1 Reply Latest reply on Sep 5, 2011 8:40 AM by kokorito
    Flex+PHP
    ReboloMen
      I have a file you want to connect to a database and insert into the databaseMyPHPAdmin multiple serial numbers while the code I was using this but would not give me even to get all the serial numbers associated with a code material and then enter multiple serial numbers for a given product code.
      Please Help me the code is below ..
      Thank response ..
      <?php
      require_once("../util/Ligacao.php");
      require_once("../vo/MaterialFactorVo.php");
      class OperacoesMaterial
      public $con;
      public function OperacoesMaterial()
        $this->con    = new Ligacao();
      public function findAll()
      $query = "select * from material";
      $exec = mysql_query($query,$this->con->getConnection());
      $xml = '<?xml version="1.0" encoding="UTF-8"?><root>';
      while($dados = mysql_fetch_assoc($exec))
                      $xml .= "<material_factor>";
                      $xml .= "<ID>".$dados['ID']."</ID>";
                      $xml .= "<Codigo>".$dados['Codigo']."</Codigo>";
                      $xml .= "<Descricao>".$dados['Descricao']."</Descricao>";
                      $xml .= "<ControlaStocks>".$dados['ControlaStocks']."</ControlaStocks>";
      $xml .= "<ValorMaterial>".$dados['ValorMaterial']."</ValorMaterial>";
      $xml .= "<StockRuptura>".$dados['StockRuptura']."</StockRuptura>";
      $xml .= "<Unidade>".$dados['Unidade']."</Unidade>";
      $xml .= "<UnidadeStockRuptura>".$dados['UnidadeStockRuptura']."</UnidadeStockRuptura>";
      $xml .= "<StockExistente>".$dados['StockExistente']."</StockExistente>";
      $xml .= "<CodigoLocalizacao>".$dados['CodigoLocalizacao']."</CodigoLocalizacao>";
      $xml .= "<TipoLocalizacao>".$dados['TipoLocalizacao']."</TipoLocalizacao>";
      $xml .= "<Data_Material>".$dados['Data_Material']."</Data_Material>";
      $sql2 = "select * FROM serie WHERE Cod_Material = ".$dados['Codigo']."";
      $exec_now = @mysql_query($sql2,$this->con->getConnection());
      $xml2 = '<root2>';
      if ($row = @mysql_fetch_assoc($exec_now))
      $xml2 .= "<serie_factor>";
                     $xml2 .= "<ID>".$row['ID']."</ID>";
                     $xml2 .= "<Cod_Material>".$row['Cod_Material']."</Cod_Material>";
                     $xml2 .= "<Serie>".$row['Serie']."</Serie>";
                      $xml2 .= "</serie_factor>";
      $xml2 .= "</root2>";
      $xml .= "<ArraySeries>".$xml2."</ArraySeries>";
                      $xml .= "</material_factor>";
      $xml .= "</root>";
      return $xml;
      public function insert(MaterialFactorVo $materialFactorVo)
      $query = "INSERT INTO material (Codigo,".
      "    Descricao,".
      "    ControlaStocks,".
      "    ValorMaterial,".
      "    StockRuptura,".
      "    Unidade,".
      "    Data_Material,".
      "    CodigoLocalizacao,".
      "    TipoLocalizacao,".
      "    UnidadeStockRuptura,".
      "    StockExistente)".
      "VALUES ('$materialFactorVo->Codigo',".
      "   '$materialFactorVo->Descricao',".
      "   '$materialFactorVo->ControlaStocks',".
      "   '$materialFactorVo->ValorMaterial',".
      "   '$materialFactorVo->StockRuptura',".
      "   '$materialFactorVo->Unidade',".
      "   '$materialFactorVo->Data_Material',".
      "   '$materialFactorVo->CodigoLocalizacao',".
      "   '$materialFactorVo->TipoLocalizacao',".
      "   '$materialFactorVo->UnidadeStockRuptura',".
      "   '$materialFactorVo->StockExistente')";
      for($c = 0; $c < count($materialFactorVo->ArraySeries); $c++)
      $sql="INSERT INTO serie (Cod_Material,"."Serie)"".""."VALUES ('".$materialFactorVo->ArraySeries[c]->Cod_Material."',"."'".$materialFactorVo->ArraySeri es[c]->Serie."')";
      $exec2 =  @mysql_query($sql,$this->con->getConnection());
      if ($exec)$hasExecute = "true"; else   $hasExecute  = "false";
      $xml = "<root>";
      $xml .= "<insert>".$hasExecute."</insert>";
      $xml .= "</root>";
      return $xml;
      public function delete(MaterialFactorVo $materialFactorVo)
      $query = "DELETE FROM material WHERE ID = $materialFactorVo->ID";
      if ($exec) $hasExecute = "true"; else   $hasExecute  = "false";
      $xml = "<root>";
      $xml .= "<remove>".$hasExecute."</remove>";
      $xml .= "</root>";
      return $xml;
