3 Replies Latest reply on Sep 9, 2011 2:43 PM by AlHolden
    Formatter rounds - the same number - two different ways?
    AlHolden Level 1
      See and/or run the 4.01 code below. Although the resulting number is the same, the formatted output is:
      8485.50
      8485.51
      Please advise what revision I should make so that I get 8485.51 in both cases.
      Thankew!!!
                      xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="200" minHeight="300">
           <fx:Declarations>
           <!-- comment in/out one or the other, the result is the same
           <mx:CurrencyFormatter id="dolFmt"
                                     decimalSeparatorTo="."
                                     precision="2"
                                     currencySymbol=""
                                     rounding="nearest"
                                     useThousandsSeparator="false" />
           <mx:NumberFormatter id="dolFmt"
                                    rounding="nearest"
                                    precision="2"
          </fx:Declarations>
           <fx:Script>
               <![CDATA[
                   [Bindable]
                   private var numString1:String = "8485.5050";
                   [Bindable]
                   private var numStringA:String = "8349.0750";
                   [Bindable]
                   private var numStringB:String = "136.4300";
                   // FYI: 8349.0750 + 136.4300 = 8485.505
                   public function val(s:String):Number {
                       var n:Number = new Number;
                       if (isNaN(parseFloat(s))){
                           n = 0
                       } else {
                           n = parseFloat(s);
                       trace('val: ' + s + '=' + n);
                       return n;
           </fx:Script>
           <mx:VBox>
               <mx:Text text="{dolFmt.format( val(numString1) )}" />
               <mx:Text text="{dolFmt.format( val(numStringA) + val(numStringB) )}" />
           </mx:VBox>
      </s:Application>
        • 1. Re: Formatter rounds - the same number - two different ways?
          AlHolden Level 1
          I should add that the frequently blogged "floating point" solutions DO NOT appear to help.
          For example, this modification does not appear to change the results:
                              n = 0
                          } else {
                              var hack:Number = Math.pow(10, 5);
                              n = Math.round(hack * parseFloat(s)) / hack;
                          return n;
          • 2. Re: Formatter rounds - the same number - two different ways?
            AlHolden Level 1
            Incorporating Josh's solution*  - after the simple addition step - seems to fix this example. I'm still hoping for something a little more elegant...
            * http://joshblog.net/2007/01/30/flash-floating-point-number-errors/
            Al
                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="200" minHeight="300" >
                <fx:Declarations>
                                         rounding="nearest"
                                         precision="2"
                </fx:Declarations>
                <fx:Script>
                    <![CDATA[
                        [Bindable]
                        [Bindable]
                        [Bindable]
                                n = 0
                            } else {
                                n = parseFloat(s);
                            //trace('val: ' + s + '=' + n);
                            return n;
                        public function correctFloatingPointError(number:Number, precision:int = 5):Number
                            var correction:Number = Math.pow(10, precision);
                            return Math.round(correction * number) / correction;
                </fx:Script>
                <mx:VBox>
                    <mx:Text text="{dolFmt.format( correctFloatingPointError(val(numStringA) + val(numStringB)) )}" />
                </mx:VBox>
            </s:Application>
            • 3. Re: Formatter rounds - the same number - two different ways?
              AlHolden Level 1
              OK, I am STILL not in a better place here...
              Consider that this example produces a proper result only the first three times - and floating point solutions don't seem to help:
              5.51
              85.51
              485.51
              8485.50
                  <fx:Declarations>
                                       rounding="nearest"
                                       precision="2"
                  </fx:Declarations>
                  <fx:Script>
                      <![CDATA[
                          [Bindable]
                          private var numString1:String = "5.5050";
                          [Bindable]
                          private var numString2:String = "85.5050";
                          [Bindable]
                          private var numString3:String = "485.5050";
                          [Bindable]
                          private var numString4:String = "8485.5050";
                  </fx:Script>
                  <mx:VBox>
                      <mx:Text text="{dolFmt.format( numString1 )}" />
                      <mx:Text text="{dolFmt.format( numString2 )}" />
                      <mx:Text text="{dolFmt.format( numString3 )}" />
                      <mx:Text text="{dolFmt.format( numString4 )}" />
                  </mx:VBox>
              </s:Application>
