6 Replies Latest reply on Aug 30, 2011 12:15 PM by xbytor2
    Get app.documents[???] for the activeDocument
    Pedro Cortez Marques Level 3
      An example:
      I have 10 opened images in photoshop.
      I start working on the last one, then the one before, and so on until the 8th image.
      1, 2, 3, 4, 5, 6 are opened
      7, 8, 9 are finished and must be saved.
      I want an action that will save the activeDocument and all the ones after that: in the example will save the 7th 8th and 10th image.
      Is this possible?
      I have everything but I don't know how to get the number for the activeDocument >>> app.documents[???]
        • 1. Re: Get app.documents[???] for the activeDocument
          Michael L Hale Level 5
          Here is a quick way to get the index of the activeDocument.
          function getActiveDocumentIndex(){
               var ref = new ActionReference();
               ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
               return desc = executeActionGet(ref).getInteger(stringIDToTypeID('itemIndex'))-1;
          alert('The activeDocument is app.documents['+getActiveDocumentIndex()+']');
          • 2. Re: Get app.documents[???] for the activeDocument
            xbytor2 Level 4
            The quick way doesn't always work.
            For instance:
            1) File > New...
            2) 3D > New Shape From Layer > Cube Wrap
            3) Image > Duplicate...
            Then run your code (slightly modified):
            var index = getActiveDocumentIndex();
            alert(app.documents[index].name);
            It thinks the duplicated doc is [2] instead of [1] then fails when you try to get the name. This is apparently an artifact of the 3D system introducing new pseudo-documents internally when you have 3D layers.
            You end up have to use something like this to get the actual DOM index:
            function getDocumentIndex(doc) {
              var docs = app.documents;
              for (var i = 0; i < docs.length; i++) {
                if (docs[i] == doc) {
                  return i+1;
              return -1;
            This is a CS5/Extended problem but the problem may present itself in other ways.
            • 3. Re: Get app.documents[???] for the activeDocument
              I have never run into that before. But then again I don't do much with 3D.
              I still like getting the index directly instead of looping so I think I will try to come up with an Action Manger fix.
              • 4. Re: Get app.documents[???] for the activeDocument
                xbytor2 Level 4
                Nor do I, but I have very thorough beta testers. There may also be other cases that cause this problem that I don't recall. I just changed my code to compensate for the problem.
                • 5. Re: Get app.documents[???] for the activeDocument
                  Thanks Michael
                  That's what I needed.
                  I only need to apply it to opened photos (never new documents) and I do not need 3D
                  Tks
                  • 6. Re: Get app.documents[???] for the activeDocument
                    xbytor2 Level 4
                    The problem I noted happens with new or existing documents that contain 3D shape layers. It can apparently happen with docs containing certain Smart Object or Smart Filter layers but I haven't been able to replicate those cases.
                    The important point here is that there are (undocumented) situations where the index in a document's descriptor may not correspond to the document's DOM index.
                    -X
