19 Replies Latest reply on Dec 1, 2011 6:51 AM by jgillies
    New text titles (created in CS5) are blurry
    rbsiv Level 1
      Trying to make a simple static text title - white text on black - created in Premiere CS5 itself. Tried a variety of project/sequence presets and fonts, but on all of them the text is blurred/frayed when inserted into the timeline and/or exported. Strangely, it looks perfectly crisp when editing the title or when manually advancing the sequence by dragging the pointer above the timeline (when the mouse is released though, it immediately reverts). My test titles have all been created in the same project, set at the same resolution, etc.
      A search showed several other people with this problem, but no solutions... any thoughts?
        • 1. Re: New text titles (created in CS5) are blurry
          Harm Millaard Level 7
          OE = Operator error.
          due to using wrong video drivers, using the program monitor to judge quality, wrong system setup, or a whole range of other OE's.
          How do they look on a properly calibrated monitor or on a DVD when played on a regular settop box and TV? Could it be related to your .ASF problems?
          • 2. Re: New text titles (created in CS5) are blurry
            rbsiv Level 1
            Whatever Harm, I'm aware it's probably OE as you call it - just looking for help troubleshooting. Though I'm not a Premiere guru by any stretch, I have used it and PE for various tasks throughout the years. This includes making simple text titles in the application itself, which previously had been crisp and clear when viewed in various video player apps. So yes, there is a setting or something amiss.
            • 3. Re: New text titles (created in CS5) are blurry
              As Colin said in your other thread, have you set the playback resolution to full? Do you have the latest video drivers installed? What is your source material? Does the same happen with material from a regular video camera? Or when the title is overlaid over a still? We need more details to come up with suggestions.
              Details like your system setup, your source material, your sequence settings, etc. Anything that may be specific to your situation but that is not encountered by most people.
              • 4. Re: New text titles (created in CS5) are blurry
                Dazed and Comfuzed
                I have the same problem, have you found a solution yet.
                • 5. Re: New text titles (created in CS5) are blurry
                  jgillies
                  I have the same issue (CS5.5). I have checked my  aspect ratios, frame sizes, tried doubling the title sequence sizes -- every suggestion I could find on the web. There are examples of this online as to what it looks like.
                  There is no way (that I can see) like Photoshop to set the appearance of the text (Sharp, crisp, etc.) It is really quite a problem and I am not sure what to do at this point.
                  Help would be appreciated. I am sure I am missing a setting somewhere. OE? Maybe. Lack of control over text? Maybe.
                  • 6. Re: New text titles (created in CS5) are blurry
                    the_wine_snob Level 9
                    Welcome to the forum.
                    Can you give us the full specs. of you Sequence, and exactly where you are seeing the problem? More detail is better.
                    It is likely that the solution will come from those specs.
                    • 7. Re: New text titles (created in CS5) are blurry
                      jgillies Level 1
                      For the blur -- it looks like softened text as opposed to sharp text. I am viewing this on a LaCie 526. I see this problem upon creation of the titles, rendering, export, MOV playback and DVD playback.
                      I have a number of  JPEG photos arranged in a pan/scan effect that render perfectly.
                      The titles are run over black, some are intro with dissolve into motion scale from 75% to 100% (reverse for outro).
                      Sequence Specs
                      Vid: 720x480 (1.2121), 29.97 fps, Lower
                      Aud: 32000 Hz, Stereo
                      For the output I render it is identical, save for maximum render quality, frame blending.
                      The title still specs (created in the title tool):
                      Title Type: Still
                      Data Size: 5 KB
                      Title Size: 720 x 480
                      Pixel Depth: 32
                      Pixel Aspect Ratio: 1.2121
                      I have one black colour matte (oversized) that I run in behind everything as there is a PIP of a candle in the lower left corner of the video:
                      File Path: Color Matte
                      Type: Color Matte
                      Image Size: 1920 x 1080
                      The PIP corner video is the only anomaly that I can see as it is a different aspect ratio and frame rate (although it is much smaller on the stage) -- should i interpret that as 29.97 FPS?
                      Type: QuickTime Movie
                      File Size: 25.9 MB
                      Image Size: 640 x 360
                      Frame Rate: 30.00
                      Total Duration: 00:00:28:00
                      Average Data Rate: 946 KB / second
                      Pixel Aspect Ratio: 1.0
                      QuickTime Details:
                      Movie contains 1 video track(s), 0 audio track(s) and 0 timecode track(s).
                      Video:
                      There are 840 frames with a duration of 1/30th.
