hi all
I'm wondering if this is what you are seeing.
I'm not sure exactly when it happened, but I am looking at RoboHelp 7 at the moment. And at least with RoboHelp 7 and the versions that follow, there are actually two different "Save" icons. One is for saving only the open component and the other is for saving everything.
Please refer to the image below:
What I'm thinking may be at play here is that you are clicking the Save Component icon and expecting it to behave as if you clicked the Save All icon.
Normally I will remove the Save icon and leave behind only the Save All because that was happening to me. I'd click save and be perplexed that the asterisks failed to disappear from all but the topic I was working on.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Rick
I have seen this myself and I always use Save All. It's rare that it happens.
