14 Replies Latest reply on Apr 3, 2015 2:01 PM by Omita
    UIImpersonator tests work in FlashBuilder, but not when run from Ant
    Chris Lilley
      I'm in the process of converting a Flex 3 project to use FlexUnit4 tests.
      Everything compiles in Flashbuilder 4.5 and runs nicely. I've converted all the tests
      to use flexunit 4, which highlighted a few issues, but nothing too major, and all the
      tests now pass when run in Flashbuilder.
      So... now, I'm trying to convert the CI build to use the 4.5 SDK and flexunit4. So far,
      so good. Everything runs and I get a nicely formatted JUnit report. Unfortunately, though,
      any test that uses the UIImpersonator fails with an async method timeout, suggesting that
      the CreationComplete event hasn't fired.
      Here's a typical example of one of my UI test cases:
                [Test(async, ui)]
                public function testAvailableProductsSetupAdminForSell() : void {
                     var view:OrderBasketView = new OrderBasketView();
                     var user:CfxUser = new CfxUser();
                     user.admin = true;
                     ModelLocator.instance.userDetails = user;
                     view.buyOrSell = OrderType.SELL;
                     helper.createComponentAndAddListener(view, this, availableProductSetupAdminForSellCreationComplete);
                private function availableProductSetupAdminForSellCreationComplete(event:Event, view:OrderBasketView) : void {
                     Assert.assertTrue(view.availableProductTypes.contains(ProductType.PRODUCT_1));
                     Assert.assertTrue(view.availableProductTypes.contains(ProductType.PRODUCT_2));
                     Assert.assertTrue(view.availableProductTypes.contains(ProductType.PRODUCT_3));
      and helper.createComponentAndAddListener looks like this:
              public function createComponentAndAddListener(view:UIComponent, testCase:Object, creationComplete:Function) : void {
                     _view = view;
                     _view.addEventListener(FlexEvent.CREATION_COMPLETE, Async.asyncHandler(testCase, creationComplete, 4000, _view));
                     UIImpersonator.addChild(_view);
      If I use FlexGlobals.topLevelApplication.parent.addChild(_view) in place of UIImpersonator.addChild(_view), all the tests pass.
      I was wondering if it's a function of the fact that my helper class has no metadata that indicates it's a ui test, but that wouldn't explain why it works in FlashBuilder and not when run with ant.
      I also wondered if it was a function of running with headless server set to true, but when I changed it to false the same thing happened.
      My environment is:
      ubuntu 11.04
      ant 1.7.1
      Sun jdk 1.6.0_26
      Flex SDK 4.5.1.21328
      FlexUnit 4.1.0-8-4.1.0.16076
      I'm using the auto-generated TestRunner.mxml
      Any thoughts, anyone? Now that I can get it to work by adding the UI components to the topLevelApplication, at least I can make progress, but I'd like to get to the bottom of the problem, because that shouldn't be necessary.
      Thanks in advance,
      -Chrisl
        • 1. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
          Michael Labriola Level 4
          just clarifying. even the ui tests work in flash builder but fail in the ci server environment unchanged
          • 2. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
            Chris Lilley Level 1
            Hi Michael, thanks for the quick reply!
            Yes, that's correct.
            Non-UI tests pass in flashbuilder, and pass in the CI environment.
            UI tests pass in flash builder, but fail in the CI environment when using UIImpersonator.
            UI tests pass in flash builder, and also pass in the CI environment when using topLevelApplication.
            Obviously it's ugly having the UI components added to topLevelApplication, but it's the only thing I've found that will get my tests to pass under ant.
            • 3. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
              okay i will try to replicate. the uiimpersonator is effectively a container or a group added to the system manager to receive those children. in the short term do the top level app hack or make a singelton container attached to the app. i will hopefully figure this out for you today but i confirmed our ui tests are working in our ci environment so it might not be straight forward.
              • 4. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                Cool, thanks. if you need help replicating or more information about environment etc etc, please let me know. I'll be happy to help out.