                      Video track 1:
                      Duration is 0:09:20:00
                      Average frame rate is 30.00 fps
                      Video track 1 contains 1 type(s) of video data:
                      Video data block #1:
                      Frame Size = 640 x 360
                      Compressor = Photo - JPEG
                      Quality = Most (5.00)
                      Thank you,
                      Jeremy
                      • 9. Re: New text titles (created in CS5) are blurry
                        jgillies Level 1
                        Thank you for that link, some great b/g info and suggestions to try.
                        • 10. Re: New text titles (created in CS5) are blurry
                          jgillies Level 1
                          Alas... to no avail. I tried creating a new timeline in higher res, also eporting to mp4... same thing -- almost exactly. I like the keyline idea suggested, but it is white text on black bg.
                          • 11. Re: New text titles (created in CS5) are blurry
                            Powered by Design Level 4
                            Screen shots would be helpfull.
                            Also try a sequence with no footage.
                            Just use a Matte and text so you know its not video related.
                            Write what font you used and the size in the screen capture and we can try it and see if we get different results.
                            GLenn
                            • 12. Re: New text titles (created in CS5) are blurry
                              jgillies Level 1
                              I cannot post the originals as it is a private memorial presentation (test text below), My next step is to try the  suggestion of sequence with no footage (you were reading my mind :). The other thing I am going to try is to go up to 1080 master with everything and then output to a smaller aspect file to see what that does.
                              I know the typeface is not ideal (Adobe Caslon Pro Semi Bold at about 60pt and 40pt) -- and it is white / grey on black.
                              Thanks again,
                              Jer
                              SS in Premiere
                              SS from output
                              Main title:
                              Individual Title:
                              • 13. Re: New text titles (created in CS5) are blurry
                                jgillies Level 1
                                One quick mod I just did was to create the test at 1920/1080p as square pixels for the text and black matte. NIGHT AND DAY difference (below). Yes there is still some softening, but it is a much better rendering.
                                • 14. Re: New text titles (created in CS5) are blurry
                                  jgillies Level 1
                                  Update
                                  I remade the whole thing as per specs above (1920x1080p/square pixel).
                                  Export was fantasic (I kept it the same as the sequence since I am outputing to DVD as primary, web secondary -- if ever).  No issues that I can see so far inplaying the whole thing in QT. Text is crisp, motion/scale is great, dissolves are fine.
                                  Next test is to create a DVD from it.
                                  • 15. Re: New text titles (created in CS5) are blurry
                                    jgillies Level 1
                                    DVD burn worked well -- no issues on my LaCie screen. I will test it on an HDTV tonight.
                                    • 16. Re: New text titles (created in CS5) are blurry
                                      Great news! Thanks for reporting your success.
                                      • 17. Re: New text titles (created in CS5) are blurry
                                        One thing to remember too is when working with interlaced video you can display both fields and it will show clearer inside Premiere.
                                        I wish we all had HD progressive square pixel TV's and Computers.  That way whatever you create on the computer would look the same for everyone.
                                        HD sure makes a difference and Progressive does too.
                                        I hate interlaced but that is where the world is.
                                        GLenn
                                        • 18. Re: New text titles (created in CS5) are blurry
                                          jgillies Level 1
                                          The interlace tip is a good one. Thank you.
                                          On the DVD copy, It was an interesting result. I did not use a high end tool to make it, I just went one-step from movie iDVD. When I watched it on an HDTV, the titles were showing, it dimmed the candle video. Not what I wanted, but it added an acceptable effect that looked deliberate. I have 3 copies in the field for testing now, so it will be interesting to see if people notice.
                                          For me, I consider this issue solved, but I cannot speak for the previous posters in the thread.
                                          Thanks to everyone who helped,
                                          Jer
                                          • 19. Re: New text titles (created in CS5) are blurry
                                            jgillies Level 1
                                            Hi everyone,
                                            I thought I would post an addendum to this thread. The final DVD copies I made worked well on HDTVs and LCD/LED monitors, but there are a small percentage of people out there with tube TVs.
                                            I ran it through a 15yr old namebrand tube tv and yikes -- the text was dancing on the screen -- especially when there was movement.
                                            There is a good tip in the post above : http://library.creativecow.net/articles/hodgetts_philip/titles.php
                                            The text was 100% white / grey on black. I dropped it to the recommended 80%, still a bit much. I found that 70% worked best for this one. A happy medium between the different kinds of display.
                                            I also dropped the gamma on the candle to 80% of its original as there was a notable difference in the black background of the black matte and the background of the candle on the tube TV. Of note, I ran this presentation originally on two side screens that were 16:9  (photos in pan/zoom with text) and a 3:1 (36 foot x 12 foot) centre screen -- it did not show the contrast in the backgrounds, nor did any HDTV I tried the merged programme (this project) on.
                                            Hope that helps,
                                            Jer
