4 Replies Latest reply on Sep 8, 2011 12:41 AM by nfact
    OMF Export bug with P2 media
    nfact
      Try the following:
      Create a sequence with P2 clips.
      Nest the seqence into a new sequence.
      Add some edits to the nested sequence.
      Export as OMF.
      Import the OMF into an audio editing suite like Nuendo or Cubase or Protools.
      All audio clips have the wrong or simply no content.
      Big bug! Needs to be fixed.
      If you export a sequence with P2 files that isn't nested everything is OK in the OMF. Only if you use P2 in nested seqences every P2 clip in the OMF is garbage.
      Regards
