5 Replies Latest reply on Jun 19, 2007 6:31 AM by kglad
    localToGlobal in nested swfs
      hi there
      i seem to behaving problems with a globalToLocal calculation. it all works fine and as it should when i run the .swf on its own, but the problem happens when i load the swf into a parent swf. if it loads in a 0, 0 then again, all is well. if i ever shift the containers _x that the child is loaded into then the co-ordinates screw up
      if its any use, then heres teh code im using for my localToGlobal
      var pointConversion:Object = new Object();
      pointConversion.x = p_x;
      pointConversion.y = p_y;
      is there a known issue, or some kinda of workaround any one knows of, perhaps even doing localToGlobal then a GlobalToLocal again?
      thanks very much
