1 2 Previous Next 56 Replies Latest reply on Jan 6, 2017 6:18 PM by mevynkerak11
    Export to PDF causes blacks to go grey.
    AdeptDigital Level 2
      Hello,
      I have been dealing with an issue involving the way InDesign exports to PDF.  In images and boxes drawn in InDesign the black value is being reduced to 95% while the text remains full black.  I thought it was a printer issue but I looked more carefully at the PDF and sure enough it's in the image I outputted to PDF format.  How would it be possible that the blacks in images and drawn boxes could loose the 100% black but not the text?  Do I have a bad install or just a setting misplaced?
      I am running CS5.5 with all the latest updates on a brand new Mac Book Pro.
      Brett
        • 1. Re: Export to PDF causes blacks to go grey.
          This seems pretty odd on a Mac as it sounds like the sort of thing that can happen when printing to PDF rather than exporting (no longer easy since Snow Leopard), and it's even odder that it affects drawn objects, but not type. What settings are you using for export?
          • 2. Re: Export to PDF causes blacks to go grey.
            Also, are there color objects inthe file? RGB Blacks?
            • 3. Re: Export to PDF causes blacks to go grey.
              Everyhting in the file is CMYK or Greyscale, the problem doesn't seem to care.  The real mystery to me is that the drawn object and images appear correctly in InDesign but not in the PDF version.  I am using the Highest Print settings without any downsampling or compression.  The file size is coming out to 4 or 5 mb for a two sided business card (which is pretty big) but the shades are still off.  I remeasured it in Photoshop and 100% CMYK is rendering to about 92% in the PDF version.
              Still a mystery.
              Brett
              • 4. Re: Export to PDF causes blacks to go grey.
                "Highest Print" settings does not correspond to any of the standard presets. I need to know exactly what is used, if one of the regular presets, or what you have in the Output pane of the export dialog.
                What do you see in the file if you roll over the black objects that are output at 95% if you open the Separations Preview in ID?
                • 5. Re: Export to PDF causes blacks to go grey.
                  I am using High Quality Print in the Export setting, in the Output pane I have No Color Conversion selected and Include Source Profiles.  When I check the individual area with the Seperation Preview I get 100% black on the problem areas.  I have the color set to the Black preset swatch from the swatches pull down menu.  By all outward indications I have it set for black, it just will not send black to the PDF.
                  The left side border is supposed to 100% black but the PDF render has it off.  This time the CMYK read 70,68,64,74 on the section in question and on the text.  To be honest I never sampled the text to be asolutley sure it was 100% I just went on looks.  So now I have a larger issue.
                  Even the supposed black section of the color scale at the top, something generated by InDesign, is not reading true black, it reads 75,68,67,90.
                  Any help in figuring this out would be great.
                  Brett
                  • 6. Re: Export to PDF causes blacks to go grey.
                    Something odd is going on. It looks like there's a profile conversion happeing in spite of the export settings.
                    Is it happening in all files, or just this one? Are you SURE you are using the default [Black] swatch?
                    • 7. Re: Export to PDF causes blacks to go grey.
                      I am possitive I am using the Black swatch and it is happening to all of my files.  The only ones I have in my system are ones created with this computer but yes all of the files I have from the last 3 months are exporting wrong.
                      • 8. Re: Export to PDF causes blacks to go grey.
                        Have you t4rashed your prefs? see Replace Your Preferences
                        • 9. Re: Export to PDF causes blacks to go grey.
                          Just trashed the prefs and it still happens.
                          • 10. Re: Export to PDF causes blacks to go grey.
                            Colin Flashman Adobe Community Professional
                            I've tried to replicate the fault here and the only way i can come close to doing this is: creating a new WEB document (rather than print document) and then preparing PDFs. Can't imagine something like this being overlooked, but that's the only way.
