3 Replies Latest reply on Sep 8, 2011 12:11 AM by Barno7
    TextArea And Html..only editable ?
    Barno7 Level 1
      hi,
      i want do a TextArea with HtmlText inside, i follow this Example inside the documentation:
      http://pastebin.com/GRyUc67G
      this is works, but if i do a textArea non editable, i can't scroll the content. i try use init instead creationComplete, the scroll works, but the textArea content is bottom
        • 1. Re: TextArea And Html..only editable ?
          Daniel Pride Level 1
          If I understand you question properly.... and assuming you are indeed talking about the mobile Flex not web...
          There is a property called verticalScrollPolicy that you need to enable
          i.e. verticalScrollPolicy='on'
          However I think you would be better off using StageWebView
          Something like
          protected var myHtml:StageWebView = new StageWebView;
          protected function init():void{
          myHtml.stage = stage;
          myHtml.viewPort = new Rectangle(0,0,100,100);
          myHtml.load(thestuffyouwanttodisplay);
          Someone else may be able to do it but I think editable html at this point is beyond the pale... things like Rich Text are not supported in the Mobile components that are currently available.
          Dan Pride
          • 2. Re: TextArea And Html..only editable ?
            Barno7 Level 1
            thanks for the answer,
            but I can not to load HTML text into this object
            • 3. Re: TextArea And Html..only editable ?
              Barno7 Level 1
              i use this code
              <!-- mobile_text/HTMLTextView.mxml -->
              <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="HTMLText View"
              addedToStage="addedToStageHandler()">
              <fx:Script>
              <![CDATA[
              protected var webView:StageWebView = new StageWebView();
              protected var counter:int = 0;
              protected var url:String = "http://coenraets.org/webview/index.html";
              protected function addedToStageHandler():void
              var styles:String = "p { color: #33CCFF; font-size:30;}";
              var myStyleSheet:StyleSheet = new StyleSheet();
              myStyleSheet.parseCSS(styles);
              var pippo:String =  "<!DOCTYPE HTML>" +
              "<html>" +
              "<body>" +
              "<h1 style='background: blue; color: white;'>Title</h1>" +
              "<p>Hello World.</p>" +
              "</body>" +
              "</html>";
              webView.stage = stage;
              webView.viewPort = new Rectangle(0,100,600,30);
              //webView.loadURL(url);
              webView.loadString(pippo,"text/html");
              </fx:Script>
              </s:View>
              with this code, i see the text with background and color, but:
              - the scrollbar is not that of texr field?
              - how can i associate the file css?
              thanks!
