9 Replies Latest reply on Aug 30, 2011 9:17 AM by SuperCrawler
    Good computer?
    elfy04
      Im thinking of buyting this computer for use of photoshop and premier editing hd videos? Will this be a good setup or not? Thanks!!!! EDIT- I'm mostly woried about the graphics card?
      Custom built Desktop.  White mini tower style case.  Biostar P4M900  motherboard.  Intel Pentium 4 3.2GHZ processor.  2 GB DDR2 Ram.  80 GB  hard drive.  DVD drive.    If interested, Email with a contact phone  number for more information.   These are the specs of the motherboard:
      Socket LGA 478
      Supports Intel Pentium 4/Celeron D Processor
      Supports FSB 400/533/800MHz
      Support Intel Hyper-Threading Technology• Chipset:
      VIA P4M900 / VT8237A
      • Memory:
      Support DDR2 533/667 MHz
      2 x DDR2 DIMM Memory Slot
      Max. Supports up to 4GB Memory
      • Slots:
      2 x PCI Slots
      1 x PCI-E x1 Slots
      1 x PCI-E x16 Slots
      • IDE:
      2 x EIDE channels (up to 4 devices)
      Ultra DMA 33/66/100/133 Bus Master Modes
      • I/O:
      1 x PS/2 mouse
      1 x PS/2 keyboard
      4 x USB 2.0 Ports
      2 x USB 2.0 Headers
      1 x Serial Port
      1 x VGA Port
      1 x LAN Port
      3 x Audio Port
      2 x SATA Connectors
      1 x Floppy Connector
      1 x IDE Connectors
      1 x Front Audio Header
      1 x Front Panel Header
      1 x CD-IN Header
      1 x S/PDIF-OUT Header
      1 x CPU FAN Header
      1 x System FAN Header
      1 x Printer Header
      • SATA:
      Support RAID, 0, 1
      • Video:
      VIA Chrome9 HC IGP, On Board Graphic Max. Memory Share Up to 256MB
      • Audio:
      Realtek ALC861VD 6-Channel HD Audio
      • LAN:
      Realtek RTL8201CL - Integrated 10/100 Transceiver
      • OS SUPPORT:
      Support Windows 2000 / XP / XP 64 / Vista / Vista 64
      • Hardware Monitor:
      CPU Voltage
      CPU Fan Speed
      DIMM Voltage
      CPU Temperature
      • Size:
      Micro ATX Form Factor Dimension: 19 cm X 24.4 cm ( W x L )
      • Accessories:
      1 x IDE Cable
      1 x FDD Cable
      1 x SATA Cable
      1 x Real I/O Panel
      1 x Fully Setup Driver
      1 x User Manual
        • 1. Re: Good computer?
          Complete waste of money to use PPro CS5/CS5.5 and HD video
          Desktop Video Editing PC http://www.adkvideoediting.com/
          -and http://forums.adobe.com/thread/877201?tstart=0
          UK http://3xs.scan.co.uk/Category.asp?SystemMasterCategoryID=14
          Laptop Video Editing PC http://www.sagernotebook.com/
          -or http://www.adkvideoediting.com/systems/viewsystem.cfm?recordid=118
          -or another brand laptop with the following features
          -the newer sandy bridge 2720 or 2820 quad processor
          -and nvidia graphics preferably the 460m, 485m is a bit much
          -1280x900 display with OpenGL 2.0-compatible graphics card
          -and 8 or 16 gig ram and Win7 64bit Pro
          -and 2 internal 7200 HDDs minimum
          This message has a really good graphic about requirements
          CS5 Requirements http://forums.adobe.com/thread/810750?tstart=0
          Build it Yourself http://forums.adobe.com/thread/815798?tstart=0
          About Requirements http://forums.adobe.com/thread/618058?tstart=0
          Disk Configurations http://forums.adobe.com/thread/878419?tstart=0
          • 2. Re: Good computer?
            elfy04 Level 1
            So, when you said complete waste I assume you mean this computer won't be able to? Thanks for your help!
            • 3. Re: Good computer?
              Bill Gehrke Most Valuable Participant
              Where did you find this antique?  No SATA disk drive capability!  Only 4 GB of RAM maximum!  On Newegg the only socket 478 chips that are available are used recertified chips!
              • 4. Re: Good computer?