                            Is the OP able to package up the file using the package option from the file menu, and zip those files (plus a PDF made using the indesign file) and upload it somewhere... maybe using yousendit or something and then posting that yousendit link? We'd need to see what's being done because there's no way that artwork with vectors as taken in the OP's screengrab should produce a 5mb PDF.
                            • 11. Re: Export to PDF causes blacks to go grey.
                              FlippyTheClown Level 1
                              Thats a very odd problem. Just out of interest you haven't changed your transparency blend space options to RGB have you?
                              Just a thought, but that can cause screwy results.
                              You could always go old school. Export an EPS and distill it. Do they still make distiller?
                              Cheers.
                              • 12. Re: Export to PDF causes blacks to go grey.
                                I'd like to see a sample file, too.
                                • 13. Re: Export to PDF causes blacks to go grey.
                                  Sorry it took so long, got tied up yesterday.  Here is the sample file with the PDF compressed on a yousendit link.  It is just under 5mb and I checked and the intent of the file is set to print.
                                  Go here to download the file:
                                  https://www.yousendit.com/sharedFolder?phi_action=app/orchestrateSharedFolder&id=mbkx4fZ7u Hd_p77ZNEG6DnkP8hwopPzEiNKn18ENQNY
                                  I have several other working on the problem now and they are all scratching their heads.
                                  Brett
                                  • 14. Re: Export to PDF causes blacks to go grey.
                                    The PDF in your package reads fine here, and matches the colors in the .indd file perfectly. The graphic on the left on the second page is a four-color black starting out, as is the type in the logo on the lower right. Everything on page 1 is K-only in both ID and your PDF.
                                    • 15. Re: Export to PDF causes blacks to go grey.
                                      I have been in contact with my printer who opened the same sample file using her computer and sees the same PDF issue I have.  They also cannot get the PDF to print the proper color.  This whole issue started because they printed 1000 business cards and the black bar on the left printed up dark grey.  I checked and my suite is completely up to date as is the printer's suite.  We both subscribe to the Adobe packages, they have the design premium on a Mac running 10.6.8 and I hyave the Master Suite on the same OS.  I was going to upgrade to Lion this weekend but if this issue persists I may not want to.
                                      I also looked back at files created with my older MacBook running 10.5.8 with CS5 and the same issue occured on several documents that I am now going to need to rework for this same client.  What started as a curiousity is going to cost me time/money because I can't get a good idea of the problem.  A work around has been to build PNG image files in PS to replace the objects that are drawn but at this point I may just need to switch to PS and do my layout work there (not my favorite option).
                                      I am off to a photo shoot for the rest of the day but if anyone else can reproduce this issue on their machine please let me know.
                                      Brett
                                      • 16. Re: Export to PDF causes blacks to go grey.
                                        I think I figured out what's going on.
                                        You mentioned earlier that you are including ALL profiles. When you do this instead of choosing Tagged Source Profiles Acrobat is changing the numbers it displays in output preview depending on the simulation profile. If the simulation profile (and the output profile from Acrobat matches the document profile in ID you should see your 100% k.
                                        • 17. Re: Export to PDF causes blacks to go grey.
                                          Everything on page 1 of your posted PDF is on the black plate, so if you or your printer are printing to Composite Gray there will be a conversion from CMYK (0|0|0|100) to grayscale, which would typically get you 92% black if SWOP CMYK is the source. You need to print the black plate separation or composite CMYK to output the black values unchanged.
                                          • 18. Re: Export to PDF causes blacks to go grey.
                                            agree with peter's post - i can't fault your PDF to behave like it was in your earlier posts. if i'd have received your PDF at my work, it'd be fine (apart from the fact that there is a black keyline on the page border - naughty!).
                                            is there a step that we're not being told about here?
                                            • 19. Re: Export to PDF causes blacks to go grey.
                                              I think the PDF in the posted package was made without changing the settings to include ALL profiles, just to include the tagged source profiles which is part of the preset. I firmly believe that changing that setting is the root of the problem.
                                              • 20. Re: Export to PDF causes blacks to go grey.
