2 Replies Latest reply on Sep 1, 2011 2:31 AM by kokorito
    a sqlite problem
    Kristin95762 Level 1
      Hi
      I'm trying to retrieve the last authorID entered into my table.
      Here's my code:
      private function getNewAuthorID(event:SQLEvent):void
           getNewAuthorIDStmt = new SQLStatement();
           getNewAuthorIDStmt.sqlConnection = conn;
           var sql:String = "SELECT MAX(authorID) FROM authors3";
           getNewAuthorIDStmt.text = sql;
           getNewAuthorIDStmt.addEventListener(SQLEvent.RESULT, newAuthorIDResult);
           getNewAuthorIDStmt.execute();
      private function newAuthorIDResult(event:SQLEvent):void
           var result:SQLResult = getNewAuthorIDStmt.getResult();
           var numResults:int = result.data.length;
           trace("numResults: " + numResults);
           for (var i:int = 0; i < numResults; i++)
                var row:Object = result.data[i];
                var newAuthorID:int = row.authorID;
                trace(newAuthorID);
      I've gotten this code to work before but it was not contained in a class file, just a script block (don't know if that matters). The first trace function returns '1', but the second trace function returns'0'.
      I need to get the newly entered authorID so I can enter a book title into another table with the correct authorID.
      I don't want to use the lastInsertRowID() because my rowid's and author id's will not be the same.
      Kristin
        • 1. Re: a sqlite problem
          Nevermind. I found a different route.
               var result:SQLResult = insertNewAuthorDetailsStmt.getResult();
               var primaryKey:int = result.lastInsertRowID;
               trace(primaryKey);
          No, wait, still having a problem.
          I seem to be having a problem holding onto the value of the primaryKey. How do I perpetuate that value through the next sqlstatement? The trace function displays the correct ID. However, when I run an INSERT to enter data into the next table it inserts a '0'. I'm trying to enter data from one form into two different tables that have a common ID number.
          Kristin
          • 2. Re: a sqlite problem
            kokorito Level 4
            you declare primaryKey inside the function, so the scope is local and only exists inside the function.
            Declare the primaryKey as a class variable if you need to use it in other methods or pass it as a parameter