                • 5. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                  ccdfroggman2k
                  Has anyone had a chance to find out why this is happening? I ran into this today as well. The UIImpersonator stuff runs like gangbusters with a UIListener but failed spectacularly in our CI environment.
                  Any update would be welcome and helpful and appreciated!
                  • 6. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                    Just as another data point, what is your CI system. And if it is headless, how are you handling the display presently?
                    Mike
                    • 7. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                      ccdfroggman2k Level 1
                      Our CI is Hudson, and we are running the flex tasks headless. In our build.xml file we run the debugPlayer for unix using the following path: ${FLEX_HOME}/runtimes/player/10.1/lnx/flashplayerdebugger... This works great with all unit tests that don't use UIImpersonator.
                      I just tried the workaround listed here and am waiting for an executor to build on to see if that worked... Will post when I know.
                      If that didn't answer your question, feel free to let me know. And thanks for the quick reply!!
                      • 8. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                        Changing to the topLevelApplication did not work. What's funny is that it then failed on a completely unrelated test by hanging and never returning... I'm thinking there must be something else that is going on here, but it's not clear what... :-/ Here is an example of my setup/teardown and a test that work great in the UI but not in CI...
                        [Before(async, ui)]
                        public function setUp():void
                            _fromToList = new FromToList();
                            _fromToList.setStyle('skinClass', FromToListSkin);
                            Async.proceedOnEvent(this, _fromToList, FlexEvent.CREATION_COMPLETE, 1000);
                            FlexGlobals.topLevelApplication.parent.addChild(_fromToList);
                            // UIImpersonator.addChild(_fromToList);
                        [After(ui)]
                        public function tearDown():void
                            FlexGlobals.topLevelApplication.parent.removeChild(_fromToList);
                            // UIImpersonator.removeChild(_fromToList);
                            _fromToList = null;
                        [Test(async)]
                        public function should_remove_selected_item_in_to_list_to_from_list():void
                            _fromToList.fromArrayList = _dpArray;
                            _fromToList.toArrayList = _toDpArray;
                            var sequence:SequenceRunner = new SequenceRunner(this);
                            sequence.addStep(new SequenceSetter(_fromToList.toList, { selectedItem: _toDpArray[1]}));
                            sequence.addStep(new SequenceWaiter(_fromToList.toList, FlexEvent.VALUE_COMMIT, 100));
                            sequence.addStep(new SequenceCaller(_fromToList, _fromToList.remove));
                            sequence.addStep(new SequenceWaiter(_fromToList, FromToListChangeEvent.FROM_TO_LIST_CHANGE_EVENT, 100));
                            sequence.addAssertHandler(handleListHasChangedThenRemoveEvent, {});
                            sequence.run();
                        private function handleListHasChangedThenRemoveEvent(event:FromToListChangeEvent, passThruData:Object):void
                            assertThat(_fromToList.toArrayList.length, equalTo(_toDpArray.length - 1));
                            assertThat(_fromToList.fromArrayList.length, equalTo(_dpArray.length - _toDpArray.length + 1));
                            assertTrue(_fromToList.fromArrayList.contains(_toDpArray[1]));
                        So you can see that I'm using Sequences to manage waiting for stuff to get updated in the background, and basically testing when I select an item in a list and act on it that it updates the model like I expect. Again, works GREAT in the UI Runner.
                        I'm open to suggestions...
                        • 9. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                          What if you just remove the sequence stuff, in other words:
                          [Before(async, ui)]
                          [After(ui)]
                              //FlexGlobals.topLevelApplication.parent.removeChild(_fromToList);
                              _fromToList = null;
                          [Test(async)]
                               //leave me blank
                          Does it complete the test or timeout?
                          Mike
                          • 10. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                            I setup my FlexBuilder (4.5) to run the ant task in my windows environment. When I did that, I'm seeing the following exception get thrown (which is probably causing the hang):
                            Error: Skin for FromToList132.FromToListSkin133.VGroup134.fromList cannot be found.
