0 Replies Latest reply on Sep 6, 2011 3:41 AM by cronjb
    Adobe Reader X change the PDF version after saved
    cronjb
      Hi all,
      I recently discovered a weird behavior of Adobe Reader X (free version) regarding the .PDF version document.
      I scanned just before the week-end a series of documents with default 1.4 version, I checked several and all were ok, Scanner did the job well.
      The only problem is that every time I opened a document and save it under a different name, or replace under the same name – Save As option (Shift+Ctrl+S); the version of the document is automatically changed from 1.4 to 1.5; This is very annoying since I do not need 1.5 document version I use only 1.4.
      Is there a way to work around this? I mean the Adobe Reader X should not keep the version 1.4 and not change it to 1.5
      Thanks is advance for looking into this
