9 Replies Latest reply on Sep 2, 2011 2:39 PM by gerdalt
    Newbie needs help please - InDesign Server crashing
    gerdalt
      Hi there, be patient please, I am new at this.
      I have downloaded the free trial CS5.5 InDesign Server code.
      I have installed it on a PC running Win Server 2008 (32 bit)
      I have installed the ExtendScript Toolkit
      I have entered the simple Hello World program from the CS5 Server Scripting Guide Manual (see below)
      When I run the helloworld.jsx file,  InDesign Server always crashes.
      The PC is quite old but has 2GB memory.
      The crash details are as follows:
      Problem Event Name: APPCRASH
        Application Name: InDesignServer.exe
        Application Version: 7.5.1.304
        Application Timestamp: 4de85730
        Fault Module Name: DOCUMENT FRAMEWORK.RPLN
        Fault Module Version: 7.5.0.142
        Fault Module Timestamp: 4d78c8d5
        Exception Code: c0000005
        Exception Offset: 00058bb1
        OS Version: 6.0.6002.2.2.0.272.7
        Locale ID: 2057
        Additional Information 1: b68b
        Additional Information 2: 3253411fd8270f5f3a953dd3615c74a5
        Additional Information 3: f6b4
        Additional Information 4: c51b6b93e8f6b2f26f2b5aa39f99a829
      Any advice appreciated.
      Ger
      The simple ExtendScript program is:
      var myDocument = app.documents.add();
      var myPage = myDocument.pages.item(0);
      var myTextFrame = myPage.textFrames.add();
      myTextFrame.geometricBounds = ["6p0", "6p0", "18p0", "18p0"];
      myTextFrame.contents = "Hello World";
      myDocument.save(new File("c:/Absolute.indd"));
      app.documents.item(0) .close();
        • 1. Re: Newbie needs help please - InDesign Server crashing
          John Hawkinson Level 5
          Hmm.
          Does Win Server 2008 have Dr. Watson? Specifically, do you have a %AllUsersProfile%\Application Data\Microsoft\Dr Watson\DRWTSN32.LOG file?
          Do you have the InDesign Desktop (regular) version installed on your system? Does it fail in the same way?
          • 2. Re: Newbie needs help please - InDesign Server crashing
            gerdalt Level 1
            Thank you for the quick response.
            Win Server 2008 does not have Dr Watson - I understand it cannot be installed there.
            No, I don't have InDesign desktop installed - just the Server.
            Ger
            • 3. Re: Newbie needs help please - InDesign Server crashing
              I would suggest you try installing InDesign Desktop (trial) and see if you can replicate the problem. It doesn't sound normal.
              • 4. Re: Newbie needs help please - InDesign Server crashing
                gerdalt Level 1
                I was afraid you'd suggest that!!
                It's taken me two weeks to get to where I am now, so I gues a few more days shouldn't matter
                As they say - "I'll be back".
                Ger
                • 5. Re: Newbie needs help please - InDesign Server crashing
                  gerdalt Level 1
                  OK, back again.
                  I downloaded InDesign CS5.5 trial and the script runs fine there.  It saves the .indd file.
                  I then removed line 6 (the SAVE) from the script above.
                  With that line removed the script runs error free on the Server. Don't know if it does anything!!
                  So I then focus on the syntax for the SAVE  It seems non standard?
                  Using workstation InDesign it seems to accept any of the following
                  "filename.indd"
                  "/c/filename.indd"
                  "D:\filename.indd"
                  The manual shows syntax "/c/filename.indd" but the /c/ part looks strange.
                  Any advice on another way to save the output file?
                  Ger
                  • 6. Re: Newbie needs help please - InDesign Server crashing
                    Sorry for the delay.
                    "filename.indd"
                    "/c/filename.indd"
                    "D:\filename.indd"
                    I'm not quite sure what the question is.
                    There are a bunch of different syntaxes, mostly because file paths in the Javascript API are handled accoridng to unix rules, most of the time, where a forward slash is the normal delimiter. The JavaScript Tools Guide discusses this, and it sounds like you have found it.
                    Just be conscious that in Javascript, if you type "D:\filename.indd", then the "\f" will be interpretted as an "f", because backslash is the JavaScript escape character. Thus, you should use either "D:\\filename.indd" or you should use one of the forward-slashed forms.
                    I would stick with "/c/filename.indd" if I were you, though you should try to avoid specifying the full path explicitly in your script, anyhow. "~/Desktop/filename.indd" would be much better.
                    • 7. Re: Newbie needs help please - InDesign Server crashing
                      gerdalt Level 1
                      Thank you for those comments.
                      But my original problem remains - when I run the original script, InDesign Server CS5.5 crashes.
                      If I remove line 6 it doesn't crash - but of course no .indd file is created.
                      I had hoped perhaps there was another way to output a file using a different syntax?
                      Ger
                      • 8. Re: Newbie needs help please - InDesign Server crashing
                        Sorry, I thought you had meant that changing the style of path specification solved your problem.
                        Are quite certain that you have permission to write to C:\?
                        Maybe the problem is one of file permissions, and you should ensure that you pass in a path that you know you can write to. Such as ~/Desktop/file.indd.
                        • 9. Re: Newbie needs help please - InDesign Server crashing
                          gerdalt Level 1
                          Hi there,
                          I have tried several different ways of specifying the output file path, but IS always crashes.
                          I need to spend more time learning ExtendScript so as to restructure the sample script provided.
                          Being a complete novice, I won't waste any more forum time until I am better skilled!!
                          Thanks again for your patience.
                          Ger
