2 Replies Latest reply on Sep 1, 2011 10:36 AM by mihksoft
    External Interface
    mihksoft Level 1
      Any answer to this problem?
      I have an application with a button and on the click handler I have
      var s:String;
      if (ExternalInterface.available) {
         var wrapperFunction:String = "getString";
         s = ExternalInterface.call(wrapperFunction);
      } else {
         s = "Wrapper not available";
      trace(s);
      If I run the application from Flash Builder I get the string from "getString"
      java script function.
      If I change the string and I run the application outside of IDE the string is
      not changed, remain the same with the one from run of the IDE.
      Best Regards,
      Mihai
        • 1. Re: External Interface
          Flex harUI Adobe Employee
          What browser and URL are you using to run outside of the IDE?  Could be a
          security issue.  If you run the HTML/SWF from the same place the IDE puts
          it, it should work, but if you move it, there might be different security
          rules.
          • 2. Re: External Interface
            mihksoft Level 1
            I have the same path like when I run it from IDE.
            I used Chrome 13.0...
            IE 8 fails to load show the swf.
            Firefox 6.0
            Here is the HTML file:
            <html lang="en">
            <head>
            <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
            <title></title>
            <script language="JavaScript" type="text/javascript">
            </script>
            </head>
            <body scroll="no">
                function getString() {
                    return "dasdsa dad23 323 ";
            </script>
              <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
            id="CopyButton" width="100%" height="100%"
            codebase="http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
            <param name="movie" value="CopyButton.swf" />
            <param name="quality" value="high" />
            <param name="bgcolor" value="#869ca7" />
            <param name="allowScriptAccess" value="sameDomain" />
            <embed src="CopyButton.swf" quality="high" bgcolor="#869ca7"
            width="100%" height="100%" name="CopyButton" align="middle"
            play="true"
            loop="false"
            quality="high"
            allowScriptAccess="sameDomain"
            type="application/x-shockwave-flash"
            pluginspage="http://www.adobe.com/go/getflashplayer">
            </embed>
            </object>
            </body>
            </html>
