Hi
I have just upgraded to RH9, an dhave the latest patch. I noticed that drop downs I have created don't work They did in RH8.
Here is the senerio
Any ideas
This is happing on 2 PCs one Windows 7 one XP both wiht the latest version of RH
Tim
Hi there
Perhaps you might try clicking Tools > Update DHTML Effects in Topics. Then recompile. Any difference?
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hi Rick
Thanks for that
I will try it. Just a point expanding text is also the same. I have tried in a brand new project (not upgraded) and it works fine. Let's hope you answer works.
Thanks again
Tim Emerson
Senior Technical Author
Trend Control Systems
Albery House
Springfield Road
Horsham
West Sussex
RH12 2PQ
United Kingdom
T:+44 (0)1403 226326
timothy.emerson@trendcontrols.com
Trend Control Systems Limited Ltd. Registration No: 1664519 (England and Wales).
Registered Address: Honeywell House, Arlington Business Park, Bracknell, RG12 1EB.
Email Confidentiality Notice ***** This email is private and confidential. If you have received this message in error, please notify the sender and delete it from your system.
ļ Please consider the environment before printing this e-mail
I assume you still have a backup of your RoboHelp 8 project. If not, first create a backup of the RoboHelp 9 project.
Try Tools > Update DHTML effects in topics. Does that solve your problem?
Greet,
Willam
Thanks. I still have the original project will try your suggestion.
I didn't know about the option
Tim Emerson
Albery House
Springfield Road
Horsham
West Sussex
RH12 2PQ
United Kingdom
Thanks to everyone for their help .
Unfortunately the solution does not work.
Anybody got any more ideas
Tim Emerson
Albery House
Springfield Road
Horsham
West Sussex
RH12 2PQ
United Kingdom
Try using one of the supplied sample projects. Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left. Do they have the same problem?
BTW. You might want to consider replying via the web interface if you cannot change your email signature. Your email address gets included in every reply and it is pretty standard forum advice (any forum) not to do that unless you enjoy reading spam.
Hi
I have tried a brand new project, and everyting works fine. I was woinderingif it may be someting to do with the stryle sheet. I have created my own styles etc. and my origingal css file is probably from several version of Robohelp ago
I have just noticed the footers I have on each page are missing as well<
Tim
I doubt it is the CSS but you can test that by using it in the new project.
I am wondering if you have a problem with the master page. Try removing the link in you main project and see if the dropdown starts working.
Hi Peter
Thanks for your help. I have solved the problem thanks to your help. The key was the master page. Once I unlinked the topic from the master page everything started working again.
I created a new master page whe the same items on an used that and now everyting works as I would expect.
Tim
