4 Replies Latest reply on Oct 10, 2011 3:29 AM by Al_kashi
    black screen after splashscreen / iPad
    Al_kashi
      Hi all,
      I tried to add a splashscreen in my flex mobile project by adding the splashScreenImage attribute on my Application tag.
      When the 'Default.png' file is present, it works well, the application start with the 'Default.png'.
      ==> But just after this 'Default.png' splashscreen, we can see a black screen for 1 second juste before the 'splash.png' splashscreen appears
      Is it a known bug ?
      Is it possible to have the splashscreen visible unitl the complete loading of the app and see the 'splash.png' screen without the black screen stepe ? (as the native behavior)
      Thanks in advance for your feedback.
      PS : I ever tried to set splashScreenMinimumDisplayTime at 2000 or more. The issue is the same, always have this black screen.
        • 1. Re: black screen after splashscreen / iPad
          Al_kashi Level 1
          No idea ? Really ?
          Does anyone ever note the same issue ?
          • 2. Re: black screen after splashscreen / iPad
            Leafcutter Level 1
            Did you find a solution to this?  I have the same problem:
            My iPad app initially displays the Default-Portrait.png file on loading.  Then when the app gets control of the screen this file is removed automatically by the platform.  The first thing I try to display is a png file which is the same as Default-Portrait.png.  However there is a delay between the Default splash being removed and me being able to get the new screen displayed, causing a flicker.
            I don't seem to be able to get the correct resolution of the screen immediately at startup and so have to wait a fraction of a second before I can put the correct image up.  Seems like a bit of a problem if your app needs to do some work initially on startup and would like to keep the same splash screen in place.
            • 3. Re: black screen after splashscreen / iPad
              Al_kashi Level 1
              No, didn't find any solution.
              I think there's no way to deal with that :/
              • 4. Re: black screen after splashscreen / iPad
                Al_kashi Level 1
                So I finally manage to squeeze this black screen.
                Fort this, just rename the Default.png file to Default-Landscape.png file. Be sure to remove the Default.png file
                Maybe my case i particular coz I only handle the landscape mode in my app. (no portrait mode needed).
                But I think that the solution is to put only the Default.png files needed