                                                The conversion from 100% black to 92% black indicates there's a conversion to grayscale happening somewhere. It would be impossible to convert 0|0|0|100 CMYK to 0|0|0|92 CMYK when converting from one CMYK profile to another—there would always be CMY in the mix. If you set your PS Color Settings to the default and open the PDF with Grayscale set as the mode, the black converts to 93%
                                                • 21. Re: Export to PDF causes blacks to go grey.
                                                  True, but in Post 5 the OP mentions CMYK values for that 100% K block, which is where I think what I said was relevant.
                                                  • 22. Re: Export to PDF causes blacks to go grey.
                                                    miqrogroove Level 1
                                                    I seem to be having this same problem with the InDesign CS6 demo.
                                                    Did anyone figure out how to get it to export files correctly?
                                                    • 23. Re: Export to PDF causes blacks to go grey.
                                                      miqrogroove Level 1
                                                      I just now found a setting that fixed this for me.
                                                      Edit -> Transparency Blend Space
                                                      The default setting was "Document CMYK".  Changing it to "Document RGB" solved the problem for me.
                                                      Beware the file I'm working on is strictly a black and white (1-bit) TIFF with some text added.  Your results may vary!
                                                      • 24. Re: Export to PDF causes blacks to go grey.
                                                        miqrogroove Level 1
                                                        Now I'm finding that the PDF created using "Document RGB" looks fine on its own, but if I add it to another existing PDF it ends up looking grey again.  This is so confusing!
                                                        • 25. Re: Export to PDF causes blacks to go grey.
                                                          miqrogroove Level 1
                                                          Here is my solution:
                                                          After trying every conceivable combination of settings, I decided there was probably something wrong with the way I imported the original image.  I had imported it from a PDF, and perhaps that is where the bug lies with InDesign.  Luckily, I still had a copy of the original TIFF from before it was a PDF.  I re-imported the image into the indd file and then changed the following settings:
                                                          Edit -> Transparency Blend Space -> Document RGB
                                                          File -> Export -> Output
                                                            Color Conversion -> Convert to Destination (Preserve Numbers)
                                                            Destination -> sRGB IEC61966-2.1
                                                            Profile Inclusion Policy -> Don't Include Profiles
                                                          3 people found this helpful
                                                          • 26. Re: Export to PDF causes blacks to go grey.
                                                            The OP's job was printing on an offset press. You've converted your PDF to all sRGB, so if it's output to separations any black objects would print as 4-color not 100% black.
                                                            • 27. Re: Export to PDF causes blacks to go grey.
                                                              miqrogroove Level 1
                                                              Except for the part where it's a 1-bit file and it will print fine.  It's too bad this is such a convoluted process.
                                                              • 28. Re: Export to PDF causes blacks to go grey.
        I don't see any problem with 1-bit black or text black with a CMYK Transparency Blend Space, either in InDesign's Separation Preview or in Acrobat's Output Preview after exporting via the PDF/X-4 preset. In all cases output reads as 0|0|0|100 CMYK, which is what you would want and expect going to  press
        A placed all black 1-bit psd in ID
        Exported to PDF/X-4
        Are you outputting separations or to a composite printer? If composite  is your Print>Output>Color, Composite Gray or Composite CMYK?
        • 29. Re: Export to PDF causes blacks to go grey.
        miqrogroove Level 1
        Okay, I realize now that we are not talking about the same color.
        Rob Day is talking about some kind of press preview, whereas I am getting grey output on screen even if I try to use the PDF/X-4 preset.  Since the sRGB destination profile is unavailable in PDF/X-4, I have to use the ROMM-RGB profile as a workaround in that case.  This seems no less confusing than my previous workaround.
        • 30. Re: Export to PDF causes blacks to go grey.
        The OP's document is going to press—the destination is CMYK.
