0 Replies Latest reply on Aug 29, 2011 3:24 PM by anurag c
    Ant task cyclic library refrence
    anurag c
      Hello everyone,
      I am using flex ant task from my Flash builder to compile application. Its working fine and I am able to get the output. But the problem is whenever I use a library in my main project which is refrencing other library than I am unable to find refrence of components in lib 2. Below is the structure
      NewLib >> contains a NewLibGrid(which is a normal spark grid)
      MainLib >> ExtPanel which includes NewLibGrid from NewLib .
      MainApp >> This uses ExtPanel
      No I am getting error during ant compilation
      [compc] D:\Data\Flex\Projects\CompLib\src\ExtPanel.mxml: Error: Could not resolve <local:NewLibGrid> to a component implementation.
      Here is part of antscript I am using
      <target name="lib1" depends="lib2">
      <compc output="${STAGE_DIR}/stagingDir/CompLib.swc"
         keep-generated-actionscript="${DEBUG}"
         debug="${DEBUG}"
         optimize="${OPTIMIZE}"
         target-player="${TARGET_FLASH_PLAYER}"
         include-classes="ExtPanel">
      <runtime-shared-library-path path-element="${FLEX_HOME}/frameworks/libs/framework.swc">
      <url rsl-url="framework_${FLEX_VERSION}.swf"/>
      <url rsl-url="framework_${FLEX_VERSION}.swz"/>
      </runtime-shared-library-path>
      <runtime-shared-library-path path-element="${PROJ_HOME}/NewLib/bin/NewLib.swc">
      <url rsl-url="${PROJ_HOME}/NewLib/bin/NewLib.swf"/>
      <url rsl-url="${PROJ_HOME}/NewLib/bin/NewLib.swz"/>
      <compiler.library-path dir=".." append="true">
      <include name="Common/libraries"/>
      <exclude name="global_library.swc" />
      </compiler.library-path>
      <source-path path-element="../CompLib/src" />
      </compc>
      </target>
      <target name="lib2">
      <compc output="${STAGE_DIR}/stagingDir/NewLib.swc"
         debug="${DEBUG}"
         include-classes="NewLibGrid">
      <source-path path-element="../NewLib/src" />
      </compc>
      </target>
