2 Replies Latest reply on Sep 9, 2011 1:53 PM by Rahul7777
    Selected Index in tree.
    Rahul7777 Level 1
      my tree has data coming from back-end, last time user selected tree-node is  in localstorage, so when tree's creationcomplete is completed, i am expanding
      my tree and  specifing like this, but this is not working,  is this the correct way?????
           var nodeName = "<node label=";
           var nodeClose  = "/>"
           for(var i:int=0; i < j=treedp.length; i++)
                           nval= nodeLab[i];    //  nval is xml
                           treeChannel.expandItem(nval,true);
                      var item:XML = XML(nodeName + " \""+localstorageObj.getLastselectedTreeitem() +"\""+ nodeClose);
                      treeChannel.validateNow();
                      treeChannel.selectedItem = item;
      any help.....
      thanks.
        • 1. Re: Selected Index in tree.
          Flex harUI Adobe Employee
          Item is being assigned to a new XML node, not one in the treedp, so the tree
          will not be able to find item in the dataprovider.  When assigning
          selectedItem, we are looking for a matching node reference, we don't compare
          the attributes of the node.
          You can perform an e4x query on the treedp if you save away enough
          information to uniquely identify it.
          • 2. Re: Selected Index in tree.
            Rahul7777 Level 1
            Hi Alex,
                          i added some attributes to xml to track particular item, Now when i set the selectedItem i am seeing some weird behaviour.
            <mx_internal_uid> attribute is added to the xml item,
            var nodeList:XMLListCollection = treeChannel.dataProvider as XMLListCollection;
            var nodeLab:XMLList = nodeList.source;
            for(var i:int=0; i < 5; i++)
                nval= nodeLab[i];
                  if(i == treeItem)  // tree Item is int
                           treeChannel.selectedItem = nval.Item.(@channelID==0);
                           trace("tree item is "+ nval.Item.(@channelID==0));
            trace result is:
            <Item label="Name" selectedID="0" channelID="0">
              <mx_internal_uid>9E875DAA-B355-8B6C-2DBE-4FE1B5C2735E</mx_internal_uid>
            </Item>
            Actual XML is
            <node label="Header">
            <Item label="Item1" selectedID="0" channelID="0">
            <Item label="Item2" selectedID="0" channelID="1"/>
            <Item label="Item3" selectedID="0" channelID="2"/>
            <Item label="Item4" selectedID="0" channelID="3"/>
            <Item label="Item5" selectedID="0" channelID="4"/>
            <Item label="Item6" selectedID="0" channelID="5"/>
            3 more of this format with different label and id's.
            I want to get rid of this internal uid, as it is displayed in the tree, and selectedItem is not highlighted, unnecessary arrow mark is showed up now.
            any suggestion.
            thanks
            Rahul.
