0 Replies Latest reply on Sep 7, 2011 9:23 AM by snes2078
    Datagrid colum item renderer HELP!!!!!
    snes2078
      I have the below datagrid, and I have to populate one of the column with three different images, a cricle an squeare and a triangle. I've been sucessful adding dinamically the differents itemrenderers. For the triangle one it has been a really pain in the *** tying to draw the triangle, but finally i figured it out, and I can draw it, but I cant set the result triangle in the middle of the column, I dont know if it's a Sprite. But I've tried with a button and it sets in th emiddle of the column, so it has to be because the sprite or something i'm doing work in some of the classes. Please HELP!!! I really appreciate your help and advice I'm newbie at Flex.
      Thanks in advance!!!
      <s:HGroup y="200" left="22" right="22">
           <s:Group width="100%">
                <mx:DataGrid id="dgDatosMapa" width="357" height="108" visible="true" dataProvider="{arrDatos}" rowHeight="40">
                     <mx:columns>
                     <mx:DataGridColumn headerText="Símbolo" dataField="simbolo" textAlign="center" width="80" />
                     <mx:DataGridColumn headerText="Tamaño" dataField="size" textAlign="center" visible="false" />
                     <mx:DataGridColumn headerText="Intervalo" dataField="intervalo" textAlign="center" width="80"/>
                     <mx:DataGridColumn headerText="Rótulo" dataField="rotulo" textAlign="center" width="80"/>
                     </mx:columns>
                </mx:DataGrid>
           </s:Group>
      </s:HGroup>
      var col:DataGridColumn = dgDatosMapa.columns[0];
      col.itemRenderer = new ClassFactory(triangle);
      package widgets
      import flash.accessibility.AccessibilityProperties;
      import flash.display.DisplayObject;
      import flash.display.DisplayObjectContainer;
      import flash.display.Graphics;
      import flash.display.LoaderInfo;
      import flash.display.Sprite;
      import flash.display.Stage;
      import flash.events.Event;
      import flash.geom.Point;
      import flash.geom.Rectangle;
      import flash.geom.Transform;
      import mx.containers.Canvas;
      import mx.containers.HBox;
      import mx.controls.List;
      import mx.controls.listClasses.IListItemRenderer;
      import mx.controls.listClasses.ListItemRenderer;
      import mx.core.UIComponent;
      import mx.managers.ISystemManager;
      import spark.components.Group;
      import spark.primitives.Graphic;
      import spark.primitives.Line;
      import widgets.CustomImportLayers.ImportLayers;
      public class triangle  extends UIComponent implements IListItemRenderer
      private var _objData:Object;
      private var sprite:Sprite;
      public function triangle()
      super();
      height=20;
      width=16;
      override protected function createChildren():void
      super.createChildren();
      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
      super.updateDisplayList(unscaledWidth,unscaledHeight);
      public function drawTriangle(datos:Object):void
      _objData = datos;
      sprite = new Sprite();
      var triangleHeight:int = (_objData.size/4);
      var uic:UIComponent = new UIComponent();
      sprite.graphics.lineStyle(1,int(0x000000),1);
      sprite.graphics.beginFill(_objData.simbolo);
      sprite.graphics.moveTo((triangleHeight/2)+2, 3);
      sprite.graphics.lineTo(triangleHeight+2, (triangleHeight+1));
      sprite.graphics.lineTo(2, triangleHeight+1);
      sprite.graphics.lineTo((triangleHeight/2)+2, 3);
      sprite.graphics.endFill();
      uic.addChild(sprite);
      this.addChild(uic);
      override protected function commitProperties() : void
      super.commitProperties();
      public function set data(value:Object):void
      _objData = value;
      public function get data():Object
      return _objData;
      package widgets
      import mx.containers.VBox;
      import mx.controls.Button;
      import widgets.GenMapasTematicos.triangle;
      public class tri  extends HBox
      private var trian:triangle;
      public function tri()
      super();
      this.width=80;
      this.setStyle("horizontalAlign", "center");
      this.setStyle("verticalAlign", "top");
      var b:Group = new Group();
      b.percentWidth=100;
      this.addChild(b);
      trian = new triangle();
      b.addElement(trian);
      trian.drawTriangle(_objData);
      override public function set data(value:Object):void
      _objData = value;
      super.invalidateDisplayList();
      override public function get data():Object
      return _objData;
