3 Replies Latest reply on Sep 6, 2011 7:41 AM by Alex_Birchler
    rtmp
    Alex_Birchler Level 1
      Hi
      I have a video player and a plugin that listen all the events from that video player
      with VOD is working good, but once I want to run a rtmp, I can´t do run that plugin, why?
      The rtmp address for example is :
      rtmp://aljazeeraflashlivefs.fplive.net:1935/aljazeeraflashlive-live/aljazeera_english_2
      the plroblem is that I can´t listen the events
      I get this error message:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      thanks
        • 1. Re: rtmp
          Silviu Vergoti Adobe Employee
          Hi Alex,
          I can't tell without tracing through the code.
          I hope the next questions will help you pinpoint the solution:
          - Are other traits loaded / not loaded / available when you start your listeners?
          - are all the events available?
          - do you listen on events from mediaplayer or individual traits?
          - do you use proxy elements or complex (serial, parallel) elements?
          • 2. Re: rtmp
            Hi
            thanks for answer
            when I am using video with http format I can lisent every event
            I need to get video name, for example, bitrate and other events that I can listen from http video
            this is my code:
            from player:
            I am using SMP player
            from plugin:
            public function CDNPluginInfo()
                        trace("CDNPluginInfo <------ 05 sep" );
                        var items:Vector.<MediaFactoryItem> = new Vector.<MediaFactoryItem>();
                        var item:MediaFactoryItem = new MediaFactoryItem
                        ("CDNPlugin"
                        ,canHandleResourceFunction
                        ,mediaElementCreationFunction
                        items.push(item);
                        super(items, creationNotificationFunction);
                    private function canHandleResourceFunction(resource:MediaResourceBase):Boolean
                        return true;
                    private function mediaElementCreationFunction():MediaElement
                        return new VideoElement();
                    public function creationNotificationFunction(media:MediaElement):void
                        ObtenerDataSMP(media); //here we begin
            • 3. Re: rtmp
              Hi
              I found the problem
              and fixed it
              now I have another question
              How can I get the bitrate from a rtmp file?
              thanks
