2 Replies Latest reply on Sep 8, 2011 6:28 PM by BackyardMoonster
    button on frame 2 won't return to frame 1
    BackyardMoonster
      I have created a racing game and over all i got 3 frames and about 10 main layers (not sure if that matters for you to help?)
      Anyway, i have tried so many scripts now and they're not working :/ Please.... Please help if you can.
      The game begins on frame 2 while the main menu is on frame 1.
      Not sure if it matters but i have the menu copied on all the frame 1's of all the layers...
      Main menu instance is called menu
      The 2nd frame i have not named.
      Pleaseeee.....
        • 1. Re: button on frame 2 won't return to frame 1
          Ron Colmen Level 2
          It would be helpfull if you show your code for that perticular action.
          try: on frame 2
          InstanceOfYourButtonOnFrame2.onRelease = function () {
          gotoAndStop(1);
          • 2. Re: button on frame 2 won't return to frame 1
            BackyardMoonster Level 1
            I have 4 frames and about 10 main layers.
            I Only need a code that allows me to have two key's pressed at the same time.
            my actions are both in frame 2 as my main menu is on frame 1 but in different layers.
            that's why I only need a code that lets me select both the LEFT key and SPACE key together.
            Here is the current game:
            http://thebackyardchampion.deviantart.com/#/d49807m -
            Please note! you won't see the booster in that version.
            you'll see what i mean by i want the left key and space key to work together.
            Because when booster is activated, it will need to have a more stiff rotation speed.
            HOLD ON
            i'll explain it a bit better!
            I want to know the left and space key not directly for the booster but for the rotations speed.
            For example I already got:
            acceleration = 0.5; (is asigned to the up key)
            acceleration2 = 0.7; (is asigned to the booster)
            maxSpeed = 20;
            maxSpeed2 = 20;
            Below is the actions asigned to the above..
            if (Key.isDown(Key.UP) && this["speed"+who]<_root.maxSpeed) {
            this["speed"+who] += _root.acceleration;
            if (Key.isDown(Key.SPACE) && this["speed"+who]<_root.maxSpeed2) {
            this["speed"+who] += _root.acceleration2;
            Hope you now see why I need an asignment for
            rotationStep = 15.3;
            rotationStep2 = 12.3;
            rotationStep2 will be for when the space bar and left key is pressed together.
