0 Replies Latest reply on Aug 30, 2011 12:15 AM by flexir
    Datagrid itemrenderer fails - data interchanged between cells
    flexir
      I have the follwing datagrid, the 2nd column of which calls an itemrenderer...
      <mx:DataGrid x="10" y="10" width="478" height="209" headerHeight="0" id="dgFollowUp"  verticalAlign="top" variableRowHeight="true" wordWrap="true" borderStyle="none" borderThickness="0" color="#000000" useRollOver="false" selectionColor="#FFFFFF">
              <mx:columns>
                  <mx:DataGridColumn dataField="sel"  width="30"  textAlign="left"  sortable="false"   id="colsel" headerText="" >
                      <mx:itemRenderer>
                          <mx:Component>
                              <mx:CheckBox paddingTop="2"  paddingLeft="10" selected="{data.sel}"
                                  change="{data.sel = this.selected;}" click="parentDocument.changeIsSelectedStatus(this.selected, data)"/>
                          </mx:Component>
                      </mx:itemRenderer>
                  </mx:DataGridColumn>
                  <mx:DataGridColumn headerText="" dataField="{data.FDOCNO_CONCAT}" itemRenderer="dgFollowupTextRenderer"/>
              </mx:columns>
          </mx:DataGrid>
      ...And here it is:
      <?xml version="1.0"?>
      <!-- itemRenderers\list\myComponents\RendererState.mxml -->
          <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init()" height="100%">
              <mx:Script>
                  <![CDATA[
                      import mx.states.SetProperty;
                      import mx.controls.Text;
                      import mx.controls.Label;
                      import mx.managers.PopUpManager;
                    private function init():void
                        var myLabel:Text = new Text;
                        var myText:String = data.FDOCNO_CONCAT;
                        var myLink:Label;
                        var myVboxIn:VBox;
                        myLabel.text = myText;
                        myLabel.width = 430;
                        myVbox.addChild(myLabel);
                        if (myText.length > 400)
                            myLink = new Label;
                            myLink.text = this.parentApplication.scn2LangXml.lastResult.followup.lblReadMore;
                            myLink.setStyle('color', 0x0000FF);
                            myLink.mouseChildren = false;
                            myLink.buttonMode = true;
                            myLink.useHandCursor = true;
                            myLink.addEventListener(MouseEvent.CLICK, callPopup);
                            myVbox.addChild(myLink);
                    public function callPopup(event:Event):void
                      var FollowUpDetailsPop:FollowUpDetails;
                      var count:Number = data.counter;
                      var tmp:String = data.FDOCNO +' :\n'+data.DESCRIPTION + '\n' + data.COMMENTS;
                      FollowUpDetailsPop = FollowUpDetails(PopUpManager.createPopUp(this, FollowUpDetails, true));
                      PopUpManager.centerPopUp(FollowUpDetailsPop);
                      FollowUpDetailsPop.text = tmp;
              </mx:Script>
              <mx:VBox id="myVbox" height="100%"/>
          </mx:VBox>
      ...And here is the popup:
      <mx:TitleWindow
          layout="absolute"
          width="400"
          height="300"
          showCloseButton="true"
          close="close()"
          title="{this.parentApplication.scn2LangXml.lastResult.followupdate.lblTitleDetails}"
          borderAlpha="1">
      <mx:Script>
          <![CDATA[
              [Bindable] var text:String;
              private function close():void
                   PopUpManager.removePopUp(this);
      </mx:Script>
          <mx:TextArea id="txtDetails" text="{text}" x="10" y="10" width="360" height="240" editable="false"/>
      </mx:TitleWindow>
      ...........Everything displays correctly and the popup functions well too.. The only problem is that when you scroll the initial datatagrid, you see data in the column, which calls the itemrenderer, being swapped between the rows. I have tried same on another example and 1) on sorting the column, the popup contains the wrong data and 2) if there are other columns, its only the one calling for itemrenderer which swaps data between its rows.
      Any help | Many thanks..