                Harm Millaard Level 7
                Don't they have an original 8088 IBM PC with 160 KB 5.25" floppy drive from early 1983? That would at least be worth more than $ 5. This system you mention is not even worth the shipping cost if it were free.
                • 5. Re: Good computer?
                  ExactImage Level 3
                  Run away.  I've put faster / better computers than this in the trash.
                  • 6. Re: Good computer?
                    That is exactly what I mean... that computer will not be able to use CS5 to edit HD
                    My previous computer was a Pentium 4 and I used CS3 to SLOWLY edit SD video
                    You need an Intel i7 CPU and Win7 64bit and a MINIMUM of 6Gig ram and a MINIMUM of two hard drives
                    • 7. Re: Good computer?
                      RjL190365 Level 5
                      That computer cannot run Premiere Pro CS5.x at all because Intel has never manufactured a Socket 478 CPU that supported x86-64 at all. All Socket 478 CPUs are strictly 32-bit-only. CS5.x requires a 64-bit computer with a 64-bit CPU running the 64-bit versions of Windows 7 or Vista. And even if you could get Premiere Pro CS4 running on that system, CS4 would be molasses-slow on that system.
                      In addition, there has never been a PATA hard drive that's anywhere near as fast (in terms of physical sustainable transfer speed) as any of today's SATA hard drives. In fact, the fastest PATA hard drives are as slow as some of the 5400 RPM SATA "green" hard drives on the market. (By the way, that Biostar P4M900 motherboard does have two SATA 1.5 Gbps ports - but that's not nearly enough to support a proper (R)AID 0 configuration that's recommended for anything HD, and which forces you to use PATA for the OS drive and the optical drive if you want RAID 0 at all while retaining a non-RAID drive for the OS. What's more, SATA 1.5 Gbps is already obsolete since most of the current-generation SATA hard drives can already surprass the maximum sustainable transfer speed of the interface physically on the outer tracks of the platters. The PATA ports do not support RAID at all.)
                      Third, that system's motherboard uses a VIA chipset, which is neither as fast nor as stable as Intel's own chipsets of that era. Plus, the P4M900 chipset's memory controller did not support dual-channel operation at all; it was limited to single-channel-only which limited the performance of most of the HyperThreading-enabled Pentium 4 CPUs of the era. (All of the 3.2GHz Pentium 4 CPUs in Socket 478 used an "800MHz" FSB while the P4M900 only ran DDR2 memory at up to "667MHz" and in single-channel mode; that created a mismatch between the CPU bus bandwidth and the memory bandwidth which resulted in a performance bottleneck.)
                      Fourth, that entire system is now completely obsolete. The motherboard has onboard graphics that are unbearably slow, and its PCI-e x16 slot is too slow for any of today's GPUs. Plus, the chipset is so old that Windows 7 might not run properly on that system (for example, there are no Windows 7 drivers available at all for at least some of the components of that system).
                      Fifth, that system's single 80GB hard drive is too small and too slow to be of much use in a video editing system.
                      There is a reason why Intel completely ditched the Netburst architecture used in the Pentium 4 in favor of a derivative of the Pentium M architecture back in 2006: Netburst CPUs are extremely inefficient, delivering a poor performance-to-wattage ratio even when compared to the AMD CPUs of that era.
                      In other words, that system is not worth even the cost to ship it (if it must be shipped). I would not take that system even if it were free. In fact, if that system were all you can afford, you'd be much, much better off with an i3-2100 build with 4 to 8 GB of DDR3-1333 RAM and integrated Intel HD Graphics 2000. (As shown in the PPBM5 results list under the name "Rag-Tag Jalopy", I'd be willing to bet that the i3-2100 with just the integrated graphics would be much, much faster in CS4 than a Pentium 4 with even the fastest discrete Nvidia Quadro or AMD/ATi FirePro 3D GPU.)
                      Message was edited by: RjL190365
                      • 8. Re: Good computer?
                        wolverine.ks Level 1
                        lol, i had to check the date after reading this post
                        • 9. Re: Good computer?
                          SuperCrawler Level 1
                          You and I should team up together... your 1983 antique with my senior citizen rustbox (Celeron 2.4 GHz, 1.49 GB RAM, 40 GB HDD) will look good together ! Wait til you read some of my threads ...
                          ... but I'm catching on (slowly).
