4 Replies Latest reply on Sep 20, 2011 12:25 PM by Francisc
    How to listen for actionContent button click event in View
    Francisc Level 3
      Hello,
      Doing this:
      FlexGlobals.topLevelApplication.addEventListener('actionContentClick',showOptions);
      Results in calling showOptions() as many times as the view was showed. The handler sticks and each time I enter a view in the creationComplete hander for it I add the same listener over and over again.
      How should this be done?
      1. FlexGlobals.topLevelApplication is the right object to listen to?
      2. I can remove the listener on view deactivate, but I am not sure if that will be called each time the view goes away.
      3. Can I check if an object already has a listener and which is it?
      Thank you.
