3 Replies Latest reply on Sep 7, 2011 1:38 PM by rbsiv
    importing .asf files, blurry in source/sequence monitors and output
      I have a large amount of material to work with in .asf form, 480x360 resolution. I'll be outputting to 480x360 as well, so no scaling/zooming needed at all. Problem is, when I import one of those asfs it immediately becomes blurry, i.e. in the source monitor even before I insert it into the sequence and do any modifications. Comparing the imported files to the originals there is a noticeable difference at the exact same dimensions.
      I've made sure my sequence settings are at 480x360 resolution. Not sure where else to look on this, any suggestions?
      In the past I've done a very similar workflow in PE with no problems, so I'm assuming (hoping??) that there's some easily changed option. Thanks in advance.
