Export to PDF, need untagged CMYK
Andrew Rodney Aug 31, 2011 7:17 AMWe are having an issue creating PDFs for prepress where we want untagged ECI profile targets to be specified as untagged (NOT SWOP or anything else). This worked in the past. I’m not sure if this is a 5.5 issue which I just upgraded couple months ago.
All the images opened in Photoshop OR from ID show they are untagged. But depending on what we set for Export, we might see the preflight panel in Acrobat indicate they are SWOP V2.
Here’s what I don’t understand. There are a few settings for export to PDF. The one selected (that in the past has always worked) was this:
It says (Description) CMYK colors that don’t have an embedded profile are left uncalibrated. I assume that means they are left untagged. And most are. Why the ECI’s are tagged I have to figure out.
The other pages are also TIFFs, solid colors (100% Cyan, Black etc). They don’t show up as SWOP. Strange!
But the setting below (Include Tagged Source Profiles) exports a PDF where SWOP isn’t embedded!
Here Description says Native colors that don’t have an embedded profile are left uncalibrated. That works on all images in the ID Export.
I also don’t know why this is now showing up unless its a bug or something new in ID5.5 which I upgraded a few months back.
Even the ID 5.5 help says this:
Don’t Include Profiles Does not create a color-managed document with embedded color profiles.
Include All Profiles Creates a color-managed document. If the application or output device that uses the Adobe PDF file needs to translate colors into another color space, it uses the embedded color space in the profile. Before you select this option, turn on color management and set up profile information.
Include Tagged Source Profiles Leaves device-dependent colors unchanged and preserves device-independent colors as the nearest possible equivalent in PDF. This is a useful option for print shops that have calibrated all their devices, used that information to specify color in the file, and are only outputting to those devices.
Include All RGB And Tagged Source CMYK Profiles Includes any profiles for tagged RGB objects and tagged CMYK objects, such as placed objects with embedded profiles. This option also includes the Document RGB profile for untagged RGB objects.
It seems either setting should treat the untagged ECI TIFFs as just that, untagged. Why are they tagged when exported to PDF while other documents are not?
