First off, I am working with ColdFusion 8. I am calling a web service method with an argument with the WSDL definition:
<s:element minOccurs="0" maxOccurs="1" name="billing_details" type="tns:billing_details"/>
I am calling the method with the cfinvokeargument of
<cfinvokeargument name="billing_details" omit="true" />
According to the documentation: "If you are invoking a web service, you can omit a parameter by setting the omit attribute to "yes". If the WSDL specifies that the argument is nillable, ColdFusion MX sets the associated argument to null. If the WSDL specifies minoccurs=0, ColdFusion MX omits the argument from the WSDL."
My SOAP request XML contains: <billing_details xsi:nil="true"/>
From my reading of the documentation, that element shouldn't be there. Can anyone clarify if that is correct?
You are right. According to the documentation the billing_details element shouldn't be there.
However, I do believe the documentation is wrong. It is in fact wrong on one count already: "ColdFusion MX" should instead be "ColdFusion 8" or just "ColdFusion".
In this case, ColdFusion is a client, and may not necessarily have anything to do with the WSDL. So, the last sentence should be something like "If the WSDL specifies minoccurs=0, ColdFusion omits the argument from the web service invocation."