        If you are working for screen then set your document's intent as Web or Digital Publishing (File>Document Setup). In that case the  [Black] swatch, which by default is assigned to your placed 1-bit image, will be 0|0|0 black RGB and will stay that way on export to PDF. If you export to an RGB or Unchanged Color destination (PDF/X-4) the RGB black will be unchanged
        • 31. Re: Export to PDF causes blacks to go grey.
        miqrogroove Level 1
        Changing the Intent setting does nothing to resolve the problem.  Once again I am returning to the workaround I posted above.
        • 32. Re: Export to PDF causes blacks to go grey.
        miqrogroove Level 1
        Correction: Actually if I go all the way back to a new document with Intent set to Digital Publishing and then place the TIFF again, then it will export correctly!  Hooray!
        On the other hand, changing Intent from File -> Document Setup does not work as described on the existing file(s).
        So I have a somewhat better work around now, thank you Rob Day.
        • 33. Re: Export to PDF causes blacks to go grey.
        It sounds like your 1-bit images are not assigned the default black swatch [Black]. When you switch the intent to Web or Digital Publishing the default black swatch is converted to 0|0|0 RGB. A 0|0|0|100 black CMYK swatch you made would not necessarily convert to 0|0|0.
        If your 1-bit images are colored with a swatch other than [Black] open its swatch and change it to 0|0|0 RGB.
        • 34. Re: Export to PDF causes blacks to go grey.
        miqrogroove Level 1
        I have not created any swatches at all.  This is a simple 1-bit TIFF being placed in an InDesign document.  I can't believe how complicated this is becoming.  Let's just be happy that my new documents are working.
        • 35. Re: Export to PDF causes blacks to go grey.
        I cant't replicate your problem. Here's a 1-bit tif placed in a CMYK doc assigned with US Sheetfed Uncoated which exaggerates the gray black:
        Then converted to Web intent:
        Finally exported to Acrobat where the sRGB preview reads as 0|0|0:
        • 36. Re: Export to PDF causes blacks to go grey.
        miqrogroove Level 1
        As I said earlier, the export does work with new files.
        I invested an extraordinary amount of time fiddling with different settings and I've found that you should be able to replicate a problem with the Document Setup method by first setting the Transparency Blend Space to Document RGB, which I had done to my files as previously described.  Following that, a change of the Intent setting from Print to Web still results in greys instead of blacks at export.  For some reason, InDesign exports 1-bit images in a 4-channel CMYK format after that particular combination of settings.
        Your solution does work after I add another step:
        1. Open the document that has the image placed in it.
        2. Reset the Transparency Blend Space setting to Document CMYK.
        3. Change the Intent setting to Web or Digital Publishing.
        4. Export to PDF.
        • 37. Re: Export to PDF causes blacks to go grey.
        A 1-bit image takes on whatever color is assigned to it, so if you select the image and choose any RGB swatch  its source color will be rgb on export—the color doesn't have to be default CMYK black.
        Not sure why the default black swatch stays CMYK when the blend space is RGB and you change the document intent to Web.
        The blackness of a 0|0|0|100 CMYK object is dependent on the document's CMYK profile—US Sheetfed Uncoated shows black as gray because that's what happens on press—60|50|50|100 is blacker than 0|0|0|100.
        Some older profiles don't make the distinction, so if you set the assigned document CMYK profile to Photoshop Default CMYK and export to an RGB destination the default black swatch will convert to 0|0|0 RGB.
        • 38. Re: Export to PDF causes blacks to go grey.
        alvin.r.henson Level 1
        I know this is an old question, but I ran across the same issue today. If your black is set to CMYK (0, 0, 0, 100), it will export to pdf as dark gray. If you change your black to CMYK (60, 40, 40, 100), it will export as black. No need to change any output settings in InDesign. Very simple solution!
        • 39. Re: Export to PDF causes blacks to go grey.
        Right, most press CMYK profiles preview black + CMY differently than black only, which is what happens on an offset press. But a rich black mix would create a registration or trapping problem with small- to medium-sized text.
        1 2 Previous Next
