I am trying to call a web service with the following definition in the WSDL
<s:element name="CreateDataList">
<s:complexType>
<s:sequence>
<s:element minOccurs="0" maxOccurs="1" name="client_app_id" type="s:string"/>
<s:element minOccurs="0" maxOccurs="1" name="client_app_pwd" type="s:string"/>
<s:element minOccurs="1" maxOccurs="1" name="data_template_id" type="s:int"/>
<s:element minOccurs="1" maxOccurs="1" name="calculate_persistent_values" type="s:int"/>
<s:element minOccurs="0" maxOccurs="1" name="data" type="tns:ArrayOfArrayOfName_value"/>
</s:sequence>
</s:complexType>
</s:element>
<s:complexType name="ArrayOfArrayOfName_value">
<s:sequence>
<s:element minOccurs="0" maxOccurs="unbounded" name="record" type="tns:ArrayOfName_value"/>
</s:sequence>
</s:complexType>
<s:complexType name="ArrayOfName_value">
<s:sequence>
<s:element minOccurs="0" maxOccurs="unbounded" name="variable" type="tns:name_value"/>
</s:sequence>
</s:complexType>
<s:complexType name="name_value">
<s:sequence>
<s:element minOccurs="0" maxOccurs="1" name="name" type="s:string"/>
<s:element minOccurs="0" maxOccurs="1" name="value" type="s:string"/>
</s:sequence>
</s:complexType>
I am trying to format the ArrayOfArrayOfName_value data and getting an "argument type mismatch" error. The sample PHP code for the data looks like this:
$data = array(0 => array(
array('name' => 'FIRST_NAME', 'value' => 'First'),
array('name' => 'LAST_NAME', 'value' => 'Last'),
array('name' => 'ADDRESS', 'value' => 'Address'),
array('name' => 'CITY', 'value' => 'City'),
array('name' => 'STATE', 'value' => 'State'),
array('name' => 'ZIP', 'value' => '55555')
1 => array(
My CF code looks like this:
<cfset data = ArrayNew(1) />
<cfset data[1] = ArrayNew(1) />
<cfset data[1][1] = StructNew() />
<cfset data[1][1]["name"] = "NAME" />
<cfset data[1][1]["value"] = "JOhn Doe" />
<cfset data[1][2] = StructNew() />
<cfset data[1][2]["name"] = "ADDRESS1" />
<cfset data[1][2]["value"] = "123 Test St" />
<cfset data[1][3] = StructNew() />
<cfset data[1][3]["name"] = "ADDRESS2" />
<cfset data[1][3]["value"] = "" />
<cfset data[1][4] = StructNew() />
<cfset data[1][4]["name"] = "CITY" />
<cfset data[1][4]["value"] = "Austin" />
<cfset data[1][5] = StructNew() />
<cfset data[1][5]["name"] = "STATE" />
<cfset data[1][5]["value"] = "TX" />
<cfset data[1][6] = StructNew() />
<cfset data[1][6]["name"] = "ZIP" />
<cfset data[1][6]["value"] = "78704" />
<cfset data[2] = ArrayNew(1) />
<cfset data[2][1] = StructNew() />
<cfset data[2][1]["name"] = "NAME" />
<cfset data[2][1]["value"] = "Jane Doe" />
<cfset data[2][2] = StructNew() />
<cfset data[2][2]["name"] = "ADDRESS1" />
<cfset data[2][2]["value"] = "987 Test St" />
<cfset data[2][3] = StructNew() />
<cfset data[2][3]["name"] = "ADDRESS2" />
<cfset data[2][3]["value"] = "" />
<cfset data[2][4] = StructNew() />
<cfset data[2][4]["name"] = "CITY" />
<cfset data[2][4]["value"] = "Austin" />
<cfset data[2][5] = StructNew() />
<cfset data[2][5]["name"] = "STATE" />
<cfset data[2][5]["value"] = "TX" />
<cfset data[2][6] = StructNew() />
<cfset data[2][6]["name"] = "ZIP" />
<cfset data[2][6]["value"] = "78704" />
Any suggestions for where I am going wrong would be greatly appreciated.
If anyone is interested here is the correct CF format for this WSDL complex type definition
<cfset data = StructNew() />
<cfset data["record"] = ArrayNew(1) />
<cfset data["record"][1] = StructNew() />
<cfset data["record"][1]["variable"] = ArrayNew(1) />
<cfset data["record"][1]["variable"][1] = StructNew() />
<cfset data["record"][1]["variable"][1]["name"] = "NAME" />
<cfset data["record"][1]["variable"][1]["value"] = "John Doe" />
<cfset data["record"][1]["variable"][2] = StructNew() />
<cfset data["record"][1]["variable"][2]["name"] = "ADDRESS1" />
<cfset data["record"][1]["variable"][2]["value"] = "123 Test St" />
<cfset data["record"][1]["variable"][3] = StructNew() />
<cfset data["record"][1]["variable"][3]["name"] = "ADDRESS2" />
<cfset data["record"][1]["variable"][3]["value"] = "" />
<cfset data["record"][1]["variable"][4] = StructNew() />
<cfset data["record"][1]["variable"][4]["name"] = "CITY" />
<cfset data["record"][1]["variable"][4]["value"] = "Austin" />
<cfset data["record"][1]["variable"][5] = StructNew() />
<cfset data["record"][1]["variable"][5]["name"] = "STATE" />
<cfset data["record"][1]["variable"][5]["value"] = "TX" />
<cfset data["record"][1]["variable"][6] = StructNew() />
<cfset data["record"][1]["variable"][6]["name"] = "ZIP" />
<cfset data["record"][1]["variable"][6]["value"] = "78704" />
<cfset data["record"][2] = StructNew() />
<cfset data["record"][2]["variable"] = ArrayNew(1) />
<cfset data["record"][2]["variable"][1] = StructNew() />
<cfset data["record"][2]["variable"][1]["name"] = "NAME" />
<cfset data["record"][2]["variable"][1]["value"] = "Jane Doe" />
<cfset data["record"][2]["variable"][2] = StructNew() />
<cfset data["record"][2]["variable"][2]["name"] = "ADDRESS1" />
<cfset data["record"][2]["variable"][2]["value"] = "987 Test St" />
<cfset data["record"][2]["variable"][3] = StructNew() />
<cfset data["record"][2]["variable"][3]["name"] = "ADDRESS2" />
<cfset data["record"][2]["variable"][3]["value"] = "" />
<cfset data["record"][2]["variable"][4] = StructNew() />
<cfset data["record"][2]["variable"][4]["name"] = "CITY" />
<cfset data["record"][2]["variable"][4]["value"] = "Austin" />
<cfset data["record"][2]["variable"][5] = StructNew() />
<cfset data["record"][2]["variable"][5]["name"] = "STATE" />
<cfset data["record"][2]["variable"][5]["value"] = "TX" />
<cfset data["record"][2]["variable"][6] = StructNew() />
<cfset data["record"][2]["variable"][6]["name"] = "ZIP" />
<cfset data["record"][2]["variable"][6]["value"] = "78704" />
