3 Replies Latest reply on Sep 22, 2011 4:19 PM by kglad
    ArgumentError: Error #2109: Frame label <BUTTON INSTANCE NAME> not found in scene <SCENE NAME>.
    Level 1
      I'm getting this error in the OUTPUT window, when I PREVIEW (COMMAND + RETURN) my SWF:
      ArgumentError: Error #2109: Frame label nGallery_btn not found in scene Scene 1.
      at flash.display::MovieClip/gotoAndStop()
      at BrookBrovazMusic004_fla::MainTimeline/pageSelect()
      • The funny thing is that the SWF works the way I want it to. You can view it here:  http://brookbrovaz.com
      • I just don't like the idea that something's wrong, according to the OUTPUT window anyway.
      Here is the code found in Frame 1, Scene 1 (My flash file only has one scene, called 'Scene 1').
      START AS3 CODE:
      //page transitions
      import fl.transitions.*;
      import fl.transitions.easing.*;
      TransitionManager.start(nPageHome,{type:Fly,direction:Transition.IN,duration:2,easing:Stro ng.easeOut})
      TransitionManager.start(nPageHome,{type:Blinds,direction:Transition.IN,duration:2,easing:S trong.easeOut});
      stop();
      nHome_btn.addEventListener (MouseEvent.CLICK,pageSelect);
      nMusic_btn.addEventListener (MouseEvent.CLICK,pageSelect);
      nGallery_btn.addEventListener (MouseEvent.CLICK,pageSelect);
      nContact_btn.addEventListener (MouseEvent.CLICK,pageSelect);
      function pageSelect(evtObj:MouseEvent) {
      gotoAndStop(evtObj.target.name);
      //original navigation
      nHome_btn.addEventListener (MouseEvent.CLICK,play1);
      function play1(event:MouseEvent):void{
      gotoAndStop("f01");
      nMusic_btn.addEventListener (MouseEvent.CLICK,play2);
      function play2(event:MouseEvent):void{
      gotoAndStop("f02");
      nGallery_btn.addEventListener (MouseEvent.CLICK,play3);
      function play3(event:MouseEvent):void{
      gotoAndStop("f03");
      nContact_btn.addEventListener (MouseEvent.CLICK,play4);
      function play4(event:MouseEvent):void{
      gotoAndStop("f04");
      END AS3 CODE.
      • I just want to figure out how to NOT get the error anymore. Cause again, everything seems to be working right.
      Again, any and all help is very much appreciated.
