2 Replies Latest reply on Sep 6, 2011 2:44 AM by Neat Gadget
    Set row text color in datagrid
    Neat Gadget Level 1
      I have a datagrid showing a number of rows of data. Some rows of data are "inactive" data so I want to display those rows in a different text color .Any ideas on how to do this?
        • 1. Re: Set row text color in datagrid
          Neatgadgets Level 1
          Ok I found this and it worked!
          Thanks to Phil Flash whomever you might be.
          http://www.ancorarflatresort.com.br/ingles/HtmlCellRenderer.as
          // Html Cell Renderer
          // by PhilFlash - http://philflash.inway.fr
          // version 1.30 : 15 Sep 2005
          //   - version compatible Flash MX 2004 et Flash 8
          //   - amélioration
          // version 1.25 : 12 Jan 2004
          //   - style_sheet devient une variable statique pour optimisation
          //     sur chargement
          // version 1.2 : 22 Dec 2003
          //   - la sélection (highlight) apparait sur ce type de cellule
          // version 1.1 : 7 Nov 2003
          //   - correction d'un bug sur le scroll
          // version 1.0 : 20 Oct 2003
          //   - version initiale
          // Dont't forget :
          // - to create a new symbol in Flash MX2004
          //   Insert > New Symbol
          //   with properties :
          //    Name : HtmlCellRenderer
          //    Behavior : MovieClip : Checked
          //   For Linkage:
          //    Identifier: HtmlCellRenderer
          //    AS 2.0 Class : HtmlCellRenderer
          //    Export for Actionscript : Checked
          //    Export for in first frame : Checked
          // Example:
          //   Column:
          //   var col:mx.controls.gridclasses.DataGridColumn;
          //   col = amazon_grd.getColumnAt(0);
          //   col.width = 200;
          //   col.cellRenderer = "HtmlCellRenderer";
          //   col["htmlFunction"] = amazonHtmlFunction;
          //   Header:
          //   col.headerText = "<author>Book:</author>";
          //   col.headerRenderer = "HtmlCellRenderer";
          import mx.core.UIComponent;
          import mx.controls.TextArea;
          import TextField.StyleSheet;
          class HtmlCellRenderer extends UIComponent
               static public var CssUrl:String;          // Global: URL for CSS stylesheet
               static public var style_sheet:StyleSheet = null;
               var htmlComponent:TextField;
               var owner; // The row that contains this cell
               var listOwner : MovieClip;   // the reference we receive to the list
               var getCellIndex : Function; // the function we receive from the list
               var     getDataLabel : Function; // the function we receive from the list
               var previousLabel:String = null; // for optimization
               function HtmlCellRenderer()
               function createChildren(Void) : Void
                    if (CssUrl != undefined && style_sheet == null)
                         style_sheet = new TextField.StyleSheet();
                         style_sheet.load(CssUrl);
                    if (htmlComponent == undefined)
                         createLabel("htmlComponent", 1);
                    htmlComponent.html = true;
                    htmlComponent.border = false;
                    htmlComponent.multiline = true;
                    htmlComponent.wordWrap = true;
                    htmlComponent.selectable = false;
                    htmlComponent.background = false;
                    htmlComponent.styleSheet = style_sheet;
                    size();
               // note that setSize is implemented by UIComponent and calls size(), after setting
               // __width and __height
               function size(Void) : Void
                    htmlComponent.setSize(__width-2, __height-2);
               function setValue(str:String, item:Object, sel:Boolean) : Void
                    // Ligne vide ou Header
                    if (item == undefined)
                         // Special case for headerRenderer
                         htmlComponent.htmlText = str;
                         previousLabel = null;
                         return;
                    var columnIndex = this["columnIndex"]; // private property (no access function)
                    var columnName = getDataLabel();
                    var htmlFunction : Function = listOwner.getColumnAt(columnIndex).htmlFunction;
                    if (htmlFunction != undefined)
                         var label = htmlFunction(item, columnName);
                         if (label != undefined)
                              // Important pour optimisation
                              // Empêche un flip-flop des images
                              if (label != previousLabel)
                                   htmlComponent.htmlText = previousLabel = label;
                         else
                              htmlComponent.htmlText = "";
                    else
               function getPreferredHeight(Void) : Number
                    if (owner == undefined) return 18;
                    return owner.__height - 2;
               //function getPreferredWidth :: only really necessary for menu
          • 2. Re: Set row text color in datagrid
            Neat Gadget Level 1
            Ideally I would prefer something where you don't have to create html around the data. Because I use the data to fill out a form and it would mean formatting and then stripping the data. But for now at least I have a partial solution.
