0 Replies Latest reply on Aug 30, 2011 1:28 PM by ok im here
    Installation Error FB 4.5 & FC cs 5.5, need help
    ok im here
      Tried installing CS5.5 web premium, everything installed ecept Flash Builder 4.5 and Flash Cataclyst cs 5.5. After trying diffret thins kile installing without av, rebooting serveral times, uninstalling Flash player active x and normal ect....
      So i decided to check the log files and found this:
      ::START TIMER:: [Pre payload :{650C9D09-D5BD-4532-8BEE-01DBC1DF5537}]
      In PrePayloadInstallProc
      hook checkDirs passed str:
      X:\Program Files\Adobe
      C:\Users\!Tulingen\AppData\Roaming
      detected bad character
      CHRC_NULL_POINTER_VALUE
      Custom action return code: 1
      :: END TIMER :: [Pre payload :{650C9D09-D5BD-4532-8BEE-01DBC1DF5537}] took 1.54282 milliseconds (0.00154282 seconds)
      and
      ::START TIMER:: [Pre payload :{D8CCCF4C-C227-427C-B4BE-736657D2AB7E}]
      :: END TIMER :: [Pre payload :{D8CCCF4C-C227-427C-B4BE-736657D2AB7E}] took 1.67242 milliseconds (0.00167242 seconds)
      the first one is for Flash Builder and the second on is for Flash Cataclyst
      Identified by the bit below
      ----------- Payload: {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 -----------
      ERROR: DW030: Custom Action for payload {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 returned error. Failing this payload.
      ----------- Payload: {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} Adobe Flash Catalyst CS5.5 1.5.0.0 -----------
      ERROR: DW030: Custom Action for payload {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} Adobe Flash Catalyst CS5.5 1.5.0.0 returned error. Failing this payload.
      So it appears the installer cant handel any special caracters in username eg. the "!" (exclamation mark).
      System OS
      Win 7 Ultimate 32-bit
      That means i have to change accountname, except if annyone got some idea or solution that might work, any help is appreciated.
      Beside this shoud be notified to the team that is making the installer if they don't already know this.
      Message was edited by: ok im here Reason: formating issue on 2nd code box