                                at spark.components.supportClasses::SkinnableComponent/attachSkin()[E:\dev\4.x\frameworks\pr ojects\spark\src\spark\components\supportClasses\SkinnableComponent.as:632]
                                at spark.components.supportClasses::SkinnableComponent/validateSkinChange()[E:\dev\4.x\frame works\projects\spark\src\spark\components\supportClasses\SkinnableComponent.as:405]
                                at spark.components.supportClasses::SkinnableComponent/commitProperties()[E:\dev\4.x\framewo rks\projects\spark\src\spark\components\supportClasses\SkinnableComponent.as:419]
                                at spark.components.supportClasses::ListBase/commitProperties()[E:\dev\4.x\frameworks\projec ts\spark\src\spark\components\supportClasses\ListBase.as:785]
                                at spark.components::List/commitProperties()[E:\dev\4.x\frameworks\projects\spark\src\spark\ components\List.as:907]
                                at mx.core::UIComponent/validateProperties()[E:\dev\4.x\frameworks\projects\framework\src\mx \core\UIComponent.as:7933]
                                at mx.managers::LayoutManager/validateProperties()[E:\dev\4.x\frameworks\projects\framework\ src\mx\managers\LayoutManager.as:572]
                                at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.x\frameworks\projects\framewo rk\src\mx\managers\LayoutManager.as:730]
                                at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.x\frameworks\projects \framework\src\mx\managers\LayoutManager.as:1072]
                            This might be off-topic for the original post and if so I'm happy to start a new one. This looks like when I try to set the skinClass, it doesn't like what is in that class... This is our first spark component to get unit tests wrapped around it... It errors with "Skin for FronToList132 cannot be found." if you don't include the skin at all.
                            I now suspect that once I figure out the skin thing, that the sequence tests and UIImpersonator will run fine. I'm assuming the skin issue is related to running headless, but we can't be the only ones who have done this... Again, let me know if this is really a different topic.
                            Thanks for the help!
                            • 11. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                              Vit_Tam
                              I had the same problem. For Continuous Integration with Ant and Hudson I've found working this code:
                                      // this works _only_ for GUI runner
                                      // UIImpersonator.addChild(myComp)
                                      // this works for CI:
                                      Application.application.parent.addChild(myComp);
                              I couldn't firure out how to report this bug to FU team, but maybe I didn't try too hard.
                              Hoppe they will fix this soon.
                              • 12. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                                TomKordys Level 1
                                If you are getting problems with UIImpersonator throwing errors make sure you point to
                                as3 version of flexunit swc not the flex one if it is as project.
                                • 13. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                                  rescueme911 Level 1
                                  Hey Chris Lilley,
                                  Can you explain me that how can i use this i didn't understand what is this.UIImpersonator tests work in FlashBuilder, but not when run from Ant
                                  Also i want to know where this code is to be applied. Please help me ?
                                  Thanks & Regards,
                                  rescueme911
                                  • 14. Re: UIImpersonator tests work in FlashBuilder, but not when run from Ant
                                    Omita
                                    UIImpersonator has been a complete pain for us.  Here is what we have noted so far:
                                    If you are using an older version of the FlexSDK which is using FlexUnit 4.1 expect the UIImpersonator to function but NOT have a stage.  Now, having said that, if you run your Test inside of FlashBuilder 4.7 your test will not run because FlashBuilder does not generate a suite that actually sets up the UIImpersonator correctly.  You can work around this:
                                    1) You can paste in the following code in your FlexUnitApplication.as file.  Naturally this is not idea:
                                    // Set up org.fluint.uiImpersonation.UIImpersonator
                                    VisualTestEnvironmentBuilder.getInstance(this.stage);
                                    2) Or you can modify the FlexUnitTestRunnerUIAS class but then you also have to rebuild a swc and then distribute the fix your your team.
                                    However, you still have the problem that your test build by ANT will still fail if they need access to the stage, or test code which listens for "onAddedToStage"...
                                    I would love for more of this information to be shared because if your are like me your work involved getting a legacy Flash application under test.
