1. Re: Project size / Import sequence
JSS1138 Sep 5, 2011 10:23 AM (in response to Danielpremiere)I don't think a definitive cause, or solution, was ever found for the memory warning message in CS3.
Honestly, your best bet may be to upgrade to 5.5 and ditch the Matrox. The trial is fully functional, and opening the current project will force you to create a copy of it, so the original remains unaltered. This way you can test to see if everything works.
2. Re: Project size / Import sequence
Danielpremiere Sep 5, 2011 10:40 AM (in response to JSS1138)Hi,
Thanks for the thought. Unfortunately the quote of over £4,000 +VAT for a new machine does not go down well with my boss so for the time being I must continue with my existing system. I cannot install CS5.5 on my existing machine as I am running Windows XP SP2 32 bit.
Any thoughts on being able to import a sequence from one project into another?
Daniel
3. Re: Project size / Import sequence
JSS1138 Sep 5, 2011 1:41 PM (in response to Danielpremiere)You don't necessarily need a new machine, just a new OS.
You can get Windows 7 64 bit for about $140.
