4 Replies Latest reply on Aug 29, 2011 8:32 AM by gkaiseril
    new line
    jck_drmjn Level 1
      I have placed following code under address field.Each field - Text1, Text2, Text3, Text4 will start on new line.
      this.getField("Address").value= this.getField("Text1").value \n this.getField("Text2").value \n this.getField("Text3").value \n this.getField("Text4").value;
      It shows error. What is the perfect code for this purpose?
        • 1. Re: new line
          The character string "\n" is a character string and not a variable name. Enter the character string with the correct delimiters for entering a character string..You will also need to use the concatenation operator.
          The sample forms in the PFN folder of the Acrobat distribution disk have a function for combining form fields and adjusting for missing or null data elements.
          • 2. Re: new line
            jck_drmjn Level 1
            Thanks for reply.
            Would you tell me how can I get correct delimiters for new line?
            Would you clarify me PFN folder?
            I'd be glad if you'd help me.
            • 3. Re: new line
              jck_drmjn Level 1
              Thanks.
              I have got answer.
              • 4. Re: new line
                The very simplest script is:
                this.getField("Address").value= this.getField("Text1").value + "\n" + this.getField("Text2").value + "\n" + this.getField("Text3").value + "\n" + this.getField("Text4").value;
                "\n" including the quotation marks, is the character string for a new line. The "+" operator is the JavaScirpt concatenation operator and addition operator. The inclusion of a character string will force the values to string and concatenation. But an empty field will insert a blank line.
                With the following document level function one can join the strings and eliminate the empty fields.
                // Concatenate 3 strings with separators where needed
                function fillin(s1, s2, s3, sep) {
                  var test = 0;
                  s1 = s1.toString();
                  s2 = s2.toString();
                  s3 = s3.toString();
                  if (s1 != "") test += 4;
                  if (s2 != "") test += 2;
                  if (s3 != "") test += 1;
                  if (test == 0) return "";
                  if (test == 1) return s3;
                  if (test == 2) return s2;
                  if (test == 3) return s2 + sep + s3;
                  if (test == 4) return s1;
                  if (test == 5) return s1 + sep + s3;
                  if (test == 6) return s1 + sep + s2;
                  if (test == 7) return s1 + sep + s2 + sep + s3;
                For the "Address" form field, one could use the following custom calculation script:
                event.value = fillin(this.getField("Text1").value, this.getField("Text2").value, this.getField("Text3").value, "\n");
                event.value = fillin(event.value, this.getField("Text4").value, "", "\n");
                If you have the distribution DVD/CD for Acrobat, there are sample folders and addtional documentation on that disk.
