0 Replies Latest reply on Aug 26, 2011 12:28 PM by Marcos J Pinto
    Process change: from watched folder to web event
    Marcos J Pinto Level 1
      Hello!
      I built a simple process to merge an XDP to an XML data file to create PDF documents.
      Simple enough, the process gets the XML from a watched folder, does the merging and saves the resulting PDF files in a server folder.
      Now I need to change this process to obtain the following behavior:
      1. User clicks a link on a Web page (HTML) sending an ID as reference
      2. Based on the ID, process gets an XML, merges with XDP and sends back to the browser the resulting PDF
      So I believe I must change this to a webservice...
      Question:
      Is it enough if I replace the watched folder with a single starting point ?
      What must I call from the web link, something like this?
      http://localhost:8080/soap/services/webPDFGen/Processo/webPDF?wsdl
      Thank you for any help.
      Marcos
