3 Replies Latest reply on Aug 31, 2011 12:25 PM by Peter Spier
    Anchored objects are transparent
    STATUS_DANNY
      Thanks in advance for the help. I am using CS5.
      I have a document were multiple anchored objects ended up overlapping each other. My problem is that the anchored objects have a transparency set to them that I cannot remove. Things to note:
      • The transparency goes away if I release the anchored object.
      • I have an object style assigned to the anchored frames, but there are style overrides that I cannot clear on the anchored objects.
      • Changes I make to the object style assigned to the anchored objects have no effect. Only the "anchored objects options" attributes box will modify the anchored objects.
      Any help with this issue would be great. Thanks!
