4 Replies Latest reply on Sep 5, 2011 10:50 PM by codexplorer
    catastrophic start
    codexplorer Level 1
      Wow!!!
      Talk about the wrong start...
      I installed CS 5.5 Production Premium on my spanking new iMac 21.5 i7 and I got:
      - Bridge not working after using Migration Assistant to get the dat from my MBP (uninstalling/reinstalling CS 5.5 did not help)...
      - First Premiere Project, first attempt to open an AVCHD video from the media browser resulted in a crash...
      - Second attempt: a 1080i video does not play smoothly in the Preview monitor even at 1/4 resolution. OK, I still have only 4 GB of RAM (more is on the way) but com'on! These 17 Mbps clips play smoothly in full screen using QT!!!
      - Then some of the clips won't open: The importer reported a generic error. WTH? These are exactly the same kind of clips I just opened... And of course they play fine in QT.
      What gives? I feel totally misled by all the Adobe TV shows I had watched before deciding to skip FCP X and moving on to the dark side. I know there must be something wrong. But where to start?
      Thanks for pointers.
        • 1. Re: catastrophic start
          codexplorer Level 1
          I managed to get some more stable behavior after avoiding to use two accounts on my iMac. That sounds like a bug to me.
          Then I got some feedback from another forum. It turns out that AVCHD footage rewrapped into .mov files (I am using ClipWrap to do that) are played back in Premiere using Adobe QT Server which is a 32 bit application and uses a single core [This BTW is not exactly correct, if at all, as all 4 cores of my i7 seem to be active. However, only one thread per core appears to be running, whereas .mts files seem to be processed with two threads per core]. Hence the stuttering. Indeed, if I preview the original .mts files in the media browser or in the timeline, everything plays back smoothly using all cores. That bad playback of .mov H.264 files is apparently a known bug... Yet another one.
          The problem with .mts files is that they are not played by QT and neither are they by Adobe Bridge! So I cannot add metadata and organize my files using Bridge unless I convert them into .mov files. But then they are a pain in the butt to use in Premiere. Sounds like a 3rd bug to me (*)!
          (*) it appears to be a problem introduced in CS 5 where Bridge is assuming the availability of tools provided with the rest of the suite which are not here, not being needed anymore...
          Anybody at Adobe listening to this?
          Message was edited by: uwxplorer
          • 2. Re: catastrophic start
            codexplorer Level 1
            Workaround: rename the .mov files as .mpg. They are played correctly in both Bridge and PP (as good as the original MTS files in the latter case). The only problem is that now, you can't preview the files in the finder (which is a minor problem for me). You can however associate them with Mpeg Streamclip.
            • 3. Re: catastrophic start
              the_wine_snob Level 9
              What are the full specs. of your iMac? The greater the detail, like CPU, GPU and I/O, the better.
              Good luck, and sorry for the rough start.
              • 4. Re: catastrophic start
                codexplorer Level 1
                iMac 21.5", 2.8 GHz i7, AMD Radeon HD 6770M 512 MB, 4GB RAM, 1TB SATA HD
                I have 8 GB on its way, but the issues I have faced initially seem unrelated to those specs. Things have stabilized somewhat since reading a number of tutorials and blogs. I won't blame Adobe for providing a funky support of AVCHD when Apple itself doesn't provide any. By that I mean the ability to use mts file in PP but not being able to preview them in Bridge (Adobe) or the Finder (Apple).
                The thing I don't quite understand is the .mov to .mpg renaming that seems to fix Bridge's AND PP's behavior, but I won't worry about it at this time. This is actually not completely true in the sense that Bridge still shows a black first frame preview (thumbnails are OK and playback works fine). Since I have seen that in tutorials I have watched and that did not seem to bother the speaker, I guess people have gotten use to quirks of that sort...
