8 Replies Latest reply on Aug 31, 2011 6:38 PM by David1946dr
    Premiere Elements 9
    David1946dr
      I am going to buy a new lap top
      for editing Premiere Ele 9.  Is the Intel Corei5 2.3 Hz 4GB (1x4gb)ram 500gb 5400 hard drive intel gma hd 3000 graphics. it is Sony. Is this enough computer. If not does someone know what I need.
        • 1. Re: Premiere Elements 9
          First question is what are you going to EDIT on your computer?
          This message has a really good graphic about requirements
          http://forums.adobe.com/thread/810750?tstart=0
          Laptop Video Editing PC http://www.sagernotebook.com/
          -or http://www.adkvideoediting.com/systems/viewsystem.cfm?recordid=118
          -or another brand laptop with the following features
          -the newer sandy bridge 2720 or 2820 quad processor
          -and nvidia graphics preferably the 460m, 485m is a bit much
          -1280x900 display with OpenGL 2.0-compatible graphics card
          -and 8 or 16 gig ram and Win7 64bit Pro
          -and 2 internal 7200 HDDs minimum
          • 2. Re: Premiere Elements 9
            the_wine_snob Level 9
            What sort of material will you be editing?
            If any form of H.264, such as AVCHD, then I would strongly suggest an i7 CPU.
            For working with video, I also feel that the Intel graphics will not perform well. The problem is that Intel seldom issues updates to their video drivers, so they quickly become obsolete, and with video editing, virtually useless. Now, if Sony has good video driver support for the Intel chips, that would change my recommendation, but I rather doubt it. I would, instead, look for a laptop with either nVidia, or ATI/AMD chips.
            Last, and though I did not notice you mention it, most laptops have only 1 HDD (Hard Disc Drive), and that can be a real bottleneck. However, if you can add an eSATA connection, and pick up an eSATA external drive, or two, things should be just fine.
            • 3. Re: Premiere Elements 9
              David1946dr Level 1
              I video weddings
              Sent from my Android phone with K-9 Mail. Please excuse my brevity.
              • 4. Re: Premiere Elements 9
                >I video weddings
                Did you look at the requirements link I provided?
                Do not buy a toy computer for professional work (you ARE paid for this?)
                The question is not WHAT you video, but what KIND of video you plan to edit
                Even for SD (Standard Definition) video from a miniDV tape camera the laptop you listed is below specification (only one hard drive, and 5400rpm instead of 7200rpm)
                If you plan to edit any kind of HD (High Definition) video that laptop is WAY below specification
                Do some more reading about requirements, then tell us what KIND of video, not what is IN the video
                Trying to use only ONE Hard Drive for Video Editing
                You are a music conductor, with a baton that you use to point to various parts of the orchestra... this is like Windows pointing to various parts of the hard drive to do Windows housekeeping or to load program segments for various functions
                Now, at the same time and with the same hand... while still using the baton to conduct the orchestra... pick up a bow and play a fiddle... this would be doing something with your video file at the same time as all the other work
                You as a person cannot do both at the same time with the same hand
                A computer is a LITTLE better, in that it can switch from one kind of task to another very quickly... but not quickly enough for EASY video editing
                You need AT LEAST two hard drives (separate drives, never a partition http://forums.adobe.com/thread/650708?tstart=0 for more) with Windows (or Mac OS) and software on your boot drive, and video files on a 2nd drive so the boot drive is not slowed down by trying to do everything
                I find that the three drives I use work very well for me, for editing AVCHD video... some people use a 4th drive, so video INPUT files are on drive three and all OUTPUT files are on drive four... I only bought a mid-tower case instead of a full tower case (my bad... but had to fit in the space available on my office desk!) so I use the three drives that will fit
                Depending on your exact hardware (motherboard brand & model AND USB2 enclosure brand & model AND external hard drive brand & model) AND the type of video file, you may... or may NOT... be able to use an external USB2 hard drive for SD (Standard Definition) video editing
                Steve Grisetti in the Premiere Elements forum http://forums.adobe.com/thread/856208?tstart=0 and Jim Simon in the Premiere Pro forum http://forums.adobe.com/thread/856433?tstart=0 use USB externals for editing
                A USB3 hard drive connected to a motherboard with USB3 is supposed to be fast enough for video editing (I don't have such, so don't know) but eSata DOES have a fast enough data transfer for video editing... I have not used this eSata Dock... for reference only, YMMV and all the usual disclaimers
                http://www.amazon.com/Thermaltake-BlacX-eSATA-Docking-Station/dp/B001A4HAFS/ref=cm_cmu_pg_ t
                • 5. Re: Premiere Elements 9
                  David1946dr Level 1
                  I should have known that, about what kind of video. That's my ADD kicking
                  in. I video in (Standard Definition) video from a miniDV tape
                  Thank you,
                  David
                  In a message dated 8/31/2011 11:54:45 A.M. Eastern Daylight Time,
                  forums@adobe.com writes:
                  >I  video weddings
                  edit
                  not what is in the  video
                  • 6. Re: Premiere Elements 9
                    For SD, with a high speed external drive (USB3 or eSata) you will JUST BARELY be able to edit with that laptop
                    Just do not put any data files on the internal 5400rpm drive... too slow and trying to edit with only one drive is an exercise in futility
                    • 7. Re: Premiere Elements 9
                      Also, since any new computer will have Win7, you need to read...
                      Legacy Driver and Capture http://forums.adobe.com/thread/869277?tstart=0
                      - And a Picture http://forums.adobe.com/thread/727755?tstart=0
                      • 8. Re: Premiere Elements 9
                        David1946dr Level 1
                        Thank you,
                        David
                        In a message dated 8/31/2011 6:40:52 P.M. Eastern Daylight Time,
