6 Replies Latest reply on Sep 6, 2011 10:49 AM by Kristin95762
    loading a dataProvider from a class file
    Kristin95762 Level 1
      Hello
      This code is in the class file. I want to replace the code that's commented out with the code below it. I just don't know how to get access to the publishedWorksList. Getting an error: Access of undefined property publishedWorksList. I have bindings on the other variables that work fine.
      /*private function loadPublishedWorksResult(event:SQLEvent):void
           var data:Array = selectPublishedTitles.getResult().data;
           adwTitlesDP = new ArrayCollection(data);
           var result:SQLResult = selectPublishedTitles.getResult();
           var numResults:int = result.data.length;
           for (var i:int = 0; i < numResults; i++)
                var row:Object = result.data[i];
                var bookTitle:String = row.title;
                adwWebsite = row.website;
                adwAuthorComments = row.comments;
                publishedWorksList.dataProvider.addItem({label:bookTitle});
      Kristin
        • 1. Re: loading a dataProvider from a class file
          kokorito Level 4
          easiest way would be have a class variable arraycollection which  loadPublishedWorksResult adds to
          then have  publishedWorksList bind to it as the dataprovider
          • 2. Re: loading a dataProvider from a class file
            Whoa! English....
            But let me take a stab at what you mean.
            Are you saying something like: (I'm modifying an example I found in the FB4/Flex 4 Bible, pg 545 in case you have the book. Don't understand it though)
            package valueObjects
                 [Bindable]
                 public class AuthorDetails
                      public var title:String;
                      public var website:String;
                      public var comments:String;
                      public function AuthorDetails()
            Should I then run my sqlstatements here?
            I'm not seeing it.
            Thanks again.
            Kristin
            • 3. Re: loading a dataProvider from a class file
              kokorito Level 4
              at the moment your loadPublishedWorksResult is trying to add an item to the dataprovider of publishedWorksList which isnt in the same scope
              so instead make a class variable, in the class
              [Bindable] public var worksList:ArrayCollection;
              in the loadPublishedWorksResult method instantiate the arraycollection and add items to it
              then in the main, bind the publishedWorksList to it
              <s:List id="publishedWorksList" dataProvider="{myClass.worksList}"/>
              • 4. Re: loading a dataProvider from a class file
                Okay, currently this is in my class file, just after the package declaration:
                [Bindable]
                public var adwTitlesDP:ArrayCollection;
                and this is in the application file:
                     x="385" y="196" width="285"
                     dataProvider="{authorDetails.adwTitlesDP}"               (in the constructor function:  authorDetails = new AuthorDetailsClass();)
                     labelField="title"/>
                So far, this looks like what you have posted.
                The function in question: The list box may contain many book titles, while the other controls only represent one cell in the table. That's my hope at least.
                          publishedWorksList.dataProvider.addItem({label:bookTitle});               (problem line)
                So I instantiate the arrayCollection thusly (?):
                myTitlesAC = new adwTitlesDP;
                Then I have to change the reference to the dataProvider of my list I suppose.
                Assigning data to myTitlesAC....
                myTitlesAC = what???
                Thanks for your help.
                KRistin
                • 5. Re: loading a dataProvider from a class file
                  kokorito Level 4
                  you cant add items directly to the list dataprovider because it is outside the class (problem line)
                  but you have bound the list to a variable inside the class, so use that
                  adwTitlesDP = new ArrayCollection();
                  adwTitlesDP.addItem({label:bookTitle});
                  • 6. Re: loading a dataProvider from a class file
                    Hi
                    Darn, I almost had that on my own. Just didn't realize where the dataprovider was instantiated. Thanks a lot.
                    Really appreciate the help.
                    Kristin
